BigJimnyMeet 2024
Yokohama Geolandar
- Thank you received: 2
23 Jan 2024 22:15 - 23 Jan 2024 22:19 #253706
by AJ
Yokohama Geolandar was created by AJ
I'm looking at replacing all the tyres on my 2019 SZ5. The original Bridgestones are still OK regarding tread but they are becomming more and more 'slippery' even ordinary traffic islands at fifteen MPH can be interesting when going slightly sideways! It's fun but scares my lady.
The tyres that consistantly seem to get the best reviews and feedback for a Jimny thats mainly used on the road to get to interesting places that then may require a little more traction. I like photography and often head out into the hills when it snows, getting to out of the way places for my macro photography also requires some care and good grippy tyres are essential if I'm not to spend the night there. I'm thinking these Geolanders may be a good choice but would like a little confirmation from those who are more knowledgeable than myself www.blackcircles.com/catalogue/yokohama/...H/96/m?tyre=35841793
Many thanks for any advice
Last edit: 23 Jan 2024 22:19 by AJ. Reason: Correct errors
- Thank you received: 178
23 Jan 2024 22:29 #253708
by gv42
Replied by gv42 on topic Yokohama Geolandar
YES the Geolanders are GOOD I have had set set or 2 on my 2 jimnys and good traction got 35k on it , in hills and snow and green lanes in N/WALES
The following user(s) said Thank You: AJ
- Thank you received: 552
23 Jan 2024 22:30 - 23 Jan 2024 22:38 #253709
by Scimike
Replied by Scimike on topic Yokohama Geolandar
I have Geolander fitted, I am mostly road use and for the few days it's snows, every now and again the odd track and muddy field.
They have been unstoppable on the snow and great in every day use. My go-to tyre, will be fitting again when they go bald.
Jimny on Geolanders in the snow
Never had an issue in the wet or when towing, so good tyre.
I suspect better exist for true off road, but good enough for my use.
Last edit: 23 Jan 2024 22:38 by Scimike.
23 Jan 2024 23:04 #253711
by AJ
Replied by AJ on topic Yokohama Geolandar
Thank you gv42, I'm in the Welsh Marches, many hills and lanes to explore. Your reply has helped a lot. The link I posted, are the tyres the correct size etc for a 2019 SZ5.
23 Jan 2024 23:07 #253712
by AJ
Hi Scimike,
Thank you so much for your reply, thats exactly what I was trying to find out. Is the link I posted the correct size etc for my gen 4 2019 Jimny.
- Thank you received: 372
23 Jan 2024 23:10 #253713
Replied by DrRobin on topic Yokohama Geolandar
I had Geolandars after Dueller ATs, they were much better and ideally suited to a Jimny that spends most of its time on the road with the odd trip off road on a track or grass.
When I started going off road more, I bought a second set of wheels and fitted Hancook Dynapros, intending to use those for winter/off road and switch back to Geolandars for other times. There wasn’t enough of a difference between Geolandars and Dynapros so swapped the Geolandars for Maxxis worm-drive.
The Geolandars were still like new so sold the tyres to someone who was putting them on a camper van conversion, he couldn’t believe his luck to find a good set.
So yes, I recommend them.
Robin
Robin
23 Jan 2024 23:21 #253714
by AJ
Hi Robin,
Thank you too, I'm so grateful to everyone on here, it was a few posts here that made me think Geolanders were the correct choice for my needs, You have just confirmed this, the Jimny is our main car,. it puts a smile on our faces whenever we use it! It has to be versatile so is used for shopping trips and trips into the hills along lanes that haven't seen any repairs for years, the grass growing in the middle of themm keeps the underside of Jimny nice and clean! Often have to pull off the hard surface to let lesser vehicles pass, the original tyres are now starting to slip a lot in such situations. Thank you Robin, going to order some shortly methinks, sound ideal for our needs and will help keep both us and Jimny safe.
Adrian
Adrian
- rogerzilla
- Visitor
24 Jan 2024 07:35 #253718
by rogerzilla
Replied by rogerzilla on topic Yokohama Geolandar
I've been quite impressed with them, although it hadn't snowed here. Some people report that they go hard and less grippy after two years.
24 Jan 2024 17:50 #253724
by AJ
Thanks for your input rogerzilla, much appreciated. I think part of the problem with my bridgestones is that the compounds have hardened, I'm hoping these new tyres will be better. They Geolandars seem to offer good value at the price point so will go with them I think.
Adrian
Adrian
24 Jan 2024 18:29 #253726
by AJ
Now ordered !
- Thank you received: 71
25 Jan 2024 14:23 - 25 Jan 2024 14:30 #253741
by lightning
Replied by lightning on topic Yokohama Geolandar
Last edit: 25 Jan 2024 14:30 by lightning.
- rogerzilla
- Visitor
25 Jan 2024 17:43 - 25 Jan 2024 17:45 #253747
by rogerzilla
There is quite a big difference in rolling diameter. The speedo will over-read even worse than normal and revs will be much higher for actual road speeds.
Blackcircles have the G015 in 195/70R15.
Last edit: 25 Jan 2024 17:45 by rogerzilla.
Time to create page: 0.171 seconds
