- If your vehicle already has front fog lamps (in the front bumper) installed from the factory, you don't need to read this article.
- Enjoy life instead.
- As far as it is known, all Jimnys 4 have front fog lamps fitted as standard equipment.
- Therefore, this article contains instructions on retrofitting fog lamps only for Jimnys 3.
Required parts
Main notes:
- A pair of fog lamps;
- Exception is if you have the newest (3rd gen.) front bumper revision - it has integrated brackets.
- Possibly some more electrics like a relay, a fuse etc.);
- This part has not yet been investigated.
You will have to cut out plastic blanks in the fog lamp openings in the front bumper. That operation is irreversible. You could glue the blanks back if you abandon the project, but it will hardly look virgin again. Therefore, it is recommended to obtain all the required parts (especially the electrics), and test-wire everything first before you finally cut the bumper and mount the lamps.
Parts compatibility
Complete retrofit sets
For Jimnys 3 type 1-5 (with 1st gen. front bumper):
- P.N. 99000-990YZ-011;
- This is the oldest upgrade set ever offered.
- This set contains the same parts which were originally used for 1st gen. front bumpers as a factory installation.
- It is compatible with Jimnys 3 type 1-4, but not with type 5.
- Type 5 is a "transitional" production edition from 2005 with 1st gen. front bumper but with 2nd gen. interior and electric 4WD controls.
- This complete upgrade set might not be available from Suzuki anymore, because they usually offer a "revised" set for 1st gen. front bumpers (see the next set below).
- If the complete set is not available, perhaps some individual parts might be, or you could scavenge the entire set from a dead Jimny 3.
- This set includes:
- A pair of fog lamps model 35500-74F50;
- A pair of mounting brackets model 35526-81A01;
- Fog lamp surrounding bezels model 99000-990YZ-B03 (for left side) and 99000-990YZ-B04 (for right side);
- These are used for "flush" fitting of the fog lamps into the holes in the front bumper;
- Wiring harness for the engine bay (connection to the fog lamps), OEM P.N. 99000-990YZ-A05;
- Includes a fuse;
- Wiring harness for the cabin console (connection to the in-cabin button / switch), OEM P.N. 99000-990YZ-A06;
- Relay P.N. 99000-990YZ-A07;
- In-cabin button / switch P.N. 37270-75F10;
- Various small bits (screws, nuts, bolts, clamps, ties, etc).
- P.N. 99000-990YZ-035;
- This appears to be a newer "revised" set which replaced the previous set described above.
- Suzuki's OEM accessory catalogues as old as 2006 already offer only this set for Jimnys 3 type 1-4 with 1st. gen front bumper, and have no mention of the previous set described above.
- According to a report from a German forum, the set contains a pair of front fog lamps, a pair of brackets, a pair of bezels for flush fitting in the holes in the front bumper, one in-cabin switch, wiring, fuse and some screws.
- According to the pictures from the same report, this set appears to contain a much newer front fog lamp model 35500-63J04 (usually used on 2nd and 3rd gen. front bumper) and a special bracket (P.N. 35566-81A30 for left side and 35526-81A30 for right side) to mount it to a 1st gen. front bumper.
- The reason for the inclusion of the bezels for the front bumper is that the included fog lamps do not fit "flush" in the holes of a 1st gen. front bumper (they were not originally designed for it), so the bezels correct that.
- For diesel type 4 vehicles (with 48 kW engine and mechanically operated 4WD transmission), the following are additionally required:
- P.N. 990E0-76J10-000;
- It is assumed (but not verified!) that this set contains a pair of front fog lamps, a pair of brackets, a pair of bezels, one in-cabin switch, wiring, relay, fuse and some screws.
- It is assumed (but not verified!) that the included fog lamp model is 35500-63J04.
- It is assumed that the lamps, brackets and bezels in this set are the same as in the set 99000-990YZ-035, but that the wiring is different.
For Jimnys 3 type 6-8 (with 2nd gen. front bumper):
- P.N. 990E0-84A02-000;
- It is assumed (but not verified!) that this set contains a pair of front fog lamps, a pair of brackets, one in-cabin switch, wiring, relay, fuse and some screws.
