Your basket is empty.
This is the often forgotten oil seal that sits inside the spindle in the hub.
If you are refurbishing your hub or changing the Front Wheel Bearings then you should consider changing this seal as well.
In the picture below it is ITEM 11, you get ITEMS 16,15 and 14 in the Wheel Bearing Kit.
eCommerce by CubeCart
