Sound system (speakers)
Revision as of 13:26, 11 July 2019 by Bosanek (talk | contribs) (Minor phrase correction)
Note Icon.pngThis article is just an embryo. It is an idea for someone to "pick up" onto and to expand the article further.
Jimny has only two weak and dull front speakers.
However, it has pre-machined space for a pair of rear speakers as well, as well as part of the wiring for them installed from the factory.
If you replace the front speakers with something good, and install a pair of good rear speakers, you will get a significantly improved sound (nothing "boombastic", just solid and proper).
Solutions
Links:
Recommended additional works
While you are having the rear interior of the car dismantled in order to install the rear speakers, you might use the opportunity to perform some additional modifications along the way:
References
Until this article gets properly written, gather some more knowledge at the following forum topics:
Page last edited on 11/07/2019 by user Bosanek
