The purpose of this article is to list various equipment and tools which can be useful to carry in a Jimny, depending on particular situation and trip.
Most of these items are non-Jimny specific and can apply to any vehicle, while only some items are Jimny specific.
Equipment and tools
- First aid kit;
- Also a knowledge on how to use it;
- Knowledge of your blood type;
- Fire extinguisher;
- 2 kg size much more useful than 1 kg size;
- OBD2 code reader and compatible software;
- 2-way radio receiver/transmitter (with charged batteries);
- Check that it is compatible with the local amateur radio communications frequencies and standards;
- Deep E11 female torx socket and a compatible wrench;
- For unbolting OEM front vacuum wheel hub heads;
- Pair of working manual front wheel hub heads;
- Including spacer rings if needed;
- 19 mm hex socket and a compatible heavy-duty long bar;
- For unbolting road wheel nuts;
- 3/4" connection between the socket and the bar is preferred over a 1/2" connection (for extra strength);
- 2T or 3T hydraulic bottle jack;
- Wide wooden block to serve as an additional base for the bottle jack;
- It has two uses - to increase jack's floatability on soft ground, and to increase the maximum jacking height;
- Tow strap;
- Long crow bar;
- At least 80 cm long;
- Two foldable shovels / spades;
- Waffle board;
- Bag of sand;
- Axe;
- Hand wood saw;
- Small hand metal saw;
- Useful for cutting down lockers on road ramps, fences and gates;
- Set of hand tools (two types of pliers, french key, combination knife, etc.);
- Set consisting of a small 1/4" ratchet, sockets and various bits (minus, plus, star, male hex, etc.);
- Heavy duty waterproof hand gloves;
- Lightweight hand gloves;
- Garbage bags;
- Foil blanket;
- Picnic blanket;
- Miniature foldable picnic chairs;
- Rain poncho;
- Umbrella;
- Paper towels and wet wipes;
- Bungee fasteners;
- Vehicle "jump starting" cables;
- Tyre air compressor, 12 V DC;
- Tyre air deflator tool;
- Tyre valve core removal tool;
- Tyre air pressure measurement tool;
- Tyre puncture repair kit;
- Electrical insulation tape;
- Duct tape;
- Cable ties;
- Set of matches;
- Flint stone;
- Vacuumed dry fruit;
- Bottled water;
- "Power" candy food;
- Air activated hand/feet warmers;
- LED torch;
- Compass;
- Knee-deep rubber boots (used by miners, fishermen, etc.);
- Anti-Diarrhea pills;
- Anti-fever pills;
- Cyanide pills;
- Useful when being hopelessly stuck or broken down in a remote area with no chance of survival;
- Miniature holy book;
- World-wide assortment of amulets and talismans;
- Cash for bribing police patrols;
- Pack of condoms;
- Geiger counter;
- Land mine / metal detector;
- Pepper spray;
- Knuckle breaker fist tool;
- Baseball bat;
- Bayonette or combat knife;
- Pistol with a loaded full ammo magazine;
- Sawed off shotgun with a pack of ammo;
- A regular shotgun is too long to fit inside Jimny's cabin ...
- Box of hand grenades;
- Bullet proof vest;
- Helmet;
If the vehicle has properly rated heavy duty off-road recovery points and lifting points, then add these to the list:
- Snatch strap or kinetic energy recovery rope (KERR);
- Minimum breaking strength (MBT) preferably between 3T and 6T;
- Omega shackles or soft shackles;
- Working load limit (WLL) of at least 3T;
- Rope recoil surpressors (or heavy blankets);
- High lift jack;
If the vehicle has a high mounted engine air intake snorkel installed and if you intend to drive through very deep water:
- Face breathing snorkel;
- Captain's license for sailing marine vessels;
- Life jacket;
- Sailor's hat;
- Sailor's tobacco smoking pipe;
- One black eye patch;
- Shoulder mounted parrot with foul language behavior;
