Forum
Suzuki Jimny
Jimny Technical
cluch pedel
BigJimnyMeet 2024
cluch pedel
suzuki jimny fella
Topic Author
Visitor
12 Jul 2012 17:38 #44034
by suzuki jimny fella
has got squeaky any ideas guy has it dry up or something
myers647
Visitor
12 Jul 2012 20:45 #44046
by myers647
Hi mate is the Pedal stiff when you press it down. Mine squeaks and it hard to push down I wasnt sure whether the cable was just stretched or not.
suzuki jimny fella
Topic Author
Visitor
markyp2000
Visitor
12 Jul 2012 22:01 #44051
by markyp2000
wd40 on the peddle area if it stops use an oil can or grease
suzuki jimny fella
Topic Author
Visitor
12 Jul 2012 22:45 #44057
re greased the pedal and cable but noise is coming from clutch fork i think
mark1971
Visitor
13 Jul 2012 08:09 #44070
by mark1971
Mine has just started with exactly the same symptoms, watching this with interest. My pedal feels a tad stiffer than it used to, which i thought might be the clutch cable snagging internally somewhere.
markyp2000
Visitor
13 Jul 2012 10:20 #44075
by markyp2000
get some one to push the peddle up and down while your underneath and spray wd40 in where the cable goes on the clutch release bearing my sj used to suffer from the bearing sticking on the shaft due to mud etc then start it up and just spray a bit in there while its spining just dont put fingers in while its running
247sniper
Visitor
14 Jul 2012 10:00 #44140
by 247sniper
Could be the clutch release bearing mate. Remove the slave cylinder rubber cove on the gearbox and squirt some WD40 on the clutch release bearing, be sure not to get any on the clutch itself though!, The squeak/ noise should disappear of significantly reduce thus confirming where the fault lies.
hope this helps
Steve.
markyp2000
Visitor
14 Jul 2012 13:32 #44151
by markyp2000
247sniper wrote: Could be the clutch release bearing mate. Remove the slave cylinder rubber cove on the gearbox and squirt some WD40 on the clutch release bearing, be sure not to get any on the clutch itself though!, The squeak/ noise should disappear of significantly reduce thus confirming where the fault lies.
hope this helps
Steve.
jimnys have cable clutches not slave cylinders and you have just repeated nearly the same as what i put up before you and if it gets on the clutch it will burn off (dont people ever read all the post before replying and repeating things over and over again rant over have a nice day lol
247sniper
Visitor
15 Jul 2012 08:39 #44173
by 247sniper
God there are some funny people about. At least when I say something I can say it with a high level of accurace/authority being a Vehicle tech for over 15 years like. I dont play at it or I dont just guess, which the common wild guesses offten seems to be the case!
Steve.
markyp2000
Visitor
15 Jul 2012 10:36 #44180
by markyp2000
well your just like me then i have also been in the motor trade for over 15 years so what part or my last post wasnt a high level of accurace and what makes you the best of the best i may no more then you on one thing and you no more than me about another so when did suzuki bring in a slave cylinder on the clutch system on a jimny rant over so come on then 247sniper you post a reply to this and thats the last of it ok as this is not the place to banter it a place to try and help people
mark1971
Visitor
16 Jul 2012 17:46 #44281
by mark1971
Now i like markyp2000 but then i like 247sniper.........but which ones better????
Theres only one way to find out............FIGHT............
LOL only joking
Forum
Suzuki Jimny
Jimny Technical
cluch pedel
