Typical weak points
- Boot / trunk floor
- Below the rear seats
- Inner wheel arches
- Bodywork behind front driving lights
Body carriers on the chassis
This chassis rail is severely weakened
This is a critical structural failure, and prevents the vehicle to be licensed for road use
Area behind the head lamps
View from the front, after the head lamp is removed
View from the back, after the front wheel inner arch liner is removed
View from the front
After sealing the seams and painting
View from the back
Front right floor section, roughly where right front passenger's right foot stands. Vibrodamping bitumen sheets had been removed prior to taking this picture.
Floor below the rear seat bench, with bitumen vibration damping compound removed
Severely rusted boot floor. Someone desperately applied wax to save it - too late and from the wrong side!
Properly and thoroughly rusted rear floor - the boot floor has already been cut off
- Salvage efforts on a thoroughly rotten rear floor section
Weld after weld after weld after weld
Notice that the entire boot floor has been replaced with a flat sheet
A lot of space has been lost by using a flat boot floor sheet
Painting then seam sealing
Close-up after work is done (note: vibrodamping materials are now missing)
General idea
- Bitumen based (the oldest and cheapest type);
- Waxes;
- Polyurethanes;
Separating body and the frame
- The only effective way to remove elastic compounds is to heat them up and manually scrape them off.
- For example: automotive wax, bitumen-alike coating, plastic-alike coating (not recommended for outdoor applications), or polyurethane ("bed-liner") coating, etc.
General description
"Enhancing" the method
Importance of existing rust removal
- Rust is like cancer.
- A standard method of rust removal is by using manual or powered wire brushes (attached to drills, grinders, etc.).
- A much more thorough rust removal can be accomplished only with sand blasting.
- Whichever mechanical rust removal procedure is performed, the treated surfaces should then be "painted" over or sprayed over with some rust treatment (elimination) chemical.
- Its job is to kill the last tiny thin remains of rust which might have stayed in some pores or scratches after the mechanical removal has been performed.
- The best chemicals for this job are the ones which chemically alter (transform) the rust into another non-ferrous material (making it impotent).
- These chemicals are much more expensive than ordinary "rust melting / elimination" chemicals.
- Prices are usually about 20-40 EUR per liter, but they are well worth it.
- An example manufacturer of these chemicals is Wurth from Germany.
- A rust treatment chemical usually needs some time (counted in hours) to do its job.
- Some of these chemicals require grinding them off after they harden off, while others allow further coating applications like it's a bare metal.
- Note that these chemicals do not seal the ruface against future rusting!
Timing and weather protection
- For example, if you sand blast a metal surface, and then load it onto a trailer to be taken somewhere else for the next phase, if it's a cloudy day with high humidity (let alone rainy day!), the metal will quickly develop rust flecks on the way to the next station.
- It is also important to obey manufacturer's curing times for each used chemical product.
- It is for this reason important to carefully observe and plan when buying various chemical products, because some products' overly quick or overly slow curing times can complicate your working schedule and timing.
- This means that you need to apply final coating(s) of your choice (which need to be airtight) as soon as the primer paint dries off.
- A lot of people leave the project for a while (maybe to take a rest) after the application of a primer paint, thinking that they have covered the bare metal and how the main "rust shield" is on, but it probably isn't!
- Thoroughly wash the underbody with soapy water or some other dirt and grease removing chemical, and then thoroughly rinse it with clean water.
- Clean and degrease the entire underbody with cleaners/degreasers.
- Chemically eliminate the last traces of rust on the areas where you mechanically removed rust.
- Use rust elminating acids or even better rust converter/inhibitor chemicals.
- Rust converters/inhibitors work on the principle of chemically altering the rust itself, "freezing" it or chemically converting it into another substance.
- Apply anti-corrosive primer paint on all bare metal surfaces.
- It is best to use epoxy anti-corrosive primers.
- Apply seam sealant to all previously rust-treated areas which were welded or where two metal parts/panels join together.
- It is best to use polyurethane seam sealant.
- Apply a stonechip coating of your choice (bitumen-based, polyurethane, etc.) to the entire underbody.
- Apply wax over the stonechip coating.
- Apply wax in all cavities (inside the chassis rails, inside door sills, inside doors, inside anything that is hollow.
- Take a vacation.
Final notes
- Be prepared to pay more for a thorough job execution though!
Unsorted quick tips
This chapter contains some new quick tips which were added in a haste and thus there was no time to properly incorporate them into the chapter(s).
- Read more here.
Additional reading
Page last edited on 27/08/2019 by user Bosanek
