Rear Wheel Bearings
Changing the bearings
Bearing kits
You will need a suitable bearing kit for your car. Two kits are available, one for non-ABS and one for ABS cars.
The ABS kit has a retainer ring with an ABS ring installed. The fitment of the kit is the same as the standard one but note that the ABS retainer is much larger overall if you were considering using the cheaper non-ABS kit. Some kits have a retainer ring with the ABS ring whilst other have the ring as an integral part.
Removing the hub
Removing the shoes
NO PICTURE.
You then need to remove the brake pipes from the cylinder. Undo the pipes and catch the drips of brake fluid. There is one pipe if you are doing the passenger side and two pipes if you are doing the drivers side.
Removing the Hub
PICTURE REQUIRED
The hub can now be removed. The unit is a friction fit into the axle casing. Attach a slide hammer to the hub and pull it out by using the slide hammer action. Alternatively refit the wheel or old wheel or brake drum (backwards) and hit the hub from behind to drive it off.
Removing the Bearing
The damage to mine is clear!
This is what a new bearing should look like. Note that it has a built in "spacer" on one edge, this should be to the OUTSIDE of the hub/wheel.
New bearing kits are available in the BigJimny store. There is also a special kit for ABS equipped cars
Page last edited on 4/08/2016 by user Mlines