For Jimnys 3 type 9-12, (with 3rd gen. front bumper):
- P.N. 990E0-57M51-000;
- It is assumed (but not verified!) that this set contains exactly the same parts as the set 990E0-84A02-000, with the exclusion of the pair of fog lamp mounting brackets.
- This is because 3rd gen. front bumper has integrated front fog lamp brackets;
"Fog lamp + bracket" combos
- Fog lamp model 35500-74F50 and bracket model 35526-81A01 are available in a combo set P.N. 99000-990YZ-B01 (for the left side) and 99000-990YZ-B02 (for the right side).
- It is not known why there are two differently named sets (specifically for each side), since both the contained fog lamp and bracket models fit any side equally.
- Perhaps it could be that the fog lamp surrounding bezels model 99000-990YZ-B03 (for left side) and 99000-990YZ-B04 (for right side) are also included respectively (but this is not verified!);
Separate parts
- However, not each part (lamp, bracket, etc.) is mutually compatible nor compatible with each front bumper generation.
- In short, there are:
- Two different fog lamp models;
- One of those models has three slightly different "sub-models";
- Three different lamp bracket / carrier models;
- Two different lamp surrounding bezel models;
- Probably three different wiring setups (with two different connector shapes);
- One available wiring connector adapter at the "fog lamp to wiring" connection point (for one particular setup combination);
- One in-cabin console switch model;
For Jimny 3 types 1-5, with 1st gen. front bumper
Lamp | Bracket left side |
Bracket right side |
Bezel left side |
Bezel right side |
El. connector adapter |
Comment |
35500-74F50 | 35526-81A01 | 35526-81A01 | None required | None required | None required | Standard setup |
35500-63J00 35500-63J02 35500-63J04 |
35566-81A30 | 35526-81A30 | Required P.N. unknown |
36813-54G20 | "Improved" (more complicated) setup |
For Jimny 3 types 6-8, with 2nd gen. front bumper
Bezel left side |
Bezel right side |
Comment |
35500-74F50 | Not produced | Not produced | Not produced | Not produced | Not produced | Infeasible setup unless custom brackets are made and el. connections are soldered |
For Jimny 3 types 9-12, with 3rd gen. front bumper
Bezel left side |
Bezel right side |
Comment |
Notes on lamps
- As evident from the tables above, both the 2nd gen. and the 3rd gen. front bumper use the same fog lamps.
- Those fog lamps can also be used in the 1st. gen front bumper with certain adapters, since that front bumper model has its own different "default" fog lamp model.
- The following three fog lamp models appear to have exactly the same dimensions, shape, bulb, el. connector and mounting points to the brackets:
- The actual differences between these three fog lamp models are unknown - possibly beam pattern or clear / ribbed glass?
- Front fog lamp P.N. 35500-74F50 with bracket P.N. 35526-81A01, taken from 1st gen. front bumper
- Suzuki Jimny - OEM accessory 35500-74F50 - fog lamp, front (with bracket), for 1st gen. front bumper - A01.jpg
Front view
- Suzuki Jimny - OEM accessory 35500-74F50 - fog lamp, front (with bracket), for 1st gen. front bumper - A02.jpg
Rear view
- Front fog lamp P.N. 35500-63J04 with brackets 35566-84A00 and 35526-84A00, taken from 2nd gen. front bumper
- Suzuki Jimny - OEM accessory 35500-63J04 - fog lamp, front (with bracket), for 2nd and 3rd gen front bumper - A01.jpg
- Brackets / carriers are required for mounting any fog lamp model to 1st and 2nd gen. front bumper.
- The 3rd gen. front bumper already has fog lamp brackets as its integral part.
