Suzuki Jimny has been in production since 1998 up until now. That is nearing 20 years.
During that time, there have been several smaller and larger revisions of the vehicle, as well as different editions for different world markets. The most notable example of market differentiation are Japanese Domestic Models (JDM) versus international models. JDM models are even smaller and "tinier".
This page deals mostly with the international edition (known in Japan as "Jimny Wide"). See the section Jimny History for more information
Another good source of information on the history of the Jimny is Generic world Wikipedia article on Jimnys
The purpose of this page
Since Jimnys have been in production for almost 20 years, it is no surprise that there are many versions of user and service manuals for all the different vehicle editions and revisions through the last 20 years!
The purpose of this page is to help you find the reference numbers of user manuals and service manuals your specific model.
However, when you find reference numbers, it's up to you to find the actual documents (either electronic or printed form), as they are most probably copyrighted. That is why you can not download them from here.
Since approx year 2007, Suzuki stopped publishing manuals for further Jimny revisions. Instead, the documentation is available from Suzuki exclusively through an online subscription for selected partners.
Therefore, if your Jimny was made after circa 2007, you can either obtain the last available printed or PDF manual for type 6 revision from 2006 (and hope that it does not differ much from your vehicle), or go the official Suzuki way.
The process of finding the correct document name for a certain Jimny is generally almost as complicated as deciphering a Russian computer code written reverse in Egyptian hieroglyphs with bad handwriting.
However, it has been deciphered, and presented in this page in a intuitively laid-out three-phase-driven process. If you follow the phases, you should have no problems determining the names of the required documents.
The general process of determining the names of exactly matching Suzuki's documents for your Jimny are:
- Determine the VIN (chassis) code of your vehicle. It can be found in the engine compartment (somewhere below the front window) and engraved in the chassis rail behind one of the rear wheels. You can also probably find it in your vehicle's documents when you registered it for road use, but reading the VIN from the vehicle itself is most reliable source.
 - Based on your VIN, determine to which technical "type" number (factory revision) your vehicle belongs. This is the most complicated step. A range of VINs is presented for each type in a set of tables. You need to determine in which range your VIN fits. The ranges do not overlap - therefore there can be only one (or none) match!
 - Based on the determined type number, see which document names are meant for that type. And read the related notes for each table!
Get ready and read on!
Basic vehicle components
All international vehicles have the same chassis, as well as the basic body contours. Therefore, all have the same wheelbase and the number of doors.
Regarding body types, there is a "closed cabin" body ("metal top", "tin top", "station wagon"), and an "open cabin" body (convertible, cabriolet, cabrio) (made by Santana Motors). Cabriolets exist with three types of body top covers (roofs) - vinyl "soft top", plastic "hard top" and plastic "fastback" sloped top, but the covers are interchangeable from one convertible vehicle to another.
Regarding transmission, all have part-time 4WD system where default is 2WD (RWD). Gearbox is manual or automatic.
Seating is for 4 (passenger edition) or for 2 (van editions, rare).
There was also a "2WD only" edition produced from 1998 to cca 2001. It has no 4WD system elements installed (no front prop shaft, no front differential, different front axle casing, no vacuum system, etc.)
Differences between factories
Jimnys are or were produced in several factories worldwide, not just in Japan. Some of those factories strictly adhered to genuine Suzuki specifications, while others had or have certain level of technical "autonomy". The most notable "autonomous" Jimny factories are/were Santana in Spain and a factory in Brazil.
Technical autonomy means that not all mechanical, body or electrical parts of the vehicle are the same as in the genuine Japanese model. One example is tie rod ends - they are different (specific) in some spanish-made Santana model revisions.
Santana made Jimnys primarily for the European market, until 2011 when they went bankrupt.
Therefore, you can find both Japanese-made and Spanish-made Jimnys in Europe. They are visually identical.
So how to determine where the vehicle was made?
It used to be generally presumed that all cabrio Jimnys and all diesel (DDiS) Jimnys were made by Santana, as well as many petrol "closed top" Jimnys. However, there have been confirmed findings of several DDiS Jimnys which were made in Japan. Based on those findings, it can not be certain that all convertible ones are Spanish either.
