Vented brake disc
Note: discs come with two separate centre hole sizes, please ensure you order the correct one.
THIS IS A SINGLE DISC.
THIS IS THE 108.3mm fit disc!
Vehicles up to VIN 203804 require 107mm centre discs
Vehicles from VIN 203804 require 108.3 mm centre discs
Note: If you are converting a Jimny to a vented disk set up then other parts are required!
NOTE: As this is not a standard UK Jimny fitment but is for the vented disk conversion, this is NOT a stock item, allow extra days for delivery
