BigJimnyMeet 2024
× Are you building a Mud Monster or a Pavement Princess??
Re:The Rat Trap
  • Keirravn
  • Visitor
  • Visitor
08 Mar 2019 09:54 #204300 by Keirravn
Replied by Keirravn on topic The Rat Trap
I'm reluctant to spend money guessing is the only thing. I'd be much happier with a code!
08 Mar 2019 12:00 #204304 by Max Headroom
Replied by Max Headroom on topic The Rat Trap
Totally with you on that!
I reset mine several times by simply disconnecting the battery, but each time I reset it, it would remain off for shorter periods. It finally started to come back on very quickly - within a mile or so of setting off.
I eventually gave in and cx'd the damned thing
The following user(s) said Thank You: Keirravn
  • Keirravn
  • Visitor
  • Visitor
08 Mar 2019 13:50 #204307 by Keirravn
Max Headroom wrote: Totally with you on that!
What's CX? I originally thought you meant changed but now I'm not so sure?
Mines comes back right away sadly
08 Mar 2019 17:14 - 08 Mar 2019 17:15 #204313 by Max Headroom
Sorry - aviation engineering yuckspeak - I use it at work every day and its a habit.
cx = change and cx'd = changed.
You were absolutely correct! :cheer:
Last edit: 08 Mar 2019 17:15 by Max Headroom.
  • Keirravn
  • Visitor
  • Visitor
09 Mar 2019 09:56 #204342 by Keirravn
Replied by Keirravn on topic Re:The Rat Trap
Max Headroom wrote: Sorry - aviation engineering yuckspeak - I use it at work every day and its a habit.
Got ya! Ha ha
  • Keirravn
  • Visitor
  • Visitor
11 Mar 2019 22:54 - 11 Mar 2019 22:55 #204473 by Keirravn
Not much progress to report. I've been having my head nipped about the time spent on the Jimny so had to leave it alone a few days :p
I did get all the tail lights working! All electronics now good other than potentially that obd. I'm borrowing a proper reader on Monday so will take it from there.
Kingpin bearings have arrived and I'll order a CV tomorrow and fit it all next weekend if time and weather suits.
Since all my welding (that I know is needed anyway) is done and all my electrical gremlins (I believe) sorted I was able to pop the interior back in which made it feel like a car again :)
I also sent away the forms to get the V5 and declare it sorn. I decided to be brave and register the colour as green ...
Here's my daughter (the wee one) and the neighbors kid getting their first seat in the Jimny. My daughter peed on the driver's seat about 4 minutes after I fitted it ...
Last edit: 11 Mar 2019 22:55 by Keirravn.
12 Mar 2019 07:55 #204482 by kirkynut
Replied by kirkynut on topic Re:The Rat Trap
It's coming along now then!
12 Mar 2019 21:23 #204500 by Soeley
Replied by Soeley on topic Re:The Rat Trap
Making good progress there, keep up the good work.
  • Lambert's Avatar
13 Mar 2019 05:36 #204507 by Lambert
Replied by Lambert on topic Re:The Rat Trap
Can I make a suggestion?
Take all the interior back out including the dashboard and fit 4 plastic bucket seats and a roll cage and give your little one the coolest school run car in the catchment?
  • Keirravn
  • Visitor
  • Visitor
13 Mar 2019 14:00 #204522 by Keirravn
Lambert wrote: Can I make a suggestion?
Hmmmmm ...
Better see if it's mot'able before I start with the mods :P
  • Keirravn
  • Visitor
  • Visitor
14 Mar 2019 19:25 - 14 Mar 2019 22:37 #204594 by Keirravn
2 of 4 kingpin bearings replaced today. Don't want to curse it but very pleasantly surprised with the lack of seized nuts and bolts on this thing! (So far).
The calliper pins must be made of a different metal though as they're seized solid. Not a surprise given the state of the outer disc.
I'll come back to that after it's soaked for a few days. If the weather is ok I'll crack on with the other side tomorrow :)
Last edit: 14 Mar 2019 22:37 by Keirravn.
15 Mar 2019 07:24 - 15 Mar 2019 07:26 #204610 by yakuza
Replied by yakuza on topic The Rat Trap
What is with the Re:Re:Re:Re?
I'm 48, I don't understand. :)
Edit: Aha, seems I managed to remove them from the topic :)
Unstuck bolts could be a sign that there have been some servicing done to it..
Last edit: 15 Mar 2019 07:26 by yakuza. Reason: add info
Time to create page: 0.132 seconds
Powered by Kunena Forum
