BigJimnyMeet 2024
Problems fitting ORA bumpers
- Smoggy
- Visitor
06 Jul 2012 18:38 - 06 Jul 2012 18:45 #43612
by Smoggy
Problems fitting ORA bumpers was created by Smoggy
Im having a nightmare job with my front bumper fitting. When I removed the old bumper I realised the car has previously had a bit of a bump. The crumple legs were slightly bent (mostly on passenger side). I thought it would be okay because I was cutting these off anyway per the ORA instructions.
But the remainder of the chassis leg is still not great.
There is a weld about 8'' back (just behind where the body mount leg attaches to the chassis leg).
I was thinking of cutting the chassis leg here and reattaching the body mount leg and slam panel to a newly fabricated leg.
Any ideas anyone?
Any ideas anyone?
Last edit: 06 Jul 2012 18:45 by Smoggy.
- X-Eng Simon
- Visitor
06 Jul 2012 20:00 - 06 Jul 2012 20:00 #43613
by X-Eng Simon
Replied by X-Eng Simon on topic Re: Problems fitting ORA bumpers
Mine was similarly bad - and had taken an impact in the middle which had crumpled the cross member. I cut this out and sleeved the original chassis rails with 3mm plate before replacing the cross member with CDS tube.
In your case, I'd be inclined to do similar - perhaps replacing the cross member with box section.
Only cut the minimum off the ends of the chassis legs you need to. Then you have something solid to attach the bumper to.
Sleeving the rails you have a better chance of getting a decent strength weld (and enough length of it) than a butt weld of a new bit of box on to the chassis rail end. In addition to welding the end, cut some holes in the sleeves & plug-weld to the original chassis leg.
Si
Si
Last edit: 06 Jul 2012 20:00 by X-Eng Simon.
- Smoggy
- Visitor
06 Jul 2012 20:16 - 06 Jul 2012 20:19 #43615
by Smoggy
Replied by Smoggy on topic Re: Problems fitting ORA bumpers
Thats great Si Thanks.
I will replace the crossmember with some 3mm box and remove the body mount legs, then sleeve 3mm plate/box over the existing leg and plug weld through to the legs. Then re-attach the body mount.
Just as you suggest
I was gonna remove the front antiroll bar anyway! If they ask for one at MOT time then il make sure the cross member box replacementis positioned accordingly.
Thats why youre the expert, grateful guys like you on here.
Just as you suggest
Last edit: 06 Jul 2012 20:19 by Smoggy.
- Smoggy
- Visitor
14 Jul 2012 20:00 - 14 Jul 2012 21:03 #44160
by Smoggy
Well I've sleeved the chassis legs and welded in a 100mm x 50mm steel 3mm crossmember. Please feel free to add your comments on my dubious welding skills (I gratefully welcome your comments/criticism on whether you believe the welds will withstand the rigours of winching jim through the mud).
Some of the welds look good to me - others less so
Driver chassis leg outside:
Inside:
Passenger chassis leg outside:
Inside:
Inside/top:
Front View:
Inside:
Inside:
Inside/top:
Front View:
Last edit: 14 Jul 2012 21:03 by Smoggy.
- Smoggy
- Visitor
14 Jul 2012 20:06 #44161
by Smoggy
Cant load pics - keeps coming up fatal error contact site owner?
- markyp2000
- Visitor
14 Jul 2012 20:26 #44162
by markyp2000
Replied by markyp2000 on topic Re: Problems fitting ORA bumpers
whats the pixal size may be to big
- Smoggy
- Visitor
14 Jul 2012 21:06 - 14 Jul 2012 21:30 #44164
by Smoggy
Phew
PS They're actually better than they look on camera.
Also what I thought about doing was drilling a10mm hole and fitting an M10 bolt through the sleeve and chassis on each leg just behind the crossmember (if that makes sense).
Mind you I know I will need to a better weld job when it comes to attaching the bumper mounts.
Last edit: 14 Jul 2012 21:30 by Smoggy.
- Thank you received: 210
15 Jul 2012 12:21 - 15 Jul 2012 12:23 #44187
by dirtydogz
2002 JLX Soft Top
Jimnybits 2" lift +Pro Comp ES1000 shocks. Big Jimny rear shock mounts. Big Jimny adjustable panhard rods.
Replied by dirtydogz on topic Re: Problems fitting ORA bumpers
well-done Smoggy when it's covered in under seal and mud no one will see it
2002 JLX Soft Top
Last edit: 15 Jul 2012 12:23 by dirtydogz.
- Smoggy
- Visitor
15 Jul 2012 16:36 #44199
by Smoggy
Thankfully the welding onto the bumper brackets was much much better. Especially after I had a bit of practice last night and upped the current and wire speed settings.
- Smoggy
- Visitor
15 Jul 2012 21:10 #44233
by Smoggy
- TomDK
- Visitor
15 Jul 2012 21:14 #44235
by TomDK
Replied by TomDK on topic Re: Problems fitting ORA bumpers
Looking good
Have any pics of the mounting brackets welded on ?
- Smoggy
- Visitor
15 Jul 2012 21:28 #44236
by Smoggy
Time to create page: 0.129 seconds
