Revision as of 20:15, 4 June 2016 by Mlines (talk | contribs)
Clutch replacement
Use the "Print as PDF" tab above to print
A guide to changing the clutch.
No special tools are required, but a good toolkit is needed. You will need extension bars for a socket set as some of the bolts are well hidden and difficult to access. A breaker bar is also needed as some bolts are very tight.
To remove the gearbox lever you have to remove the centre console. This is held on by four screws on the side at the front and back.
File:Figure 1. Removing the Centre Console.png
The console then lifts out. Mine was more of a problem as I have a switch panel fitted so I then needed to remove the gearlever before the console would come completely away, but this has to be done at some point anyway. Pull the gaiter away to reveal the three bolt heads around the base of the gearlever, undo the bolts and carefully lift out the gearstick, note that there is a small spring and a cup that should not be lost!
File:Figure 2. Removing the Gearlever.png
File:Figure 3. Removing the lower Gaiter.png
File:Figure 4. Removing the Transfer Lever Knob.png
File:Figure 5. Removing the Transfer Level Gaiter.png
Move outside the car and disconnect the negative cable at battery. Now drain the oil from the gearbox and transfer box, if you are not doing any work on the transfer box then it is not strictly necessary to drain the oil providing you keep it upright to stop the oil coming out of the lever hole.
File:Figure 6. Gearbox Drain Plugs.png
On my Jimny the drain plugs are square and therefore the square end of a 3/8 socket driver fits. Always undo the filler plug first because if the filler is stuck you do not want to drain the oil and not be able to fill it again. The gearbox filler is hidden up the side of the gearbox and lack of space is a problem
File:Figure 7. Transfer Box Fillers and Connectors.png
File:Figure 8. Exhaust Bolts.png
File:Figure 9. Lambda Sensor on Converter.png
File:Lambda Sensor Connector Behind Here.png
File:Mark the Propshaft.png
Mark the Propshaft
File:Figure 10. Transfer mounts.png
File:Figure 11. Transfer Mounts.png
File:Figure 12. Gearbox Remote Mechanism.png
File:Figure 13. Remote Mechanism in place.png
File:Figure 14. Gearbox Reverse Switch.png
File:Figure 15. Starter Motor (from underneath car).png
File:Figure 16. Clutch cable (unhooked).png
File:Figure 17. Gearbox bolts.png
File:Figure 18. Pulling the engine forward with strap.png
File:Figure 19. Gap between gearbox and clutch with engine pulled forward.png
File:Figure 20. Clutch Release Bearing.png
File:Figure 21. Wrong Release Bearing is on Right.png
File:Figure 22. New Clutch Plate on left.png
File:Figure 23. New clutch cover on left.png
File:Figure 24. Clutch Assembled.png
File:Figure 25. Clutch with alignment tool.png
File:Figure 26. Clutch back in place.png
File:Figure 27. Grease the mounting face of the gearbox.png
File:Figure 28. Gearbox breather.png
Page last edited on 4/06/2016 by user Mlines