The only certain way to determine vehicle's birthplace is by its VIN code.
- If the first three digits of Jimny's VIN code are "JSA", then it was made in Japan by Suzuki.
 - If the first three digits of Jimny's VIN code are "VSE", then it was made in Spain by Santana.
 - Only the above two VIN codes should be encountered in Europe. As for the rest of the world, information is lacking (for example, VIN code of Brazilian-made Jimnys). International users are welcome to contribute the missing info.
Santana's Jimnys have their own Owner's manuals and service manuals, which are hard to find since the company is defunct.
Suzuki also has its own factory in Hungary for the European market. However, as far as it is known, that factory has never produced Jimnys. On the other hand, it appears that Suzuki's main European vehicle parts warehouse is located there as well.
Key model changes
- 1998 - circa 2001: Petrol with G13BB engine (59 kW)
 - Circa 2001 - circa 2005: Petrol with M13A engine (62 kW)
 - Circa 2006 - today: Petrol with M13A VVT engine (63 kW)
 - Circa 2003 - Circa 2005: Diesel with K9K 700 engine (48 kW)
 - Circa 2006 - Circa 2011: Diesel with K9K 266 engine (63 kW)
 - Circa 2005 - Front interior completely redesigned (dashboard, instrument panel, controls, ventilation, steering wheel, seats, etc.)
 - Circa 2005 - Manually shifting transfer box replaced with electrically controlled ("push button") transfer box
 - Circa 2006 - 1st gen front bumper replaced with a much deeper 2nd gen front bumper
 - Circa 2012 - 2nd gen front bumper replaced with a slightly smaller 3rd gen front bumper
 - Circa 2012 - Front hood redesigned to have separate grilles from the bonnet with more "aggressive" look
 - Circa 2012 - Additional side impact reinforcements in side doors
 - Circa 2012 - Steering wheel changed
 - Circa 2014 - Electronic Stability Control (ESC/ESP) (selectable) added as mandatory in some markets
 - Circa 2014 - Instrument panel changed
Key models
Suzuki has several ways to generally differentiate Jimnys.
You may encounter these technical model names when browsing through aftermarket parts databases (for example: Febi Bilstein's parts database) or catalogues of vehicle fluids (for example, Castrol's oil catalogue).
Therefore, these models are mentioned here for that purpose.
On the other hand, these model names can not be used to determine the matching manual/document name for a particular vehicle. In order to determine that, you need to determine to which factory "type" your VIN belongs, and then obtain the appropriate documents for that type, according to the tables below.
Differentiation 1
- SN413 is the petrol edition (with any petrol engine)
 - SN415 is the diesel edition (with any diesel engine)
Differentiation 2
- JB33 are early petrol Jimnys with G13BB engine. They have "33" in 7th and 8th VIN code positions.
 - JB43 are later petrol Jimnys with M13 engine (either with or without VVT). They have "43" in 7th and 8th VIN code positions. The currently produced petrol Jimnys are still classified as JB43.
 - JB53 are diesel Jimnys with K9K engine (both early 48 kW non-intercooled and later 63 kw intercooled). They have "53" in 7th and 8th VIN code positions.
Factory types by VINs
Suzuki made several smaller and larger revisions of Jimny through the long production life.
In order to discern their changes, they classified Jimnys in several "types".
A "type" is essentially a technical revision. Therefore, type 1 is the initial model. Type 2 is the first model revision, type 3 the second and so on.
Some revisions are non-visual, and it is very difficult for a normal human being to discern why Suzuki made some revisions (what has actually changed in between).
Also, types (revisions) encompass all vehicle editions (petrol with this or that engine, or diesel with this or that engine). In other words, a type (revision) affects any vehicle edition more or less equally.
All Suzuki's official documentation (user manuals, mechanical service manuals, electrical wiring manuals, etc.) are divided by these types.
In other words, a particular manual is made for only one type (in most cases). Or in more other words, each type has its own set of manuals. But there are exceptions (explained further down below!).
Therefore, if you want to operate or service your vehicle per Suzuki's official documentation, you first need to determine to which "type" (technical revision) your Jimny belongs, and then find the exact Suzuki manuals for that type.
