Revision as of 21:04, 4 August 2016 by Mlines (talk | contribs) (Created page with "= Rear Wheel Bearings = == Introduction == The Rear Wheel Bearings on a Jimny can be prone to wearing, particularly when used off-road. The drum brake backing plate is suppos...")
Rear wheel bearing replacement
Rear Wheel Bearings
Typical symptom of failure
Click on images to make them larger
Changing the bearings
  • Assorted screwdrivers
  • Slide Hammer
  • Angle Grinder
  • Bearing Press
YOU NEED ACCESS TO A PRESS
Bearing kits
Non-ABS Bearing kit
The ABS kit has a retainer ring with an ABS ring installed. The fitment of the kit is the same as the standard one but note that the ABS retainer is much larger overall if you were considering using the cheaper non-ABS kit. Some kits have a retainer ring with the ABS ring whilst other have the ring as an integral part.
Old retainer ring
Full ABS retainer
Removing the hub
Jimny Rear Drum
Using bolts to remove drum
Drum removed
Removing the shoes
Lower spring
Adjuster Spring
Shoe retainer
Shoe removal
Handbrake cable
Handbrake cable retainer
NO PICTURE. You then need to remove the brake pipes from the cylinder. Undo the pipes and catch the drips of brake fluid. There is one pipe if you are doing the passenger side and two pipes if you are doing the drivers side.
Removing the Hub
Backplate bolts
Rear axle oil seal
Removing the Bearing
Bearing retainer
Cutting the Bearing retainer
Stuck inner race
Collapsed bearing
The damage to mine is clear!
New bearing
Re-assembly
Page last edited on 4/08/2016 by user Mlines
