Inevitable - snapped aerial
- shortylumber
- Visitor
Is it going to be a case of buying a stock aerial to replace, or can the original fitment be altered to fit a standard 5/6mm threaded one?
- Thank you received: 1764
- Thank you received: 653
- shortylumber
- Visitor
Lambert - yeah I did find one at around £23 after a little more searching, saw quite a few at £40 mind which was a little off putting at first sight
Why would you want a broken one?
It was cosmetically damaged in the post. The nylon sleeve that fits down into the pillar has been bent. The aerial itself is fine and extends and retracts ok.
£15 plus postage
- shortylumber
- Visitor
mlines wrote: I have a brand new broken one, genuine Suzuki.
£15 plus postage
Well an offer like that is hard to refuse, thank you. I'll drop you a message shortly.
I was looking at a raku 2 fitting and then adapting the current fitment to suit it before I saw your message.
- 1066Boy
- Visitor
- Caelite
- Visitor
I also need the wee bit of trim that caps the rubber rain rail on the front right corner
The aerials are "only" £43 from me, brand new genuine Suzuki so the used part at £60 is really bad value!
I will try and identify the roof part and get a price
- Caelite
- Visitor
Thanks for checking, just ordered one at my local dealer for £44. Would've pick one up from yourself but the zuke garage is only a 20 minute detour on my way to work so really isn't too bad. They however can't supply the plastic end-cap on its own as they can only order the whole rubber rail, for £53. Will need to find a scrap one somewhere.
Here's a link: www.thunderpole.co.uk/switches-filters/d...ntenna-splitter.html