Jimny "types" by VIN ranges
- The tables below contain Jimny VIN ranges divided by types. The purpose of the tables is to determine to which "type" your Jimny belongs, based on its VIN.
 - All the "type" tables below were compiled from official Suzuki documents, which were allegedly dated from Q2 2007.
 - Type 6 Jimny was the newest (and still in production) revision at the time when those source documents were made.
 - Therefore, the information about types 7 and newer is still rather scarce.
 - The first three VIN letters show the country of manufacture: JSA = Japan, VSE = Spain.
 - VSE Jimnys are unfortunately not included here yet, as proper informations about them are still to be found.
A "#" character in certain VIN codes designates that it is a "wildcard" character position which can be any number or letter.
Type 1
| FROM VIN | TO VIN |
| JSAFJA33V00100001 | any higher JSAFJA33V######## |
| JSAFJB33V00100001 | any higher JSAFJB33V0####### |
| JSAFJB33VW4100001 | any higher JSAFJB33VW####### |
| JSAFJB33VX0100001 | any higher JSAFJB33VX####### |
| JSAFJB33VY0100001 | any higher JSAFJB33VY0###### |
| JSAFJB33VY4100001 | any higher JSAFJB33VY4###### |
| JS3JB33V#14100001 | any higher JS3JB33V#1####### |
| JS3JB33V#X4100001 | any higher JS3JB33V#X####### |
| JS3JB33V#Y4100001 | any higher JS3JB33V#Y####### |
| JB33V-100001 | any higher JB33V-###### |
| JB33W-100001 | any higher JB33W-###### |
Notes and known changes concerning type 1:
- Type 1 is the initial (first) production model.
 - Essentially, all Jimnys with "33" in 7th and 8th VIN character positions belong to type 1. Code "33" means that they have G13BB engine.
Type 2
| FROM VIN | TO VIN |
| JSAFJA43V00100001 | JSAFJA43V00140000 |
| JSAFJB43V00100001 | JSAFJB43V00140000 |
| JSAFJB43V10100001 | any higher JSAFJB43V10###### |
| JSAFJB43V14100001 | any higher JSAFJB43V14###### |
| JSAFJB43V20100001 | any higher JSAFJB43V20###### |
| JSAFJB43V24100001 | any higher JSAFJB43V24###### |
| JSAFJB43VW0100001 | any higher JSAFJB43VW####### |
| JS3JB43V#14100001 | any higher JS3JB43V#14###### |
| JS3JB43V#24100001 | JS3JB43V#24140000 |
| JB43W-100001 | any higher JB43W-###### |
Notes and known changes concerning type 2:
- Type 2 is the earliest type where vehicles with M13A petrol engine appear ("43" in 7th and 8th VIN character positions).
 - Although the table 02 does not contain any JSAFJB33# VIN range, there could also be vehicles with G13BB engine in type 2.
 - Basis for suspicion on the presence of G13BB engines - service manual for type 2 clearly mentions servicing information both for G13BB and M13A engine (service manuals for type 3 and later don't mention G13BB at all, only M13A).
Type 3
| FROM VIN | TO VIN |
| JSAFJA43V00140001 | JSAFJA43V00160000 |
| JSAFJB43V00140001 | JSAFJB43V00160000 |
| JSAFJB43V20140001 | any higher JSAFJB43V20###### |
| JSAFJB43V24140001 | any higher JSAFJB43V24###### |
| JSAFJB43V30140001 | JSAFJB43V30160000 |
| JSAFJB43V34140001 | JSAFJB43V34160000 |
| JS3JB43V#24140001 | any higher JS3JB43V#2####### |
| JS3JB43V#34140001 | JS3JB43V#34160000 |
Notes and known changes concerning type 3:
- Changes in type 3 are currently unknown. Contribute information if you know something!
