{embryo-note}}
The purpose of this article is to list various equipment and tools which can be useful to carry in a Jimny, depending on particular situation and trip.
Most of these items are non-Jimny specific and can apply to any vehicle, while only some items are Jimny specific.
Equipment and tools
- Deep E11 female torx socket and a compatible wrench (for unbolting OEM front vacuum wheel hub heads);
- Pair of working manual front wheel hub heads (including spacer rings if needed);
- 19 mm hex socket and a compatible heavy-duty long bar (for unbolting wheel nuts)
- 3/4" connection between the socket and the bar is preferred over a 1/2" connection (for extra strength);
- 3T hydraulic bottle jack;
- Wide wooden block to serve as an additional base for the bottle jack;
- It has two uses - to increase jack's floatability on soft ground, and to increase the maximum jacking height;
- Long crow bar (at least 80 cm long);
- Axe;
- Hand wood saw;
- Small hand metal saw;
- Useful for cutting down lockers on road ramps, fences and gates;
- Set of hand tools (two types of pliers, french key, combination knife, etc.);
- Set consisting of a small 1/4" ratchet, sockets and various bits (minus, plus, star, male hex, etc.);
- Heavy duty waterproof hand gloves
- Lightweight hand gloves;
- Garbage bags;
- Vehicle "jump starting" cables;
- Tyre air compressor, 12 V DC;
- Tyre air deflator tool;
- Tyre valve core removal tool;
- Tyre air pressure measurement tool;
- Tyre puncture repair kit;
- Duct tape;
- Set of matches;
- Flint stone;
- Vacuumed dry fruit;
- Bottled water;
- "Power" candy food;
- Air activated hand/feet warmers;
- LED torch;
- Knee-deep rubber boots (used by miners, fishermen, etc.);
- Anti-Diarrhea pills;
- Anti-fever pills;
- Miniature holy book;
- Cash for bribing police patrols;
- Pack of condoms;
- Pepper spray;
- Knuckle breaker fist tool;
- Bayonette or combat knife;
- Pistol with a loaded full ammo magazine;
- Sawed off shotgun with a pack of ammo;
