Drive Belts
This section covers the engine drive belts, their configurations and adjustment. The Jimny has an Auxillary Belt (Fan Belt) and a Power Steering Belt.
G13BB with Power Steering
- PAS: Adjust mid point of belt between Pump and Crank (lower belt section) to 6 – 9 mm (0.24 – 0.35 in.) of flex by adjusting tensioner
G13BB with Power Steering and Aircon
- PAS: Adjust horizontal (TOP) of belt to 3 – 4 mm (0.12 – 0.16 in.) of flex by adjusting tensioner
M13AA with Power Steering
- Auxillary Belt - known part number for some models 95141-50F01 (4PK835)
- PS Belt - known part numbers for some models 17521-84H00 (4PK950) (2007 VVT) or 17521-52E00 (4PK850) (2005 VVT)
- PAS:Adjust mid point of belt between Pump and Crank (lower belt section) to 6 – 9 mm (0.24 – 0.35 in.) of flex by adjusting tensioner
M13AA with Power Steering and Aircon
- PAS: Adjust horizontal (bottom) of belt to 6 – 9 mm (0.24 – 0.35 in.) of flex by adjusting tensioner
M13AA with Aircon
- PAS+Aircon Belt - known part number for some models 17521-52E00 (4PK950)
- Aircon: Adjust horizontal (bottom) of belt to 6 – 9 mm (0.24 – 0.35 in.) of flex by adjusting tensioner
Tensioners
This section covers the Tensioners.
There basically two types of tensioner. One with a small centre and one with a large centre. The small ones are more common on the G13B engines and the large centre ones tend to be on the M13A series engines.
Small hole tensioner
This is Suzuki part number 49160-82A00 . If the bearing has worn then it can be replaced by pressing the old bearing out. A suitable bearing is available in the BigJimny Shop HERE
Large hole tensioner
This is Suzuki part number 49160-81A00 . This tensioner is commonly called a "smilely tensioner" because of the appearance.If the bearing has worn then it can be replaced by pressing the old bearing out of the outer rim and pressing the smilely centre out. A suitable bearing is available in the BigJimny Shop HERE
Page last edited on 2/09/2016 by user Mlines
