Torque
Revision as of 09:49, 3 June 2016 by Mlines (talk | contribs) (→‎Axle)
Axle
Item Torque Nm Torque lb-ft
Radius Arm bolts (Axle) 90 Nm 65 lb-ft
Radius Arm bolts (Chassis) 90 Nm 65 lb-ft
Differential
Diff Drain Plug 27 Nm 19.5 lb-ft
Diff Filler Plug 50 Nm 36.5 lb-ft
Prop Shaft Flange Bolts 50 Nm 36.5 lb-ft
Bevel Gear Bolts 85 Nm 61.5 lb-ft
Bearing Cap Bolts (front) 50 Nm 36.5 lb-ft
Bearing Cap Bolts (rear) 85 Nm 61.5 lb-ft
Lock Plate Bolts 11.5 Nm 8.5 lb-ft
Front and Rear carrier bolts 23 Nm 17 lb-ft
Gear Thrust Bolt (front) 1.5 Nm 0.1 lb-ft
Gear Thrust Bolt (rear) 85 Nm 61.5 lb-ft
Front Hub
Wheel Nuts 95 Nm 69 lb-ft
Tie-Rod End Nut 43 Nm 31.5 lb-ft
Kingpin Bolt 25 Nm 18.0 lb-ft
Locking Hub Bolts 48 Nm 35 lb-ft
Swivel Seal Bolts 10 Nm 7.5 lb-ft
Brake Carrier Bolts 85 Nm 61.5 lb-ft
Wheel Bearing Lock Nut 220 Nm 160 lb-ft
Drop-Link/Stabilizer Link ball nut 50 Nm 36.5 lb-ft
Brake Caliper Slider Bolt 22 Nm 16 lb-ft
Front Brake Flexi Hose bolt 23 Nm 17 lb-ft