Type 4
| FROM VIN | TO VIN |
| JSAFJA43V00160001 | any higher JSAFJA43V######## |
| JSAFJB43V00160001 | JSAFJB43V00200000 |
| JSAFJB43V30160001 | any higher JSAFJB43V30###### |
| JSAFJB43V34160001 | JSAFJB43V34200000 |
| JSAFJB43V40160001 | any higher JSAFJB43V4####### |
| JSAFJB43V50160001 | any higher JSAFJB43V5####### |
| JS3JB43V#34160001 | JS3JB43V#34200000 |
| JS3JB43V#44160001 | any higher JS3JB43V#4####### |
| JS3JB43V#54160001 | JS3JB43V#54200000 |
| JSAFJB53V00100001 | JSAFJB53V00200000 |
Notes and known changes concerning type 4:
- Type 4 is the earliest type where a diesel (DDiS) edition appears ("53" in 7th and 8th VIN character positions).
 - Type 4 DDiS vehicles use older 48 kW non-intercooled K9K engine.
 - Type 4 is the last type which uses manually shifted transfer box and old style (1st design) interior (dashboard, instrument panel, steering wheel, seats etc.).
Type 5
| FROM VIN | TO VIN |
| JSAFJB43V00200001 | JSAFJB43V00300000 |
| JSAFJB43V60200001 | JSAFJB43V60300000 |
| JSAFJB43V34200001 | any higher JSAFJB43V3####### |
| JS3JB43V#34200001 | any higher JS3JB43V#3####### |
| JS3JB43V#54200001 | any higher JS3JB43V#5####### |
| JS3JB43V#64200001 | JS3JB43V#64300000 |
| JSAFJB53V00200001 | JSAFJB53V00300000 |
Notes and known changes concerning type 5:
- Type 5 is the earliest type which uses electrically ("push-button") shifted transfer box and new style (2nd design) interior (dashboard, instrument panel, steering wheel, seats etc.).
 - Type 5 still uses 1st generation front bumper.
 - Type 5 had a relatively short production time span, approximately only during the second half of 2005.
 - Type 5 DDiS Jimnys still use older 48 kW non-intercooled K9K engine.
 - It is assumed (but not verified) that type 5 is the first type where "VVT" M13A petrol engine is used. If not, then it was certainly used in type 6.
Type 6
| FROM VIN | TO VIN |
| JSAFJB43V00300001 | unknown |
| JSAFJB43V60300001 | unknown |
| JSAFJB43V64300001 | unknown |
| JSAFJB43V70300001 | unknown |
| JS3JB43V#64300001 | unknown |
| JS3JB43V#74300001 | unknown |
| JSAFJB53V00300001 | unknown |
Notes and known changes concerning type 6:
- Front bumper changed from 1st to 2nd generation design.
 - For diesel (DDiS) Jimnys, the major change from type 5 to type 6 is the change of engine - from non-intercooled 48 kW K9K 700 to intercooled 63 kW K9K 266.
 - "VVT" M13A petrol engine was possibly introduced in type 5, but it was certainly used in type 6.
 - Table 06 (type 6) can be relied upon only in the "FROM VIN" column. All limits in the "TO VIN" column are currently unknown because type 6 was still the latest production type in the time when the source Suzuki documents were written in Q2 2007.
Type 7
| FROM VIN | TO VIN |
| unknown | unknown |
| unknown | unknown |
| unknown | unknown |
| unknown | unknown |
| unknown | unknown |
| unknown | unknown |
| unknown | unknown |
Notes and known changes concerning type 7:
- Type 7 is the last type where DDiS (diesel) Jimnys were produced.
 - 4WD controller changed to enable (seemingly) direct shifting from 2WD to 4WD-L and vice versa. The actual technical process still is the same (through 4WD-H), just the sequence is automatic.
Type 8
| FROM VIN | TO VIN |
| unknown | unknown |
| unknown | unknown |
| unknown | unknown |
| unknown | unknown |
| unknown | unknown |
| unknown | unknown |
| unknown | unknown |
Notes and known changes concerning type 8:
- Changes in type 8 are still unknown. Contribute information if you know something!
Type 9
| FROM VIN | TO VIN |
| unknown | unknown |
| unknown | unknown |
| unknown | unknown |
| unknown | unknown |
| unknown | unknown |
| unknown | unknown |
| unknown | unknown |
Notes and known changes concerning type 9:
- Front bumper changed from 2nd to 3rd generation design.
 - New front hood (bonnet) and front grille design.
 - The front grille is separate from the bonnet and looks completely different than the old grille.
