Revision as of 14:06, 4 March 2021 by Bosanek (talk | contribs) (Link correction)
Manual or fixed front wheel hub heads
Vacuum operated free-wheeling wheel hub head on a wheel
Vacuum (top) and manual (bottom) free wheeling wheel hub head for a comparison
  • There is luckily an alternative remedy - to eliminate the entire vacuum system and with it all the risks and issues which it imposes.
  • The required modifications are relatively simple to perform, with required parts widely available on the second hand market and/or in the aftermarket.
Elimination of the vacuum system is worth considering in the following scenarios:
  3. If you just want to preventively minimize the risk of a failure (which usually occurs when it is most inconvenient);
  1. Replacing it altogether with manually operated free-wheeling front wheel hub heads;
    • Like in Samurais and other classic 4WD vehicles;
  2. Replacing it altogether with fixed front wheel hub heads;
  3. Converting original vacuum operated free-wheeling front wheel hub heads into fixed hub heads;
All three solutions share many common steps.
To clear any misconceptions:
  • Free wheeling (and fixed) wheel hub heads of any type have no relation to differential lockers or with the action of locking a differential.
  • They also have no relation to reduction gearing, nor with any form of traction control.
  • And they generally don't bring bad nor good luck!
  • On the other hand, if you paint them to look sexy, they might attract some females (depending on the species - wolf, bear, snake, skunk, etc.).
This article certainly appears gargantuan and overwhelming.
It is large because it contains all the solutions for all the situations.
Only some of those will be applicable to your case and desires.
Therefore, only certain parts of this article will actually interest you.
Before hastily embarking on any of the three solutions mentioned above, you might first consider repairing your original vacuum system.
Wheel hub heads / caps are usually just shortened in naming to "hubs", but a "hub" is actually an entire wheel hub assembly - the casing which contains the wheel bearing with its seals, the steering knuckle surround casing, the king pin bearings and (in the case of the Jimny) the pipes and passages which transport the air / vacuum through the wheel hub assembly to/from wheel hub heads.
Quick overview of the solutions
Solution with manually operated hub heads
Manually operated free-wheeling wheel hub head
Advantages
  • Still allows the front drive line to be (dis)engaged at operator's will in order to save on fuel and mechanical wear of the drive line when using the vehicle in 2WD transmission mode.
  • Generally robust and simple mechanical (dis)engagement system with the least amount of components which can fail compared to automatic and vacuum operated systems.
    • In very rare cases when it fails, the cause is easy to detect and fix.
  • Manually operated front wheel hub heads indirectly allow the use of the "2WD-L" transmission mode.
    • Suzuki has not enabled that mode by default in any Jimny.
    • Read the wiki article "2WD-L transmission mode" for all the details.
Disadvantages
  • As most manual free wheeling hub heads have no anti-tamper mechanisms, a malicious person can easily (dis)engage a hub head while the vehicle is parked.
    • This is easily remedied by the driver when detected, but can cause confusion while driving in the meantime.
  • If water enters into a manual free wheeling hub head, it can freeze the manual (un)locking spring mechanism in the hub head during frigid weather.
    • If this happens while the hub head is disengaged, it can prevent the vehicle from using 4WD transmission when it is needed the most.
Solution with fixed wheel hub heads
Fixed wheel hub head on a wheel
  • It is also possible to install fixed wheel hub heads.
Advantages
  • They are usually the most durable type for extremely heavy-duty operation;
Disadvantages
  • Possible sources would be from a SJ413 (Samurai) and from Vitara Mk1 (and possibly from Vitara Mk2 as well?), but it is not known if some additional spacers are required.
  • The only operational disadvantage compared to manually operated free-wheeling wheel hub heads is that you will never be able to disengage the front wheels from the drive line.
    • Nothing will break, but the vehicle will use slightly more fuel in 2WD transmission mode and the front drive line will naturally wear slightly more, since it will be always working as opposed to working only when the transmission is in 4WD mode.
  • "2WD-L transmission mode" can not be used.
Solution with converting original vacuum wheel hub heads into fixed hub heads
  • Jimny's original vacuum-operated front wheel hub heads can be relatively easily modified so that they become fixed (always engaged).
  • The modifications can be accomplished in a few ways.
    • Some are reversible and some are irreversible.
  • The procedure is described in detail further down in this article.
Advantages
  • No new (replacement) fixed hub heads are needed.
