Revision as of 13:32, 13 July 2017 by Bosanek (talk | contribs) (Some small wiki code adjustments)
Regular maintenance intervals and consumables
Forecourt Information
Please ensure this information applies to your specific vehicle and country as variations can occur.
G13BB petrol engine, UK
Type Quantity Specification
Engine oil 4.5 litres SAE 10W-30 (UK recommended)
Gearbox oil 1.3 litres API GL-4, SAE 75W-90
Transfer gearbox oil 0.9 litres API GL-4, SAE 75W-90
Differential oil (front) 1.35 litres API GL-5, SAE 80W-90, hypoid
Differential oil (rear) 1.5 litres API GL-5, SAE 80W-90, hypoid
Coolant capacity 4.5 litres TBC
M13A (non-VVT) petrol engine, UK
Engine oil 4.0 litres SAE 10W-30 (UK recommended)
Gearbox oil 1.1 litres API GL-4, SAE 75W-90
Transfer gearbox oil 0.8 litres API GL-4, SAE 75W-90
Differential oil (front) 1.1 litres API GL-5, SAE 80W-90, hypoid
Differential oil (rear) 1.3 litres API GL-5, SAE 80W-90, hypoid
Coolant capacity 5.2 litres TBC
A/T fluid 1.1 litres Dexron IIE
Power steering ? litres Dexron IIE
Brake fluid ? DOT3
M13A (VVT) petrol engine, UK
from late 2016: SAE 0W-20 (recommended for new UK cars in the handbook)
Gearbox oil 1.3 litres API GL-4, SAE 75W-80
Transfer gearbox oil 1.13 litres API GL-4, SAE 75W-90
Differential oil (front) 1.65 litres API GL-5, SAE 80W-90, hypoid
Differential oil (rear) 1.35 litres API GL-5, SAE 80W-90, hypoid
Coolant capacity 5.9 litres TBC
A/T fluid 5.7 litres Dexron III
Brake fluid ? DOT3
DDiS diesel (K9K engine 48 kW), continental Europe
Engine Oil 4.0 litres ACEA B3 or B4, SAE "X"W-40
(10W-40 good, 5W-40 better, 0W-40 best)
Gearbox Oil 1.9 litres API GL-4, SAE 75W-90
(lever shifted type)
1.2 litres API GL-4, SAE 75W-90
(push-button shifted type)
Coolant capacity 7.0 l Ethylene glycol non-silicate based
Power steering ? litres Dexron III
Brake fluid ? litres SAE J1703 or DOT3
  • Air filter, oil filter and fuel filter for diesel Jimnys are different than for petrol Jimnys.
  • Most DDiS Jimnys with 48 kW engine have the lever shifted transfer box, while the last production examples from 2005 have the push-button shifted transfer box. Hence two specifications in the above table.
DDiS diesel (K9K engine 63 kW), continental Europe
Engine Oil 4.9 litres ACEA B3 or B4, SAE "X"W-40
Coolant capacity 7.3 l Ethylene glycol non-silicate based
Page last edited on 13/07/2017 by user Bosanek
