Front Wheel Bearing Kit (Koyo)
Tap to enlarge
£42.91
Product Information
Specification
Front Wheel Bearing Set. Consists of a Bearing, oil seals and new large C-Clip and small shaft C-Clip
Contains:
Bearing - Suzuki Equiv. Part No.43462-84A00 or 09267-41001  (This is a genuine Koyo brand bearing, this is as used by Suzuki)
Oil seal - Suzuki Equiv. Part No. 09283-54001
C-Clip - Suzuki Equiv. Part No. 09381-68001
C-Clip - Suzuki Equiv. Part No. 09380-26004
Fits: All Jimnys
DON'T BE FOOLED BY THE £25 KITS THAT ARE AROUND. These contain two taper bearings rather than the single dual race bearing and they appear to be completely wrong and impossible to fit. You can be assured that I would stock these if they fitted as the taper bearings are only £5 each! No-one I know of has been able to make these kits fit properly.
For instructions on how to fit these, look HERE
How to check for fake Koyo bearings
   I only sell genuine bearings  !
The genuine bearings have a label like this, it has a barcode, a QR code and holographic strip. The holographic strip has a Koyo logo in it that turns to iTekt as you move your head. Once you have seen the hologram you can then look up the QR code in the WBA Authenticator App and it will confirm that the bearing is genuine.
Product CodeBJ1530-KOYO
ManufacturerBigJimny
ConditionNew
Weight0.6kg
Products related to this item
Vacuum Hub Tool
Vacuum Hub Tool
£15.00
Customer Reviews
Write a review
Write Review
This field is required.
Top
eCommerce by CubeCart
