BigJimnyMeet 2024
Identifying Lift
- Blackout
- Visitor
25 Jun 2019 17:47 #210307
by Blackout
Identifying Lift was created by Blackout
Hi guys I am thinking about replacing shocks on my jimny they look battered and the rear lower bush has gone on one.
The guy I bought it off said “2” body and 2” suspension “
The shocks have no identifiers on them. Is there an easy way to work it out or where to measure from? I’m running 235/75/15 tyres. It looks high, got a pic next to a standard (I think) and it looks a load higher. I’m not convinced it is 2” suspension but due to liking the height I don’t want to order and fit a 2” and discover it was 3 or 4
Any ideas / anyone measured theirs with a 2 + 2?
- Thank you received: 923
25 Jun 2019 19:25 #210311
Replied by X8GGY on topic Identifying Lift
Hi! My daily driver -
Has a 2" Trailmaster Lift and a 2" Body Lift and 235/75.15 Tyres, and measures...
46.5" to the underside of the mirrors...
Hope that helps?
Dave
Hope that helps?
Dave
- Blackout
- Visitor
25 Jun 2019 20:48 #210313
by Blackout
Replied by Blackout on topic Identifying Lift
Awesome cheers Dave, will get tape measure out tomorrow !
- Thank you received: 552
26 Jun 2019 09:55 #210314
by Scimike
Replied by Scimike on topic Identifying Lift
In addition to the above if you can remove one of the shocks and measure it's fully compressed and extended dimensions you could get the supplier to check the ones being sent match this as a minimum. If you can get a smaller shock with a longer stroke it's the off road Holly Grail
- Thank you received: 1761
26 Jun 2019 10:29 #210315
Replied by Lambert on topic Identifying Lift
Any chance you can post a picture of the damper. Someone is bound to recognize it as there's only a limited number of aftermarket dampers that are usually used on Jimny?
- Blackout
- Visitor
26 Jun 2019 17:20 #210328
by Blackout
Guys thank you all for the input. I have attached pics and it seems to be measuring higher than Daves so not sure if it is 2” at all now
- Thank you received: 653
26 Jun 2019 17:26 #210329
Replied by jackonlyjack on topic Identifying Lift
That looks like a procomp code
26 Jun 2019 17:30 #210330
- Blackout
- Visitor
26 Jun 2019 17:41 #210331
by Blackout
Code looks like
0E1 1835 X3 10H1
With 12050 above
0E1 1835 X3 10H1
With 12050 above
26 Jun 2019 17:41 #210332
Replied by Riccy on topic Identifying Lift
You could post some pics of the radius arms that hold the axle to the chassis, to see if they are standard or after-market. Generally 2" kits use the standard arms, 3"+ use HD ones usually (for a full kit).
The Panhard rod looks standard, so I would guess that its on a 2" pro-comp kit, most likley Jimnybits. The extra height might be that its a 3" body lift instead of 2", or different spring/shock manufacturer to Dave's.
For the body lift have a look at where the body bolts to the chassis and you will see a block in-between the rubber bushes and mount, measure that and
you will see how big it is
- Blackout
- Visitor
26 Jun 2019 18:02 #210333
by Blackout
Sorry guys a total newbie to the Jimny think I have posted the pics also in the last pic something looks broke... gearbox mount ?
26 Jun 2019 18:23 - 26 Jun 2019 18:28 #210334
Can't see what you think is broken in pic
But I've looked at open/closed lengths on net and your shock is +2"
body block looks like a 2" to me with the cut down rubber possible stands at 3"
Last edit: 26 Jun 2019 18:28 by jackonlyjack.
Time to create page: 0.134 seconds