 - Bonnet has an integrated fake power bulge (different than the fake bulge on DDiS bonnets).
 - Additional side impact reinforcements in side doors.
 - New steering wheel design.
 - New seats.
 - Electronic stability control (ESC / ESP) function introduced as an optional feature (not verified that it exists at all in type 9!).
 - If ESC/ESP is fitted, it can be turned on/off by operating a switch located in the same switch cluster with the rear fog lamp switch and (if present) front fog lamps switch.
Type 10
| FROM VIN | TO VIN |
| unknown | unknown |
| unknown | unknown |
| unknown | unknown |
| unknown | unknown |
| unknown | unknown |
| unknown | unknown |
| unknown | unknown |
Notes and known changes concerning type 10:
- New instrument panel design.
 - Electronic stability control (ESC / ESP) function introduced as a mandatory feature in certain countries.
 - ESP/ESC can be turned on/off by operating a switch located in the same switch cluster with the rear fog lamp switch and (if present) front fog lamps switch.
Types by approximate years
| TYPE NUMBER | START OF PRODUCTION |
| 1 | 1999 Q1 |
| 2 | 2001 Q2 |
| 3 | 2003 Q4 |
| 4 | ?2004? |
| 5 | 2005 Q2 |
| 6 | 2006 Q1 |
| 7 | 2008 Q? |
| 8 | 2010 Q? |
| 9 | 2012 Q? |
| 10 | 2014? |
- Table 11 gives rough guidelines in which time period a certain type was in production.
 - The data in table 11 was compiled from official production dates of owner's manuals for each type. It can only be presumed that a manual was created at an approximate time when its corresponding type (vehicle revision) was put into production.
 - It is also presumed that the end-of-production time of a certain type is the same as the start-of-production time of a succeeding type. However, it is possible that certain types overlapped (were produced at the same time). Who knows!
 - Table 11 includes only Japanes-made Jimnys ("JSA" in first three VIN character positions). Information on Spanish-made Jimnys ("VSE" in first three VIN character positions) is still unknown!
Official Suzuki manual (document) names by type
The table
After you have hopefully determined to which type your VIN belongs, you can determine which set of manuals is meant for your vehicle.
Most manuals are meant only for one type. However, some manuals "cover" more than one type. All that is deductible from the data in table 12.
Here is the most important table of Jimny manuals with correlation to types:
| Type number  |
Owner's manual  |
Service manual  |
Supplementary service manual  |
Wiring diagram manual  |
| 1 | 99011-81A20-012 | 99500-81A02-01E | Does not exist | 99512-81A00-015 |
| 2 | 99011-81A21-012 | 99500-81A02-01E | 99501-81A00-01E | 99512-81A30-015 |
| 3 | 99011-81A22-012 | 99500-81A10-01E | Does not exist | 99512-81A30-015 |
| 4 | 99011-81A23-01E | 99500-81A10-01E |
99512-81A30-015 |
| 5 | 99011-81A24-01E | 99500-81A10-01E |
99512-81A40-015 |
| 6 |
 see subchapter below  |
99500-81A10-01E |
99512-81A50-015 |
| 7 | 99011-81A29-01E | Online from Suzuki | Online from Suzuki | Online from Suzuki |
| 8 |
| 9 | 99011-81A2D-01E | Online from Suzuki | Online from Suzuki | Online from Suzuki |
| 10 | ? | Online from Suzuki | Online from Suzuki | Online from Suzuki |
Main notes
Absence of suppl. service manual
- When a supplementary service manual does not exist for a certain type, that means that the "baseline" service manual "covers" all servicing information for that type (apart from the electrical/wiring of course).
Presence of suppl. service manual
- When a supplementary service manual does exist for a certain type, that manual should be used primarily instead of the "baseline" service manual for that type.
 - If the needed information is not found in the supplementary service manual, only then should it be searched for in the "baseline" service manual for that type.
Presence of several suppl. service manuals
- Some "types" have several supplementary service manuals, which are displayed in a list (for example, types 5 and 6).
 - In such cases, the last supplementary service manual in the list (lowest position in the list) should be used primarily.
