Clutch replacement
A guide to changing the clutch.
No special tools are required, but a good toolkit is needed. You will need extension bars for a socket set as some of the bolts are well hidden and difficult to access. A breaker bar is also needed as some bolts are very tight.
To remove the gearbox lever you have to remove the centre console. This is held on by four screws on the side at the front and back.
File:Figure 1. Removing the Centre Console.png
The console then lifts out. Mine was more of a problem as I have a switch panel fitted so I then needed to remove the gearlever before the console would come completely away, but this has to be done at some point anyway. Pull the gaiter away to reveal the three bolt heads around the base of the gearlever, undo the bolts and carefully lift out the gearstick, note that there is a small spring and a cup that should not be lost!
File:Figure 2. Removing the Gearlever.png
File:Figure 3. Removing the lower Gaiter.png