- 3rd gen. front bumper - view from inside - enlarge the pictures and note the screw holes in the integrated front fog lamp brackets, to which the fog lamps directly attach
- Suzuki Jimny - front bumper, 3rd gen - focus on integrated front fog lamp brackets - A01.jpg
Left part
- Suzuki Jimny - front bumper, 3rd gen - focus on integrated front fog lamp brackets - A02.jpg
Right part
- In some combinations (as indicated in the tables above), surrounding bezels are required to achieve nice "flush" fitting of lamps inside the bumper holes.
- 3rd gen. front bumper already comes with a pair of "blank" bezels attached in the place of fog lamps.
- The "proper" bezels look exactly like the "blank" bezels, but only with a pre-cut hole for the fog lamps.
- Therefore, in theory, there is no need to buy "proper" bezels for retrofitting fog lamps to a 3rd gen. front bumper, as it should be (in theory) possible to carefully cut suitable holes for the fog lamps in the default "blank" bezels which are already present in the bumper, and achieve exactly the same look and finish.
- The P.N. of bezels, which are required for flush fitting of fog lamp models 35500-63J0X in the holes in the 1st. gen front bumper, is currently unknown.
Wiring
- Some Jimnys 3, which were produced without front fog lamps, still have all the required wiring (cables, connectors, relays, fuses, etc.) for them already installed.
- Therefore, you should first check for the presence of wires with unused el. connectors in the vehicle.
- For the connection for the fog lamps, first check in the engine bay, just behind the head lamps (usually front left).
- If not found there, then check somewhere behind the front bumper (after removing the front inner wheel arch liners).
- For the connection to the console button / switch, check inside the console in the cabin (see the chapter about the installation of the console button / switch).
- If you find both unused el. connectors (for the fog lamps and for the in-cabin switch) in your Jimny 3, consider yourself lucky.
- In that case, you then only need to connect the in-cabin switch to the unused connector and mount the fog lamps with brackets to the front bumper and connect them to the unused el. connector.
- If you find no unused wires and connectors in the vehicle, you will also need to obtain suitable wiring harness kit(s).
- You can also buy one of complete fog lamp retrofit kits mentioned earlier in the article.
- That way you will eliminate any risk of missing any of needed components.
- The wiring harness kits appear to be separate for the fog lamps and for the in-cabin switch.
- The wiring harness kit in the engine bay for the fog lamps is P.N. 99000-990YZ-A05.
- This kit also includes a 15A in-line fuse and a plug to the relay, but not the relay itself.
- It is currently not known if this kit is compatible with every Jimny 3 revision and every fog lamp model used!
- However, it is known to be compatible with Jimnys type 1-4 and fog lamps model 35500-74F50.
- The wiring harness kit in the console for the in-cabin switch is P.N. 99000-990YZ-A06.
- It is currently not known if this kit is compatible with every Jimny 3 revision!
- However, it is known to be compatible with Jimnys type 1-4 (with old style interior console).
- The relay is P.N. 99000-990YZ-A07.
- There are two types of wiring connectors for front fog lamps in Jimnys 3.
- The first connector type was used in all Jimnys 3 type 1-5 (which originally came with 1st gen. front bumper, from 1998 to approx 2005).
- Other fog lamp models can be connected to it through a suitable connector adapter 36813-54G20.
- The second connector type was used in all Jimnys 3 type 6-12 (which originally came with 2nd and 3rd gen. front bumper, from approx 2005 to 2018).
- This connector is directly compatible with all fog lamp models 35500-63J0X.
- It is incompatible with front fog lamp model 35500-74F50 (which was not meant for 2nd and 3rd gen bumpers anyway, since no brackets for that combination are available).
- However, a required el. connection could probably be made by cutting the connectors off and soldering the wires directly.
- Regarding the wiring in general, refer to a corresponding wiring diagram manual for your vehicle revision (and for donor's vehicle revision if needed).
Console button / switch
Main info
- The OEM P.N. is 37270-76J00.
- The in-cabin console switch is the same in all Jimnys 3.
- This includes both pre-2006 Jimnys 3 (with the older console version), and post-2005 Jimnys 3 (with the newer console version).
- In-cabin front fog lamp switch from a Jimny 3
- Test if the switch works.
Page last edited on 10/06/2019 by user Bosanek