    • Therefore zero costs of the conversion!
Disadvantages
  • Front drive line remains always engaged and can not be disengaged any more.
  • Vacuum operated wheel hub heads are generally the least durable for heavy all-terrain duty compared to other hub head types, especially when they are DIY modified.
The entire modification procedure in a neat overview diagram
  • This solution is less expensive of the two solutions with manually operated free wheeling hub heads, but involves more "fiddling" around.
  • The additional required "fiddling" is because the hub heads from earlier Suzuki vehicles do not fit/mate directly on Jimny's wheel hubs.
    • The cause for that is the presence of a special metallic vacuum sealing ring in Jimny's wheel hub assembly.
Resolving incompatibility
  1. By installing a pair of special spacers/adapters (with suitable bolts), which sit between the newly obtained hub heads and the wheel hub assembly.
  2. By undoing the locking hub nut and grinding off the vacuum sealing ring.
  • А: Potentially cheaper, simpler to perform and entirely reversible (possible to return the wheel hub assembly back to the original setup);
  • D: Reduces the length of the spline contact between the wheel hub head and the short drive shaft part of the CV joint.
    • Therefore, method 1 weakens that point in the drive line, making this method less suitable for heavy-duty off road use.
      • (In other words: increased risk of damage to the wheel hub head or to the CV joint).
  • A: Does not reduce the spline contact surface between the wheel hub head and the short drive shaft part of the CV joint.
    • Therefore, the strength of this point in the drive line is preserved.
  • A/D: Requires the purchase and use of a special tool to undo the hub nut.
    • That tool is usually more expensive than the pair of spacers from method 1.
    • However, that tool is also required when changing a front wheel bearing on a Jimny.
      • Therefore, the purchase of this tool might be a good investment anyway for the future.
  • D: More complicated to perform (grinding work).
  • D: The wheel hub assembly will be irreversibly altered, preventing any future use of Jimny's air locking wheel hub heads (if you ever happen to wish to return to them).
Required parts
There are numerous versions and editions of Suzuki SJ 413s, Samurais and Vitaras / Escudos / Sidekicks / Geotrackers in existence.
Figure 01 - SJ manual hub heads
  • A pair of manually operated, second hand hub heads from any Suzuki SJ 413 (Samurai) or from any Suzuki Vitara (Escudo / Sidekick / GeoTracker) Mk1.
Figure 02 - The cone washers from SJ hub head bolts
  • The cones from the SJ / Vitara hub head bolts.
Figure 03a - wheel hub head spacer rings
  • A pair of special wheel hub head spacer rings;
  • Browse the shops like BigJimny, JimnyBits, Bits4Vits, etc. for suitable spacers/adapters (method 1) or for the special tool (method 2).
  • If you decide for method 1, BigJimny sells a suitable kit.
    • In the kit you get two spacer rings and 12 Hex cap bolts.
    • The kit includes replacement bolts as the Jimny and SJ bolts are too long and too short respectively.
  • This picture shows the BigJimny rings (the photo is of the prototype rings painted blue, the shop versions are properly plated):
Figure 04 - SJ and Jimny bolts
  • A set of bolts for securing the wheel hub head to the wheel hub assembly.
  • Suitable bolts should be supplied together with the wheel hub head spacer rings.
Figure 03b - special "hub nut unlock tool"
  • The special tool to undo the wheel hub assembly locking nut.
  • Some kind of a grinding tool is also required.
Installation guide
This guide shows the procedure with incompatibility remedy method 1 applied.
Figure 05 - E10 "Torx" socket
  • First remove both Jimny vacuum hub heads using an E10 Torx socket.
Figure 06 - spacer ring coated with sealant
  • Coat the spacer ring with a thin layer of sealant to keep the water out.
Figure 07 - SJ cone washers on the new bolts
  • Slide the cones from the SJ hubs onto the new bolts.
Figure 08 - Coated bolt with thread locker
  • Now coat the bolts with a thin layer of thread locker.
Figure 09 - removing the SJ hub heads's front plate
  • Mate the hub head to the wheel hub and screw the bolts in by finger as far as possible.
  • You may find that the front of the hub head prevents you from getting at the new bolts.
  • In this case, set the hub head to FREE position and undo the hub head's front plate.
Figure 10 - tightening the bolts
  • Now you should be able to tighten the bolts.
  • Tighten them sequentially in a "star" pattern, like when mounting a wheel.
