Buying a Jimny
Before you buy
- Take one for a test drive, compared to modern cars even the most recent Jimnys feel primitive.
- Buy one in the Spring and sell one in the Winter, everyone wants a 4x4 when the snow falls so prices are higher in the winter.
General Points
- The main issue with Jimnys is rust, depending on the year/model etc some had rust protection but others did not. As the vehicle is chassis based it can pass a UK MOT test with quite a bit of rust unless the rust is around the body and seat mounting points.
- Try and look behind the front headlamps, underneath the lamps and splashguard, this is a rust point and is near the front body mounts.
- Lift any carpet in the boot and look into the small pan where the tools/jack are stored, this can rust out, particularly on soft-tops.
- Check the boot floor in general, this can rust through and is the most common issue. This is a real problem for older Jimnys.
- Check around the seat belt mounting points for rust.
- Check around the plastic trim, particularly on the sills as rust hides behind.
- Check the brackets which connect the arms holding the axle in place, these rust at the axle and at the chassis end.
- Kingpin bearings: A common issue on live axle 4x4s. These corrode and wear quickly. It is almost inevitable that you will have to change them at some point. When buying take that vital test drive and check for steering wobble around 45 - 50 mph. see Death Wobble
G13B Specifics
Soft-top Specifics
- The Soft-top retained the G13B until the end with some late registrations in 2005
- There are some M13A engined soft-tops around but these seem to be rare and an anomaly.
- The soft-top frames suffer considerable corrosion at the front, Suzuki no longer make these parts and getting hold of replacements is extremely difficult
- New soft tops can be bought from Monsoon in the UK. They have a reputation for good quality.
- There is a removable hard-top available to replace a soft-top during winter.
M13A Specifics
M13A VVT Specifics
K9K Diesel Specifics
After about 2000 hard tops got a twin cam engine with a timing chain instead of a cam belt. Soft tops retained their single cam engine until the end of their production in about 2005.
You can buy hard tops to go on soft tops. This may be appealing as the soft top is in two parts with a front section over the front seats. You can remove just this section, which would be nice in the summer months! There were 2 designs of the hard top for soft tops and owners with more experience of these will tell you when they changed over and what he differences are.
Mechanical issues as a rule are not numerous but there are a couple of problems that can pop up from time to time, especially if you go off-road.
The King Pin bearings in the front axles wear quicker on the Jimny than they ever did on the SJ. The movement created by this causes the axle tube oil seal to leak and mix with the CV grease. You then have the gunk created by their mixture leaking out of the Swivel Ball Dust Seals. This is no biggie for the DIY mechanic. The biggest issue will be rusted in bolts but they are all available in the Big Jimny Shop at a reasonable price with a very good and quick service from the site Owner - Martin Lines.
The trouble is that many Professional Mechanics do not see the old SJ very often to know the Swivels on Suzuki's do not have oil in them for the CV's like the Land Rovers they are used to repairing. The CV is just greased with a rubber dust seal that wipes over the swivel ball. They then quote silly things for the simple repair.
A home mechanic can change the King Pin Bearings in about 3/4 hours per side when all the bolts have been off before. There's a "How To" Guide within here: www.bigjimny.com/index.php/information/qhow-toq-guides
Moving on a little from the King Pin bearings but still linked to them is a phenomenon called "Death Wobble". It has it's own thread here: www.bigjimny.com/index.php/forum?view=topic&catid=7&id=51883
I won't repeat the contents of this thread again but essentially you can have a horrible wobble of the steering wheel, usually about 45 MPH that gets so bad you think you are going to die. Hence the name. Worn King Pin Bearings are one cause of it. The thread will tell you about all the others.
The Jimny is not the only Live Axle vehicle to suffer with it. Jeeps also suffer and I have known of Land Rovers to do so. The Jimny is particularly susceptible to it though.
In about 2005 the twin cam engine was developed to have Variable Valve Timing - VVT. This gave the Jimny a few extra Horses but there was also a new Gearbox added at this time and the 4WD mechanism went from a gearstick from the transfer box push button selection for 2WD, 4WD HIGH and 4WD LOW.
The Jimny is normally 2WD you see and has no Centre Differential like some Land Rovers do. You must only put it in 4WD when the ground is of a slightly lower grip (wet grass, gravel, ice, snow). Otherwise you will suffer what is called transmission wind up, where tension builds in the transmission as the front and rear axles have turned as different speeds from cornering etc.
