Forecourt Information
Please ensure this information applies to your specific vehicle and country as variations can occur.
G13BB petrol engine, UK
| Type | Quantity | Specification |
| Engine oil | 4.5 litres | SAE 10W-30 (UK recommended) |
| Gearbox oil | 1.3 litres | API GL-4, SAE 75W-90 |
| Transfer gearbox oil | 0.9 litres | API GL-4, SAE 75W-90 |
| Differential oil (front) | 1.35 litres | API GL-5, SAE 80W-90, hypoid |
| Differential oil (rear) | 1.5 litres | API GL-5, SAE 80W-90, hypoid |
| Coolant capacity | 4.5 litres | TBC |
M13A (non-VVT) petrol engine, UK
| Engine oil | 4.0 litres | SAE 10W-30 (UK recommended) |
| Gearbox oil | 1.1 litres | API GL-4, SAE 75W-90 |
| Transfer gearbox oil | 0.8 litres | API GL-4, SAE 75W-90 |
| Differential oil (front) | 1.1 litres | API GL-5, SAE 80W-90, hypoid |
| Differential oil (rear) | 1.3 litres | API GL-5, SAE 80W-90, hypoid |
| Coolant capacity | 5.2 litres | TBC |
| A/T fluid | 1.1 litres | Dexron IIE |
| Power steering | ? litres | Dexron IIE |
| Brake fluid | ? | DOT3 |
M13A (VVT) petrol engine, UK
| Engine oil | 4.0 litres | SAE 10W-30 not available in UK, back page of UK owners manual advises 5W/30 from late 2016: SAE 0W-20 (recommended for new UK cars in the handbook) |
| Gearbox oil | 1.3 litres | API GL-4, SAE 75W-80 |
| Transfer gearbox oil | 1.13 litres | API GL-4, SAE 75W-90 |
| Differential oil (front) | 1.65 litres | API GL-5, SAE 80W-90, hypoid |
| Differential oil (rear) | 1.35 litres | API GL-5, SAE 80W-90, hypoid |
| Coolant capacity | 5.9 litres | TBC |
| A/T fluid | 5.7 litres | Dexron III |
DDiS diesel (K9K engine 48 kW), continental Europe
| Engine Oil | 4.0 litres | ACEA B3 or B4, SAE "X"W-40 (10W-40 good, 5W-40 better, 0W-40 best) |
| Gearbox Oil | 1.9 litres | API GL-4, SAE 75W-90 |
| Transfer gearbox oil (lever shifted type) |
1.2 litres | API GL-4, SAE 75W-90 |
| Transfer gearbox oil (push-button shifted type) |
| Coolant capacity | 7.0 l | Ethylene glycol non-silicate based |
| Power steering | ? litres | Dexron III |
| Brake fluid | ? litres | SAE J1703 or DOT3 |
- Air filter, oil filter and fuel filter for diesel Jimnys are different than for petrol Jimnys.
- Most DDiS Jimnys with 48 kW engine have the lever shifted transfer box, while the last production examples from 2005 have the push-button shifted transfer box. Hence two specifications in the above table.
DDiS diesel (K9K engine 63 kW), continental Europe
| Engine Oil | 4.9 litres | ACEA B3 or B4, SAE "X"W-40 (10W-40 good, 5W-40 better, 0W-40 best) |
| Coolant capacity | 7.3 l | Ethylene glycol non-silicate based |
Page last edited on 20/09/2017 by user Bosanek