  • Go around the hub a couple of times to tighten the bolts fully.
Figure 11 - successfully installed manual SJ 413 hub head
  • Now refit the SJ hub head front plate and admire the finished installation.
  • No special tools, spacers, rings, bolts, potions, magic wands, etc. are required.
  • Compared to solution 1a with method 1, it does not reduce the spline contact surface between the wheel hub head and the short drive shaft part of the CV joint.
  • Compared to solution 1a with method 2, the entire installation is completely reversible (it is easily possible to return the wheel hub assembly back to the original setup).
Required parts:
    • These are a direct "bolt-on" replacement (just use original existing bolts)!
Examples of aftermarket brands of tailor-made manual hub heads for Jimnys:
  • AVM, hub head model 457
    • These allegedly exist in two editions - blue (cheaper/weaker) and red (expensive/stronger)
  • Tyre X
  • Various no name
  • Others?
Solution 1c - fixed hub heads
Required parts:
This solution needs additional info from someone who has done this.
Solution 1d - converting existing vacuum hub heads into fixed hub heads
  • Therefore, it is the cheapest of all solutions - zero costs!
  • It just needs some ingenuity and some mechanical (or optionally welding) skills in order to fixate the hub heads.
  • The best of all - this modification is entirely reversible (unless you get angry and weld something).
  • The goal of this solution is to simply forcibly jam the internal (un)locking mechanism of the original vacuum hub head into the "locked" position.
    • This gives the same effect as having a fixed wheel hub head, or as having a manually locking wheel hub head locked all the time.
Beware that, in general case, the strength / robustness of modified (fixated) vacuum hub heads can never match the strength of true fixed hub heads, no matter which method to modify (fixate) them was utilized.
Conversion guide
Figure 01 - demounted original vacuum wheel hub head
  • Here is an original Suzuki vacuum wheel hub head when demounted from a Jimny.
Figure 02 - removing the vacuum seal from the hub head
  • There is a vacuum seal in the hub head that needs levering off.
  • It will not be strictly needed after the "fixation" of the hub head is complete.
  • Therefore, it can be re-used by someone else to repair their genuine Jimny vacuum hub head (if your seal is good and their seal is faulty).
  • In that case, their faulty seal would serve just fine in your fixated hub head, because it will just serve to generally keep most of water and grit out.
Figure 03 - pulling out the gearing
  • Then pull out this gearing ...
Figure 04 - throwing out the center bits
  • Turn the hub head upside down and the center bits should come out.
  • It might need a sharp tap on the bench.
Figure 05 - splitting the castings
  • The center is made of two alloy castings.
  • The two castings are pressed together with the hollow inner splined shaft within them, that pushes in and out.
  • It is this hollow splined shaft that, when pushed out, slides into the geared ring, which in turn sits inside the geared part of the casing, that bolts to the hub of the car.
  • The splined end of the CV joint slides inside the hollow splined shaft.
  • When all is linked like this, the drive force can be transmitted from the transmission to the wheel.
  • Carefully split the two castings from each other, as shown in the picture.
Figure 06 - a surprise spring inside
  • Be ready when the top casting comes off, as there's a large spring inside!
Figure 07 - the inside spring from another angle of view
Figure 08 - a suitable old rubber bush from a bin
  • An old rubber bush was then placed under the spring.
  • This will stop the hollow splined shaft being allowed back, which would otherwise make the hub head "freewheel".
  • You can use other objects as a jamming spacer.
  • However, the jamming spacer object must not be more than 10 mm thick.
  • Otherwise, the splines between the geared ring and the casting will not mesh enough.
  • This increases the risk of damaging them when significant drive force is applied.
Figure 09 - bush spacer in place
Figure 10 - bush spacer in the assembly
  • Since now everything has been taken apart, it is a good moment to clean all the bits and re-grease the gears and the spline shafts lightly.
Figure 11 - joining the two castings together
  • Then tap the castings together, ensuring that the three holes on the casting that holds the spring and new spacer line up with the three slots on the inner part.
  • It just won't go back together otherwise, so don't overlook this.
Figure 12 - putting the center bits back inside
  • Then slide the whole lot inside the casing, noting the three slots inside the casing that the three lugs from the casting slide into.
Figure 13 - placing the geared ring back in
  • Drop the geared ring back in.
  • Make sure that its outer gears mesh well with the teeth inside the casing.
