Revision as of 15:26, 8 June 2016 by Mlines (talk | contribs) (→Tools)
Clutch replacement
Use the "Print as PDF" tab above to print
A guide to changing the clutch.
  • Judder as clutch is released
  • Slipping as engine power is applied
  • Burning smell or smoke from under car
  • Bearing squeal or rumble when clutch pedal pressed.
Changing the Clutch
  • Assorted screwdrivers
  • Breaker bar
  • Clutch alignment tool
  • Strops to pull engine forward
  • 10mm Square Drain plug socket
Removing Interior Items
Centre Console
File:Figure 1. Removing the Centre Console.png
To remove the gearbox lever you have to remove the centre console. This is held on by four screws on the side at the front and back. The console then lifts out. Mine was more of a problem as I have a switch panel fitted so I then needed to remove the gearlever before the console would come completely away, but this has to be done at some point anyway.
Gear levers
File:Figure 2. Removing the Gearlever.png
Lower Gaiter
File:Figure 3. Removing the lower Gaiter.png
Transfer Lever
File:Figure 4. Removing the Transfer Lever Knob.png
File:Figure 5. Removing the Transfer Level Gaiter.png
Draining the Oil
File:Figure 6. Gearbox Drain Plugs.png
Move outside the car and disconnect the negative cable at battery. Now drain the oil from the gearbox and transfer box, if you are not doing any work on the transfer box then it is not strictly necessary to drain the oil providing you keep it upright to stop the oil coming out of the lever hole. On my Jimny the drain plugs are square and therefore a SQUARE 10MM drain plug socket should be used, however the square end of a 3/8 socket driver fits if you are pushed. Always undo the filler plug first because if the filler is stuck you do not want to drain the oil and not be able to fill it again. The gearbox filler is hidden up the side of the gearbox and lack of space is a problem
Removing Front Exhaust Section
Exhaust
File:Figure 7. Transfer Box Fillers and Connectors.png
File:Figure 8. Exhaust Bolts.png
Lambda Sensor
File:Figure 9. Lambda Sensor on Converter.png
File:Lambda Sensor Connector Behind Here.png
Removing the Prop shafts, Transfer Box & Gearbox Remote Mechanism
Prop shafts
File:Mark the Propshaft.png
Mark the Propshaft
Transfer Box
File:Figure 10. Transfer mounts.png
File:Figure 11. Transfer Mounts.png
File:Figure 12. Gearbox Remote Mechanism.png
File:Figure 13. Remote Mechanism in place.png
Removing the Engine Mounting Bolts, Starter Motor and Clutch Cable
Engine Mounting
Reversing Switch
File:Figure 14. Gearbox Reverse Switch.png
Starter Motor
File:Figure 15. Starter Motor (from underneath car).png
Clutch Cable
File:Figure 16. Clutch cable (unhooked).png
Seperating Gearbox away From Engine
File:Figure 17. Gearbox bolts.png
File:Figure 18. Pulling the engine forward with strap.png
File:Figure 19. Gap between gearbox and clutch with engine pulled forward.png
Replacing the Clutch
File:Figure 20. Clutch Release Bearing.png
File:Figure 21. Wrong Release Bearing is on Right.png
File:Figure 22. New Clutch Plate on left.png
File:Figure 23. New clutch cover on left.png
File:Figure 24. Clutch Assembled.png
File:Figure 25. Clutch with alignment tool.png
File:Figure 26. Clutch back in place.png
File:Figure 27. Grease the mounting face of the gearbox.png
Refitting the Gearbox
File:Figure 28. Gearbox breather.png
Page last edited on 8/06/2016 by user Mlines