Both methods of changing from High to Low and 4WD to 2WD appear reliable.
The transfer box has a chain inside which can stretch and start to make vibration noises through wear. To test, drive in second and go on and off the throttle to see if you can hear it vibrate as it goes slack when you take your foot off the throttle. Second hand transfer boxes are easy to get and cheap enough. Replacement is easy. They are divorced from the gearbox, connected with a mini prop and light enough for a single person to bench press up with one arm whilst guiding it with the other. Or use a Jack!
The VVT engine received a new gearbox though. This gearbox on the whole is reliable but being a forum specialising in these cars we hear of all the problems. One of them is that this VVT gearbox does sometimes go wrong and is expensive to repair and next to impossible to find second hand. When you do find one it will be expensive. The symptoms to my understanding are worn bearing like noises but the problem, a transmission specialist new to this site recently posted, is more syncromesh related, hence the expensive repairs. He suggested the oil Suzuki spec is too thin and burns too quickly. No other gearbox can be fitted in its place from older cars. So you have to fix it or find a like replacement.
I believe later models have a new gearbox again that is probably too new to show any issues. When this was introduced I am not sure.
There are many other small issues, such as the bolt holes for the rear radius arm mounts elongating, allowing the bolt to move and clunk. Sometimes they are just loose and need nipping up. I've experienced this twice. I've nipped them up and have not got elongated holes as a result.
The vacuum operated hubs can fail where the vacuum leaks from the rubber seals of the pipework. This can be solved by finding the leak and replacing the parts required or blocking it off and fitting manual hubs / fixed hubs.
I started this thread about converting your vacuum hubs to fixed for free: www.bigjimny.com/index.php/forum?view=topic&catid=7&id=55862
There is school of thought that this is no good for your front diff or transfer box as it is not designed to always have the reverse forces on the gears when you let off the throttle and are in over run. My personal experience is that there is no need to worry and my old SJ had fixed front hubs from the factory. You make your choice. I've run fixed hubs for a long time with no issues on my Jimny.
If you are planning to go off road you will likely want to modify your Jimny. The first things you will want to do are give it a suspension lift and bigger tyres. These are topics in their own right but a point to bear in mind is that the Low ratios in the transfer box are not that Low and you'll find tyres bigger than 215/75/15 will make Low ratio far too High.
We solve this problem the same way as SJ owners do. We use a Rocklobster Transfer Box. This is an SJ transfer box casing with some magic performed inside to give a slight reduction in High Ratio and a much, much lower Low ratio gearset. Richard Wattam from RAM AUTO DESIGN is the main man for this and does a great fitting kit. Jimnybits.co.uk also sell them.
I mention Rocklobsters in this Buyer's Guide as fitting a Rocklobster to a Push Button Transfer Box car is a bit harder than fitting it to a stick shift transfer box car. It is not insurmountable but if you know you will be going down the Rocklobster route with massive modifications at some point, you might just want to make your life easier by buying a stick transfer box car in the first place!
Having said all of this, my personal pick of the bunch from across the years of UK Jimny models is the 2000 model hard top up to the end of February 2011.
My reasons for this are that it has the twin cam engine (no cambelt to change or head gasket issues) in the lower tax bracket and the reliable gearbox with stick shift transfer box. You just have to look out for the rust! After this it is a pre 2005 twin cam, just suffering the little extra tax.
I would personally buy a 2005 on VVT but would change the gearbox oil nearly as often as the Engine Oil - it's not hard! The younger it is the less rust it will have. There are many VVT engine cars that have never had gearbox troubles. So don't think because we are aware of it on a forum that it is a massive issue. Forums are magnets for the problems but don't publicise the hundreds of thousands of cars that never had the issue!
There are other things that go wrong like on any car - blocked and worn out cats, cam and crank sensors. cooling system faults. Nothing more than other cars though.
One last thing to mention is that if you are buying to create an off road monster with massive tyres, the shafts and CV's are not as strong as on the SJ413 or Samurai. They are more akin to the SJ410 in dimensions and strength, yet have more power and torque than any of them before it. You will therefore need to budget for HD front shafts and CV's from one of the several manufacturers selling them now. They are not cheap! This is no different than for Land Rover owners who spend fortunes with Ashcroft Transmissions!
I hope this helps.
Kirktnut
