Revision as of 16:44, 20 August 2019 by Gadget (talk | contribs)
Door open buzzer
4th generation Jimnys sound an audible warning tone when the key is in the ignition and a door is ajar. This warning tone can become annoying when working on the vehicle, but can be silenced by disconnecting one plug in the steering column.
Tools needed
  • #2 Philips screwdriver
  • electrical insulation tape
Procedure
To remove the steering column trim:
  • Underneath the steering column, locate the single retaining screw (in the deeply recessed hole adjacent to the steering wheel heigh adjustment lever).
  • Remove this screw using a #2 Philips screwdriver.
  • Release the steering while height adjustment lever (this provides clearance to remove the lower half of the steering column trim.
  • The steering column trim lower is secured to the upper with plastic clips on each side.
  • To release, push the lower half of the trim inwards and pull downwards.
  • The photo below shows the exposed clips.
  • Having released the clips on each side, remove the lower half of the trim, carefully pulling over the ignition key barrel and steering wheel adjustment lever.
  • Disconnect the two pin plug shown above from the indicated socket by depressing the catch on the far side of the plug and pulling towards the engine bay.
  • Cover the end of the plug in electrical insulation tape to prevent any possible short circuit and tape the plug to a suitable location to prevent it rattling.
  • Replace the steering column trim by reversing the steps above.
