Revision as of 15:51, 11 May 2016 by Mlines (talk | contribs) (Created page with "=== Differential === {| class="wikitable" vertical-align:top; !Item !Torque Nm !Torque lb-ft |- |Diff Drain Plug |27 Nm |19.5 lb-ft |- |Diff Filler Plug |50 Nm |36.5 lb-ft |...")
Torque
Differential
Item Torque Nm Torque lb-ft
Diff Drain Plug 27 Nm 19.5 lb-ft
Diff Filler Plug 50 Nm 36.5 lb-ft
Prop Shaft Flange Bolts 50 Nm 36.5 lb-ft
Bevel Gear Bolts 85 Nm 61.5 lb-ft
Bearing Cap Bolts (front) 50 Nm 36.5 lb-ft
Bearing Cap Bolts (rear) 85 Nm 61.5 lb-ft
Lock Plate Bolts 11.5 Nm 8.5 lb-ft
Front and Rear carrier bolts 23 Nm 17 lb-ft
Gear Thrust Bolt (front) 1.5 Nm 0.1 lb-ft
Gear Thrust Bolt (rear) 85 Nm 61.5 lb-ft
