My green laner project
11 Jul 2018 13:42 #194191
by ahtr
My green laner build
2003 Jimny - M16 engine - 4.16 TC - Winch - Snorkel - 30x9.5 Maxxis MT-764 tyres on 15x7 ET-7 offset wheels - 4" lift - Rear floating axles and discs
My green laner project was created by ahtr
Recently picked up, will be modified primarily for laning but still want it driveable on the road. Plans for 30" tyres, lift and winch initially. May do 1.6 engine swap and lockers further down line.
My second Jimny I've owned, this one will be a keeper so want to do it right.
Picked it up looking like this...
First job was rear lights not working. It had a towbar fitted and the wiring had been hacked to bits. Pulled towbar off and basically remade rear light wiring loom. All working spot on now!
Stripped front and rear bumpers off, wheel arch liners out, spent a few hours pressure washing everywhere while the weather was nice, gave it a couple of days to dry out, cleaned all the metal up and painted. Chassis all got coated with underseal. It's all surprisingly solid. Some light surface rust but no major corrosion. Snorkel fitted while arch liners and air box were out.
Marked up ready for drilling...
Fitted
Front off and painted. Behind back bumper got the same treatment.
Stripped all the seats, carpets and plastics out. Inside floor cleaned, painted before plastics back in.
Fitted Subaru Impreza seats I picked up months ago and had waiting to use, have experienced Jimny seats before and knew they weren't for me. Rear seats being left out and will ply line the rear floor.
Brake pedal was nearly touching the floor and exhaust snapped just in front of cat. Picked up new exhaust and got that on (doesn't sound like a tractor any more). Fitted new discs and pads, will have a rear disc conversion at some point soon but stuck new rear shoes in for now and adjusted up. Fitted extended brake lines at the same time in preparation for a lift and bled everything through.
Bought five 15x7 steel rims with -7 offset ages ago. Had these fitted with 30x9.5 Maxxis MT-764's ready to go on when the lift is fitted
Fitted
- Thank you received: 923
11 Jul 2018 14:34 #194193
Replied by X8GGY on topic My green laner project
Blimey! You don't mess about! Good start!
12 Jul 2018 10:40 #194230
by ahtr
Replied by ahtr on topic My green laner project
Thanks! I bought your diff guards I think?
I've got a plan of where I'm going with it so I've had a stash of parts building up before I even bought the car :whistle:
Oils now changed. Engine oil was looking pretty awful so running some cheap oil through for 50 miles to flush through then changing to some decent stuff.
Gearbox and diff oils done. Had some new diff plugs ready from bigjimny shop, ended up taking last ones out with a chisel.
Started on extended breathers too. Manifold fixed with a couple of rivnuts, hose on left heads up the snorkel.
Diffs tapped and screwed in some 6mm push fit 1/8 BSP 90deg elbows (before I changed the oil, incase any swaft dropped in). Gearbox one nice and simple, pulled off the standard small rubber pipe...
In goes a 6mm push fit adapter
Then back on to gearbox with some 6mm hose into breather manifold
- MadsV
12 Jul 2018 10:45 #194232
by MadsV
Replied by MadsV on topic My green laner project
Nice work, looking forward seeing those wheels on
- OlaGB
12 Jul 2018 11:28 #194235
by OlaGB
Replied by OlaGB on topic My green laner project
Very nice work!
How did the Impreza seats fit? Alot of work?
12 Jul 2018 16:27 #194239
by ahtr
Not too bad, easier than expected. The frames are quite low on them which helped, bit of chopping and a few brackets made up with some 6mm flat bar and 50mm box. Was just a case of offering them up and see what worked.
Time to create page: 0.173 seconds
