Jump to navigation
		Jump to search
General idea
Areas of Jimny which are most susceptible to rust:
- Boot / trunk floor
 - Below the rear seats
 - Inner wheel arches
 - Bodywork behind front driving lights
- Bitumen based (the oldest and cheapest type);
 - Waxes;
 - Polyurethanes;
Separating body and the frame
- The only effective way to remove elastic compounds is to heat them up and manually scrape them off.
- For example: automotive wax, bitumen-alike coating, plastic-alike coating (not recommended for outdoor applications), or polyurethane ("bed-liner") coating, etc.
General description
"Enhancing" the method
- The limited accessibility issue of the ordinary method can be significantly reduced by undoing all 8 bolts which secure the body to the frame and then slightly temporarily jacking up the body.
- It is known that 2" (5 cm) body lifts are trivial to install to a Jimny, as they don't require extending brake lines, vacuum pipes, etc.
 - It has been confirmed that the body can be temporarily jacked up to 4" (10 cm) from the frame just if you disconnect the brake lines from the frame (not from the wheels!).
Importance of existing rust removal
 - Rust is like cancer.
 - A standard method of rust removal is by using manual or powered wire brushes (attached to drills, grinders, etc.).
 - A much more thorough rust removal can be accomplished only with sand blasting.
 - Whichever mechanical rust removal procedure is performed, the treated surfaces should then be "painted" over or sprayed over with some rust treatment (elimination) chemical.
- Its job is to kill the last tiny thin remains of rust which might have stayed in some pores or scratches after the mechanical removal has been performed.
 - The best chemicals for this job are the ones which chemically alter (transform) the rust into another non-ferrous material (making it impotent).
- These chemicals are much more expensive than ordinary "rust melting / elimination" chemicals.
 - Prices are usually about 20-40 EUR per liter, but they are well worth it.
 - An example manufacturer of these chemicals is Wurth from Germany.
 - A rust treatment chemical usually needs some time (counted in hours) to do its job.
 - Some of these chemicals require grinding them off after they harden off, while others allow further coating applications like it's a bare metal.
 - Note that these chemicals do not seal the ruface against future rusting!
Timing and weather protection
 - For example, if you sand blast a metal surface, and then load it onto a trailer to be taken somewhere else for the next phase, if it's a cloudy day with high humidity (let alone rainy day!), the metal will quickly develop rust flecks on the way to the next station.
 - It is also important to obey manufacturer's curing times for each used chemical product.
 - This means that you need to apply final coating(s) of your choice (which need to be airtight) as soon as the primer paint dries off.
 - A lot of people leave the project for a while (maybe to take a rest) after the application of a primer paint, thinking that they have covered the bare metal and how the main "rust shield" is on, but it probably isn't!
 - Remove all plugs which seal cavities (like plugs on chassis rails, door sills, etc.)
 - Clean and degrease the entire underbody with cleaners/degreasers.
 - Chemically eliminate the last traces of rust on the areas where you mechanically removed rust.
- Use rust elminating acids or even better rust converter/inhibitor chemicals.
- Rust converters/inhibitors work on the principle of chemically altering the rust itself, "freezing" it or chemically converting it into another substance.
 - Apply anti-corrosive primer paint on all bare metal surfaces.
- It is best to use epoxy anti-corrosive primers.
 - Apply seam sealant to all previously rust-treated areas which were welded or where two metal parts/panels join together.
- It is best to use polyurethane seam sealant.
 - Apply a stonechip coating of your choice (bitumen-based, polyurethane, etc.) to the entire underbody.
 - Apply wax over the stonechip coating.
 - Apply wax in all cavities (inside the chassis rails, inside door sills, inside doors, inside anything that is hollow.
 - Take a vacation.
Final notes
Page last edited on 19/09/2018 by user Bosanek