  • This is why I cut the spacer (old rubber bush) down to 10 mm, as my gear assembly did not sit too well inside with a thicker bush.
  • When bolted to the car with a thicker bush, the assembly would probably be pushed together OK, as the spacer is rubber and the bolts that bolt the freewheeling hub to the car would draw them together (squeezing the spacer).
  • But this is only an assumption!
  • That is why it is best to play safe with a 10 mm spacer thickness.
Figure 14 - putting the seal back in
  • Optional step: push the seal back in with the gasket on top.
  • You don't strictly need this seal anymore.
  • However, it is still recommended to put it back in, because it also prevents the mud and grit entering the wheel hub head.
Additional notes on spacer solutions
Figure 15 - a bolt acting as a spacer instead of a bush
  • In this conversion guide I chose to use an old cut down rubber bush as the jamming spacer.
  • This will be light to not cause issues such as Death Wobble and can compress if it's too big when all bolted up.
  • However, another option for a spacer could be a bolt from the outside of the casting like in this picture.
Figure 16 - issues with the bolt head
  • However, you would have to cut the bolt down to ensure it only spaces by 10 mm inside the casting (reasons explained earlier in the guide).
  • Also, the bolt head will undoubtedly be too tall for the recess, like in this picture.
  • Therefore, the bolt head would need grinding down, to prevent it hitting on the outer casing, stopping the whole lot going back together.
The summary of the choices:
  • A bolt will obviously not compress like rubber.
  • A bolt should last forever.
  • A bolt might rattle in the assembly during use, since it is made of metal, is relatively heavy and can hardly be properly centered.
    • This might create noise or even worse - induce Death Wobble.
  • On the other hand, rubber might wear out, crumble or flatten over time (depending on material).
  • Another potential alternative might be to use a plastic or a polyurethane spacer.
  • Those two materials should be much more durable than rubber, without the issues associated with metallic bolts.
  • So, it comes to your decision on which type of spacer to use.
  • Instead of using spacers to hold the hub head stuck in locked position, you could alternatively weld the internal hub head parts together so that they always stay locked.
  • This method of fixation is not covered here.
    • Reasons:
      1. Тhere are several opinions on the question of which internal hub head parts are best suited for welding and how;
      2. The resulting durability of the welded assembly would highly depend on welder's skills;
Required tools
Required tools for any of these four solutions are:
Practical notes
Reasons
  • It will NOT be possible to shift between 2WD<->4WD-H transmission modes, as the 4WD controller electromagnetically operates the (dis)engagement mechanisms in the transfer box after your push-button invocation.
Possible solutions
  2. At the valves in the engine bay - disconnecting the pipes from the valves and then blocking both the pipes and the valves.
Disadvantages and constraints
  • Vacuum metering valve;
  • The check valve;
  • It is advised to first simulate the removal of the vacuum system elements by disconnecting all the wires from all vacuum valves, switches, tanks etc. and by blocking the vacuum pipe coming from the engine.
  • Then perform solution 3a or 3b below.
  • If it is all right in the end, then truly and physically remove all vacuum system elements.
  • This way you can easily return everything back if the simulation test shows that the end results of the modification are not behaving as planned.
This is the best solution!
  • Reason for the short circuit:
    • This valve used to short-circuit this connector whenever it sensed a successful vacuum formation.
    • By permanently shorting the wires, the 4WD controller will always believe that the vacuum system is working fine.
    • A permanent short circuit condition should not harm it (theoretically).
  • This will "free" the vehicle of all electronic / smart / modern / vulnerable elements of the 4WD transmission system.
    • It will be as classic as a Willys Jeep.
Suzuki Jimny 4WD controller module (<'05)
4WD module location (in LHD vehicle)
A coupler setup with the green 4WD light re-enabled after 4WD module removal
Disclaimer
  • Theoretically, if you have an ABS-equipped vehicle, and you unplug the module and connect blue/black and blue cables, the ABS controller should receive exactly the same reading as before.
    • It is the same blue cable, it gets the same nominal 13V current.
Final words
  1. Print out the main diagram from this article;
  2. Draw a desired "path of conversion" on that diagram (based on your vehicle edition and chosen solutions);
  3. Concentrate only on that path (chain of chosen solutions) when following this article through the next read.
And then finally comes the fun part - dislocating your butt from the armchair and actually performing this.
Useful forum discussions
The following forum discussions contain some useful info:
