Revision as of 13:52, 3 June 2016 by Mlines (talk | contribs)
Martins Test
Front Wheel Bearings
The Front Wheel Bearings on a Jimny can be prone to wearing, particularly when used off-road. Providing you have the correct tools it can be straight forward task.
It is also closely tied in with changing/working on the kingpin bearings so some of the steps are duplicated. So what are the symptoms of worn Wheel bearings:
  • Horizontal play in the front wheel (with the car jacked up grip the wheel sides, there will be movement if they are worn. Get an assistant to press the brakes and the movement should disappear)
Leaking front swivel
Click on images to make them larger
It is also common not to experience any play at all and to even pass an MOT with a really bad bearing. This is because the bearings are dual race and only one race may have failed.
Changing the bearings
  • Assorted screwdrivers
  • Hub Nut Tool
  • Circlip pliers (External)
  • A ball joint splitter
  • 1" Imperial Socket
YOU NEED A SPECIAL TOOL TO RELEASE THE HUB NUT
Removing the Caliper and pads
Jimny Front Caliper
Unbolting the caliper
Open brake caliper
Removing the brake pads
Removing the Brake Disc
Carrier bolt
Caliper tied to Spring
Disc removal using bolt
Dismantling the Hub
Torx bolt on hub
Removing the circlip
removing a vacuum pipe
Removing the swivel seal bolts
Splitting the ball joint
undoing the Kingpin bolts
The KingPins are also held in with sticky sealant so you will need to prise them out. The hub will now pull off. Beware, if they are badly worn the hub will be full of stinking grease, oil and water so make sure you can capture the mess in something. This is the bit I hate because of the smell!. That’s water pouring out of the axle! Also shown is a worn out bearing.
The rebuild
The old bearing race
Removing the bearing race
A simple way to drive them out is to use a 1" Imperial socket. Using an extension bar fed through the swivel place the 1" Socket behind the ring and drive it out by hitting it. (picture from Dave at Bits4Vits
The rebuilt swivel
The greased CV joint
Applying sealant
