If you off-road a Jimny (or any of the Suzuki classic 4wd vehicles) then this is a job you will become familiar with.
It is also one of the worst in my opinion, not because it is difficult, but because of the smell, you will find out what I mean later.
It is also closely tied in with changing/working on the wheel bearings so some of the steps are duplicated.
The symptoms of worn KingPin bearings:
- Vertical play in the front wheel (with the car jacked up grip the wheel top and bottom and rock it, there will be movement if they are worn, get an assistant to press the brakes, if it still wobbles then it is the Kingpin bearings.)
It is also common not to experience any play at all and to even pass an MOT with a really bad bearing.
This is because the bottom bearing in particular can rust solid so no play is detectable.
The worst Jimnys for this are often the "one careful lady owner" ones that have sat for long periods on the driveway with the bottom bearing rusting away.
Changing the bearings
Required parts
| King pin bearing | 2 pieces | 09265-15006 | Any bearing make of type "30302J": Koyo, SKF, NSK, Timken .... |
Koyo bearings (if you find true Koyo) are the same as Suzuki OEM; You might need only one bearing, but you won't know that until you dismantle everything. Therefore, buy two now - you will need the other one sooner or later! |
| Halfshaft oil seal | 1 piece | 09283-26016 | Any seal with dimensions: "26 x 38 x 9" (best fit); "26 x 38 x 8" (good fit); "26 x 38 x 7" (okay fit); |
Original Suzuki seal is recommended, because it has special "double lip" construction; Aftermarket seals usually do not have double lips; Also, most of them are shallower (8 mm or even 7 mm depth compared to Suzuki's 9 mm); While a shallower seal is not a critical mismatch, is is always better to avoid that; Reason: smaller sealing / contact area; |
| Steering knuckle swivel seal | 1 piece | 45120-81A04 | Febest SZOS-001 | Might not be needed if the current one is not worn out; Its condition is easy to check just by thoroughly looking under the vehicle; Check if the seal's lip is torn, cracked, jammed, kinked, etc. The current P.N. is the 4th (best quality) revision by Suzuki; There used to be older revisions (ending with 81A01, 81A02 and 81A03); Buy the older revision only if it is on a good discount!; All those revisions are mutually fully compatible; Buy the Febest replacement only if you can't obtain any Suzuki's original seal. |
| Differential oil | 1.1 - 1.65 litre | Who cares | See the wiki article: "Forecourt" |
Not strictly needed (if you jack up only one side of the car, no oil will leak from the axle); However, it is a good idea to change it if your schedule for its replacement is due anyway; |
| Heavy-duty nuclear-proof grease | A handful or so | ? | Divinol Fett Top 2003 (23980); |
This is perhaps the most important part! A super-durable water-and-mud-and-everything-else resistant grease is essential to keep your newly rebuilt assembly protected from grit, water and mud which will certainly enter the steering knuckle (one of Jimny's main weaknesses); Forum user Bosanek has has excellent experience with the stated Divinol 23980 grease; Others are welcome to add their own recommendations in the list; |
| A calendar with pictures of (half)naked women | 12 pictures / months | Who cares | Claudia Schiffer; Ana Kournikova; Monica Bellucci; Salma Hayek; Bridgitte Bardot; |
An essential part of pleasant working experience in most mechanical garages; It is recommended to flip over calendar's pages / months one by one as you progress trough each step in this guide; |
The BigJimny store has two kits available:
- The basic kit has the two king pin bearings and the small oil seal (the first two items from the above table), which are required to do one side.
- The full kit also includes the large external seal (the 3rd item from the above table), although some people choose not to change that seal.
Required tools
- Assorted screwdrivers
- Circlip pliers (external)
- A ball joint splitter
- 1" imperial socket
The Video
Before you read the guide below, you may wish to view the video.
This shows the changing of the Kingpin Bearings on a Jimny fitted with ABS so you will see me remove the sensor etc.
The rest of the guide below shows the same task in a series of steps for clarity.
