Rear wheel bearing replacement
Revision as of 07:07, 29 August 2018 by Bosanek (talk | contribs) (Minor phrase correction)
The Rear Wheel Bearings on a Jimny can be prone to wearing, particularly when used off-road. The drum brake backing plate is supposed to provide protection for the bearing but it is very poor and you can expect the bearing to fail VERY regularly if the vehicle is used in muddy/watery conditions.
Providing you have the correct tools, the replacement work can be a straight forward task.
The symptoms of worn Rear Wheel bearings:
Typical symptom of failure
Bearing kits
You will need a suitable bearing kit for your car.
Two kit types are available:
  • A kit for non-ABS Jimnys;
  • A kit for ABS-equipped Jimnys;
Note Icon.pngDon't know what ABS is? Educate yourself by reading this!
Common notes for both kit types:
  • Both types have the same wheel bearing specifications and half shaft oil seal specifications.
  • The "only" difference between the kit types is that the bearing retainer in the ABS kit is much more sophisticated.
    • That is why ABS kits are much more expensive than non-ABS kits.
  • The fitment procedure for an ABS kit is the same as for a non-ABS kit.
    • Don't try to skimp by using a (much cheaper) non-ABS kit on a ABS-equipped Jimny - it won't fit.
An example of a non-ABS Jimny rear wheel bearing kit
  • The non-ABS kit has a plain bearing retainer ring.
An example of an ABS Jimny rear wheel bearing kit
  • The ABS kit has a retainer ring with an ABS ring installed.
  • Some ABS kits have a retainer ring with the ABS ring, whilst other have the ring as an integral part.
Note Icon.pngI have sold a number of different kits over the years and found the quality of the retainer ring varies, with some cheap kits being very poor quality.
Prerequisites
Required parts
The table
Wheel
bearing
1 piece 09269-35009 Various Suzuki actually uses Koyo "DG357222DWC4" bearing under the stated OEM P.N.
Bearing
retainer ring
(non-ABS)
1 piece 43485-73000 Various For non-ABS Jimnys only!!
This part is usually available in the aftermarket only in a set together with the bearing.
Bearing
retainer ring
(ABS)
1 piece 43485-76J00 Various For ABS-equipped Jimnys only!!
Oil seal 1 piece 09283-48007 Various
Dimensions: 48x62x9 mm
Seals the differential oil on the rear half shaft from pouring from inside the axle towards the wheel.
This part is usually available in the aftermarket already in a set together with the bearing.
Oil seal
protector
1 piece 43588-73000 ? Usually does not need replacing, but if you find out that yours is damaged, now you know the replacement part number.
Bearing
grease
A fistful
or so
? Various Sometimes comes together with the bearing
(otherwise use a high quality grease which is suitable for the application).
A calendar
with
pictures of
(half)naked
women
12
pictures
months
Probably
with portraits
of Suzuki's
female
employees
  • Claudia Schiffer
  • Ana Kournikova
  • Monica Bellucci
  • Salma Hayek
  • Pamela Anderson
  • A "bearing + retainer + oil seal" kit for non-ABS Jimnys;
  • A "bearing + retainer + oil seal" kit for ABS-equipped Jimnys;
  • Sorry, no calendars with pictures of naked women (nor men for that matter) are in store's offer (yet)!
Required tools
  • Assorted screwdrivers
  • Slide Hammer
  • Angle Grinder
  • Bearing Press
Note Icon.pngYou will have to use a press.
Replacement procedure
Removing the drum
Jimny Rear Drum
  • First of all secure the car.
  • Release the wheel nuts and jack up the car and remove the road wheel.
  • This then reveals the brake drum.
  • The drum on the picture has a spacer fitted to it.
  • With all the wheel bolts removed, the drum can be pulled forward and off the hub.
Warning Icon.pngThe handbrake must be OFF, otherwise you will not be able to remove the the drum!
Using bolts to remove drum
  • If the drum is stuck, then first of all check that the brake system (cable, shoes, etc.) is not stuck.
  • Then insert two small bolts in the holes in the face of the drum.
  • Reach around the back and feel near the top for a rubber bung.
  • Remove the rubber bung and insert a flat bladed screwdriver.
  • Angle the screwdriver so that the blade is pointing to the back of the car and the handle towards the front.
  • You should be able to feel the adjuster wheel.
  • Using the screwdriver turn the adjuster downwards a few clicks. Then gradually tighten the bolts you inserted in the front, the drum should come off.
Drum removed
  • With the drum removed, the brake shoes can be seen (covered in mud in this case!).
  • As the hub has to come off to change the bearings you need to remove the brake assembly.
Removing the shoes
Lower spring
  • Use a small pair of pliers and remove the small spring that connects across the base of the brake shoes.
Adjuster Spring
  • Use a pair of molegrips to remove the strong spring that joins the top of the shoes with the adjuster.
  • Make a careful note of how the adjuster is fitted.
  • The rod has a forked end and on part of the fork has a step in it.
  • Make careful note of how this fork is fitted.
Shoe retainer
  • Use a pair of pliers and twist the end of the shoe retaining pin until the spring clip is released.
Shoe removal
  • Now the shoes will lift away.
  • Take care not to loose the little adjuster arm and its small spring.
Handbrake cable
  • Release the end of the handbrake cable from the arm on the shoe.
Handbrake cable retainer
  • The handbrake cable is held into the brake backing plate by an expanding spring clip around the cable.
  • The clip needs to be squeezed, so the cable can be pulled out complete with the clip.
  • This is not easy to do but will come out with persistence.
PICTURE REQUIRED
  • You then need to remove the brake pipes from the cylinder.
  • Undo the pipes and catch the drips of brake fluid.
  • There is one pipe if you are doing the passenger side and two pipes if you are doing the drivers side.
Removing the Hub
Backplate bolts
  • The hub is retained by four bolts on the rear.
PICTURE REQUIRED
  • The hub can now be removed.
  • The unit is a friction fit into the axle casing.
  • Attach a slide hammer to the hub and pull it out by using the slide hammer action.
  • Alternatively refit the wheel or old wheel or brake drum (backwards) and hit the hub from behind to drive it off.
Rear axle oil seal
  • With the hub pulled, you can then see the oil seal and oil splash protector in the axle.
  • Hook the old seal out, clean up the axle and push the new seal supplied with the kit into place.
Removing the Bearing
Bearing retainer
  • The old bearing is held in place by a retainer ring which needs cutting off.
Cutting the Bearing retainer
  • The best way seems to be to cut it away with an angle grinder.
  • I do not know of anyone who has removed it in a different way.
Stuck inner race
  • With the retainer cut away, you should be able to remove the remains of the bearing.
  • As you can see in the picture, my bearing had collapsed and left the inner race on the axle .
Collapsed bearing
  • The damage to mine is clear!
New bearing
  • This is what a new bearing should look like.
  • Note that it has a built in "spacer" on one edge, this should be to the OUTSIDE of the hub/wheel.
Re-assembly
Page last edited on 29/08/2018 by user Bosanek
