Martins Test
Front Wheel Bearings
The Front Wheel Bearings on a Jimny can be prone to wearing, particularly when used off-road. Providing you have the correct tools it can be straight forward task.
It is also closely tied in with changing/working on the kingpin bearings so some of the steps are duplicated. So what are the symptoms of worn Wheel bearings:
  • Horizontal play in the front wheel (with the car jacked up grip the wheel sides, there will be movement if they are worn. Get an assistant to press the brakes and the movement should disappear)
Leaking front swivel
Click on images to make them larger
It is also common not to experience any play at all and to even pass an MOT with a really bad bearing. This is because the bearings are dual race and only one race may have failed.
Changing the bearings
  • Assorted screwdrivers
  • Hub Nut Tool
  • Circlip pliers (External)
  • A ball joint splitter
  • 1" Imperial Socket
YOU NEED A SPECIAL TOOL TO RELEASE THE HUB NUT
Removing the Caliper and pads
Jimny Front Caliper
Unbolting the caliper
Open brake caliper
Removing the brake pads
Removing the Brake Disc
Carrier bolt
Caliper tied to Spring
Disc removal using bolt
Dismantling the Hub
Torx bolt on hub
Removing the circlip
The hub nut
The hub nut tool
This is the tool, it is available from the BigJimny Store. Make sure that the tool and the nut are completely clean as the tool will not fit. Make sure the tool is inserted into the nut correctly with the pins all in the holes in the nut, you are really going to have to swing on the nut to release it. I had to use a long breaker bar AND a piece of scaffold tube. With the nut removed the hub should be removeable, it might need a pull with a slide hammer, mine just pulled off by hand.
The bearing seal
With the hub face down on a surface you can now remove the bearing seal from the rear of the hub. I prised mine out with a screwdriver.
C-Clips retain the bearing
Then you can use a pair of long nose pliers to remove the C-Clips that retain the bearing, note that these may be corroded in and difficult to even see at first.
Removing the bearing
Now comes the first bit that is supposed to be difficult. Suzuki say that the bearing needs to be removed using a press. I decided to have a go myself. Using an old piece of bearing and a steel pin I hammered out the bearing and it only took two or three swift blows. The picture shows the steel pin resting on the bearing before being hit. Note the use of the brake disk to provide a holder for the hub allowing the bearing to be driven out of the bottom.
Wheel Bearing Kit
The bearings are Koyo brand as standard. The BigJimny store has a kit available which includes the seal and the c-clips (not all kits contain the c-clips), the Wheel Bearing Kit is here
The rebuild
Suzuki says the new bearing needs to be pressed into place. I decided to try a bit of school boy physics. I coated the bearing in Copper Grease and then put it in the deep freeze overnight. The hub was placed in the oven at 180 degrees for 30 minutes. So with an ice cold bearing and a very hot hub I put the bearing in the hub, placed the old bearing ring and the steel pin on top and tapped the bearing straight into place. It took two gentle hits!. Again note the use of the brake disk to hold the hub. ALLOW THE WHOLE ASSEMBLY TO COOL BEFORE TOUCHING OR TURNING THE BEARING ASSEMBLY
Once it is cooled put grease into the ends of the bearing. Then insert the new circlip and the oil seal. I found that the oil seal pressed in ok by hand once coated in Copper Grease. The oil seal has a protruding lip,this must be to the outside of the joint. Grease the inside of the bearing and slide the hub back onto the driveshaft
The hub nut
Grease the hub nut and tighten the nut using the special tool, torque it to 220NM or 160ft lbs – ie. really tight!. Use a punch to bend the inner lip of the nut to lock it in place. Refit the hub thrust washer and circlip to the driveshaft.
