16 Nov 2017 16:53 #186329
Replied by Daniel30 on topic Dave's "S200KYS" Jimny 'laner Build...
Happy Bday
The topic has been locked.
16 Nov 2017 19:54 #186334
Replied by Riccy on topic Dave's "S200KYS" Jimny 'laner Build...
Many Happy Returns!
- Thank you received: 923
26 Nov 2017 18:06 - 26 Nov 2017 18:39 #186756
Replied by X8GGY on topic Dave's "S200KYS" Jimny 'laner Build...
Thanks for the birthday messages... now fifty
:lol:
On our latest trip I managed to rip the offside rear shock off it's mounting point on the chassis crossmember -
But completed the trip with it ty-wrapped to the panhard rod...
Today was the day to fix it...
So in the week I tidied all the 'ZookBOB' production equipment out of the way, so that today...
I could squeeze the Jimny into the nice warm garage / man cave to...
...be able to work around, especially have enough room around the back.
The offending mount, the bolt has ripped through it
Referencing the bolts for the centre seat mountings and the roll cage plates...
I could work out where I needed to cut my access hole...
There!
And open up a flap above the mounting.
I then cut the front off the mount where the bolt had ripped itself out
And then cut the sides back...
There!
Last edit: 26 Nov 2017 18:39 by X8GGY.
26 Nov 2017 18:08 - 26 Nov 2017 18:16 #186757
I then set about making a new mount -
From some suitably sized box section...
I then welded a nut on the back and a reinforcing washer on the front, before...
Welding the new mount in place, and then, after painting the top of it...
I removed all the sound-deadening tar with a blow torch and scraper and then wire brushed and sanded ready for...
And then welded the flap back, sanded down the welds and hammerited the patch to protect it...
And then did the same underneath and then reconnected the shock...
Almost done, just need to repack everything back into the rear of the Jimny
Last edit: 26 Nov 2017 18:16 by X8GGY.
- Jimnyshaun
26 Nov 2017 20:18 #186768
by Jimnyshaun
Replied by Jimnyshaun on topic Dave's "S200KYS" Jimny 'laner Build...
funnily enough i had to cut a similar hole in my floor to get my standard shocks off
26 Nov 2017 21:36 #186770
Good work Dave!
that looked like a nightmare to to me, fix but you made it look easy!
I wonder if you have that shock hitting your panhard or panhard mount like i do, which may have contributed to it breaking?
