Revision as of 14:46, 14 April 2018 by Bosanek (talk | contribs) (A brand new article on solid collars for axle differential pinions)
Differential pinion solid collar upgrade
Solid collar for differential pinion upgrade
If you are using significantly larger tyres, more powerful engine, heavily modified gearbox or transfer box, or differential lockers in your Jimny, the standard crush type collar in the axle differentials can sometimes collapse and cause expensive damage.
The preventive solution is to upgrade (replace it) with a solid collar.
Solid collars are cheaper than the standard crush type collar and come with shims, so you can set the pinion preload correctly.
It is not known if this solution has any disadvantages - someone should write about those.
One of solid collar manufacturers for Jimny is Rob Storr.
Page last edited on 14/04/2018 by user Bosanek
