Armrests (Storage)
Armrests (Storage)
  • Click to enlarge
  • Click to enlarge
5.0 average, based on 4 reviews
Product Information
Specification
VEHICLE FIT
The standard item offered here FITS A UK GENERATION 4 JIMNY out of the box and is finished "Black/Black" as standard (Black vinyl or Black fabric on a black base)
For other vehicles you require a "FREE" adaptor (I swap the adaptor in the box)
Anyone ordering for a different vehicle MUST also order an adaptor from the list below. If you do not order an adaptor you will get the UK GEN4 armrest. Check the adaptor is in stock BEFORE ordering the armrest. Click the links below...
EU Gen 4 adaptor (LHD)
UK Gen 3 adaptor (RHD)
A high quality armrest, directly comparable to OEM systems on many vehicles.
  • STABILITY
    • Equivalent to OEM fit, installs to the seat frame using existing holes and is proven to loads of 75kg or more.
    • Secure steel fittings, no loose wobble or screws into plastic.
    • TÜV-approved with German ABE
  • FLEXIBILITY
    • MLC310 - broad enough for both driver and passenger use
    • Retains use of storage built into transmission tunnel (Cup holders etc.)
    • Simple install with basic tools.
  • USABILITY
    • up to 60degrees of angular adjustment
    • Moves and adjusts as part of the seat so suits all sizes of driver
    • Built in storage
These premium armrests provide the perfect solution for your Suzuki. A version with a built in Qi charger is now available. Please select the option when purchasing (Note: you must check that your phone meets the Qi standard)
SEE MY GEN4 INSTALLATION VIDEO HERE
Built-in Qi charger (Option)
OTHER OPTIONS
These are available across the Suzuki range of vehicles (e.g. Alto, Baleno, Celerio, Ignis, Jimny, Liana, Swift, SX4, Wagon R, Vitara) in many colour and material options
If you want something not immediately listed here then let me know, this is an invitation to talk to me!
Click here to mail me!
SUZUKI DEALERS
These are already fitted by Dealers across the EU, either during new vehicle PDI or retrofitted (about 20-30 minutes work)
If you want to sell these as a Dealer Fit accessory talk to me!
Customers, if you are ordering a new Suzuki and the Dealers say "Armrests are not an option", point your dealer here!
Below are some example future options. I would have to order these in within a larger batch so you would have to be prepared to wait. Pricing will be variable. Use the email button above to discuss.
Suzuki Jimny fitted with ML285 Double Kit in Vinyl (Special Order)
Colour Options (Special Order - Email me)
Product CodeMLC310
ManufacturerBigJimny
ConditionNew
Weight2.1Kg
Customer Reviews
Average Rating: 5
Jimny armrest gen4 black/black
12345
Great quality item, easy to fit and looks great in black vinyl, matches the cab interior. If you watch 'fitting an armrest to a gen4 Jimny', you can see the armrest, when down, protrudes over the hand brake lever, making it awkward to apply the hand brake. Not a problem for me as i only use the armrest on long trips. (15 Sep 2021, 16:56)
Armreast
12345
Brilliant armrest easy to fit ???????? (22 Jul 2020, 18:40)
The best
12345
I have had this kit for quitea a while. To make my review short - it is the best thing on the market !! (7 May 2020, 15:11)
Armrest
12345
Easy to install and perfect fit. Verry happy with it :) (21 Mar 2020, 20:35)
Write a review
Write Review
This field is required.
Top
eCommerce by CubeCart
