Immobiliser
THIS IS INCOMPLETE AS IT IS CURRENTLY STILL BEING WRITTEN
In some markets an Immobiliser system is fitted. Whilst the actions you can perform on this system are limited (for security reasons!), Suzuki provide access to the diagnostics so you can at least understand where any issue might be.
The immobiliser consists of 4 main parts of which 3 are "active" ie. contain a level of intelligence.
1. The key. This contains a small coded chip in the form of a tiny black rectangle. This is activated by a radio signal and does NOT require a battery. In keys with batteries these are for the remote lock/unlock facility and does not affect chip operation. However when changing the batteries (or renewing the key case) do not lose the chip!.
2. The Coil Antenna - this is the only passive part of the system. It is looped around the ignition key barrel and senses the chip in the key. It transmits a pulse to power the chip in the key and then passes the response to the Immobiliser unit.
3. Immobiliser unit. This reads the key code coming from the antenna and compares it with a list of up to 4 keys registered in its memory. It also talks to the ECU as well, exchanging its own internal secret code number and the ECUs secret number. Only if the key code, the immobiliser secret number and ECU secret number are all as stored in the memory will it let the ECU start the engine
4. ECU. This starts the engine but only when permitted by the immobiliser. It also checks the secret code received from the immobiliser and only proceeds if this code is matched to the one in its memory. If starting is not permitted then the ECU disables the injectors and the spark ignition.
In summary, the keys, the immobiliser and the ECU are all matched together and changing ANY one requires re-coding of the system. The re-coding can only be done using the Suzuki proprietary scan tool.
However, as stated, the diagnostic codes can be read using the following instructions.
Preparing the read-out
The ECU.
Please refer to the ECU section to read codes from the ECU (NEED TO WRITE LINK)
The Immobiliser.
The read-out of the error codes from the immobiliser is achieved by plugging an analogue (with a needle) voltmeter in the immobiliser connector located behind the dashboard. It is on the drivers side (both for Right Hand Drive and Left Hand Drive) behind the steering wheel, on the side of the steering wheel nearest the door.
Therefore, on vehicles with the steering wheel on the proper side (RHD) it is behind the dashboard behind the drivers right hand when it is holding the steering wheel.
If you are in one of those Jimnys with the steering wheel on the wrong side (a legacy of being invaded by Napoleon) then it is behind the dashboard behind the drivers left hand when it is holding the steering wheel.
PICTURE OF CONNECTOR NEEDED
Reading the codes
To read the codes:
  1. Plug meter into immobiliser socket
  2. Switch on ignition.
The immobiliser will now flick the meter needle giving a code to tell you the fault.
The code is a two digit code so will flick the first digit (using LONG flicks), pause for 1 second and then flash the second digit (Using short flicks), then after a 3 second delay it will repeat.
If more than one code is stored then all the codes will sequence through
The codes are:
Code Reason
00 Three short Normal
11 One Long, one short Key not matched
31 Three long, one short No keys stored
12 One long, two short Immobiliser fault
13 Coil antenna or key fault
31 or 32 Righthand Rear sensor fault
35 or 36 Lefthand Rear sensor fault
41 Right front Hold solenoid valve
42 Right front Release solenoid valve
45 Left front Hold solenoid valve
46 Left front Release solenoid valve
55 Rear Hold solenoid valve
56 Rear Release solenoid valve
57 Power source issue
61 ABS Pump motor circuit
63 ABS Solenoid valve circuit
71 ABS control module
Once complete, remove the wire.
Don't forget to return the diode back into position if you removed it !
Clearing codes
To clear the codes:
  1. Switch off ignition.
  2. Using a piece of wire, short the two pins in the connector together.
  3. Turn on the ignition.
  4. Pull and remake the wire link at least 5 times within a 10 second period.
  5. Turn off ignition and remove the wire.
To be certain that the clearing has been successfully performed, you can repeat the "reading the codes" procedure above to confirm that the code is now "12" = normal.
Page last edited on 21/08/2018 by user Mlines