Removing the Caliper and pads
First of all secure the car. Then release the wheel nuts and jack up the car and remove the road wheel. This then reveals the brake caliper. The picture shows the passenger side (nearside) caliper (UK).
Using a 12mm spanner, release the front caliper bolt (the left is the front of the car in this picture). Then loosen the same bolt on the rear of the caliper.
The pads are retained by small spring clips. A simple pull on the pads (horizontally away from the disk) should remove them. If the pads resist, gently prise out the pads with a small screwdriver - do not remove the spring clips. If you require new pads, spring clips or a caliper fitting kit then these are available in the BigJimny Store.
Removing the Brake Disc
Now the front brake disc can be removed. If you are lucky it will simply pull off, but if you have problems then there are two M8 holes in the disk hub. Simply run two bolts into these holes and the disk will push off the hub. The picture below shows a bolt being used to push the disk off the hub.
Dismantling the Hub
With the hub removed, the driveshaft is exposed. The driveshaft is retained with a circlip, so use a pair of circlip pliers to remove it. This is really fiddly and can be an annoying task. Behind the circlip is a rectangular washer that should also be removed. Note that I have also marked with white paint the orientation of the freewheeling hub, this is not strictly needed.
Gently pull the two vacuum hoses for the hub from the knuckle, making sure you note which one connects to each pipe. It is essential that you get this correct, else the hub will not work again. Also note that if you have an ABS equipped vehicle then you will have to remove the sensor. I do not have photos of this but the video shows it.
At the rear of the hub, release the small bolts holding the seal and retainer. You can see that the swivel hub is covered in oil, a bad sign for KingPin problems.
Undo the nuts on the steering joints. If the joint rotates, then put a jack under the joint and lift the car slightly to lock the joint. Using a splitter, split the steering joints (two to do on the passenger side and one on the drivers side – UK).
Finally, release the KingPin bolts themselves. There are two sets, top and bottom and they must not be mixed up. You can see in the picture that I have marked them up with a letter T.
If you are doing both sides at once then do not mix them across either!
The KingPins are also held in with sticky sealant so you will need to prise them out. The hub will now pull off. Beware, if they are badly worn the hub will be full of stinking grease, oil and water so make sure you can capture the mess in something. This is the bit I hate because of the smell!
- That’s water pouring out of the axle! Also shown is a worn out bearing.
The thing to remember is that it is not a Land Rover, which has oil filled swivels. The joints on Jimnys should be "dry" apart from some lubricating grease.
The rebuild
A simple way to drive them out is to use a 1" Imperial socket. Using an extension bar fed through the swivel, place the 1" Socket behind the ring and drive it out by hitting it. Picture from Dave at Bits4Vits
The new rings can then be driven into place with a piece of wood to protect them from the hammer. Again, this is seen in the video (picture needed here).
If you are changing the large seal then now is the time to put the new one on. The confusing part is the order of the seals and rings on the swivel. The pictures below show the correct orientation. Note also that the slits in the retainers go to the top.
Grease the new KingPin bearings and insert the top one in the carrier. I find the easiest way to grease the bearings is to put them in a polythene bag with some grease. Then use the bag to squeeze the grease into the bearing, this can be seen in the video. (picture needed here). Carefully insert the new bottom bearing and, holding it in place, slide the whole knuckle onto the hub. Fill the Knuckle with 100ml of grease, Suzuki recommend only 100ml and not to overfill. Now the KingPins need to be inserted, but first they need a bead of sealant around the KingPin. * Again, the BigJimny shop sells suitable sealant.
Make sure that you have put the correct Kingpin in place, remember you should have marked them when you dismantled it! Bolt the Kingpins in and tighten them to the correct torque (18ft/lbs). Refit the steering arm (or arms if it is the side with two connections), tightening the nuts to 31ft/lbs. Fit the disk and fit the caliper (Caliper bolts 61ft/lbs), brake pads and bolt the caliper down in position (Caliper pin bolt 16/ft/lbs). Re-fit the wheel and lower the vehicle.
Page last edited on 23/03/2018 by user Bosanek