 - If the needed information is not found in it, then a "previous" (next higher) supplementary service manual from the list should be consulted next.
 - The iteration repeats either until the needed information is found, or until the "baseline" service manual is reached, where the information should at last be present.
 - Complicated as flying a rocket, isn't it!?
 - There is something worse than deciphering hieroglyphs after all!
 - At least you can feel like Indiana Jones while hunting for the needed information from Suzuki manuals!
 - I bet that the wise idiot who designed this "incremental" documentation system (and saved the company some paper) is very proud of himself.
Letter code suffixes
- Some manuals have a letter code suffix in their technical name (for example: Type 4 owner's manual is 99011-81A23-01E).
 - That suffix designates the language of the document (E = English, F = Français, G = Deutsch, S = Español).
 - Therefore, if you are seeking for a document edition written one of those other languages, replace the suffix letter "E" with the corresponding one (F, G or S).
 - If a document's technical name in table 12 does not have a letter suffix, that means that the document is written in multiple languages, so it has no separate language-specific editions.
- There is one exception the the above mentioned rule about documents' language editions: The French, German and Spanish editions of the document 99500-81A02-01E (type 1 and type 2 service manual) are 99500-81A00-01F|G|S respectively.
 - In other words, the English edition's naming is "out of rule", as the "base" name of the document is 99500-81A00-XXX.
Air conditioning manual
- There also exists an "Air conditioning basic manual" which is generic to most Suzuki vehicles from 1990s and 2000s.
 - The technical name of the manual is 99520-02130.
 - When servicing the air conditioning system, that manual should be consulted only if the needed information is not found in your vehicle's supplementary or "baseline" service manual's chapter about the air conditioning system.
Additional notes for certain documents
Obsolescence of wiring manual 99512-81A20-015
- Service manual 99500-81A10-01E contains a reference in its second page to wiring diagram manual 99512-81A20-015 as a directly related manual.
 - However, that wiring manual has been superseded (replaced) by the wiring manual 99512-81A30-015, which contains all the content from the older manual and some more.
 - Therefore, the older manual is not written in table 12, while the newer one is.
Obsolescence of wiring manual 99512-81A10-015
- Supplementary service manual 99501-81A00-01E contains a reference in its third page to wiring diagram manual 99512-81A10-015 as a directly related manual.
 - Therefore, the older manual is not written in the table 12, while the newer one is.
Documentation for type 7 and newer
- You might have noticed in table 12 that the names of service documents for type 7 and newer are stated as "Online from Suzuki" in the table.
 - Reason: Starting with type 7, Suzuki stopped publishing service manuals for that and further Jimny revisions.
 - Instead, the servicing documentation is available from Suzuki exclusively through an online subscription for selected partners.
 - Therefore, if your Jimny is type 7 or newer (production year circa 2008 and newer), you can either obtain the last available printed or PDF manual for type 6 (revision from 2006) (and hope that it does not differ much from your vehicle), or obtain access to Suzuki's online documentation database, somehow.
Multiple owner's manuals for type 6 and 8
- As evident from table 12, type 6 and 8 have multiple owner's manuals.
 - The reason is that, for types 6 and 8, there were some revisions even within a single technical type, and therefore Suzuki had to change owner's manuals in the middle of a certain type production.
 - Apparently they did that several times for type 6.
- It appears that most of those inner-type revisions in types 6 and 8 were minor.
 - Most changes deal with inclusion or changes of some regulatory certificates and other paperwork for certain countries.
 - This mostly affected things like the air bag system, ABS system, seat belts, child restraint seats and anchors, wireless (keyless) door locking system, engine immobilizer, etc.
 - Some technical details in those systems might have changed as well to satisfy the changing regulations.
 - Remember, later half of 2000s was the time when many countries in the developed world started to intensively regulate many safety and usability affairs regarding vehicles and communication systems in general.
- So, if your vehicle is type 6 or 8, only one of those multiple owner's manuals is for you.
 - So how to determine which one?
 - The tables below contains VIN ranges for each of those multiple owner's manuals.
| FROM VIN | TO VIN |
| Start of Type 6 | JSAFJB43V00326734 |
| Start of Type 6 | JSAFJB43V80300001 |
| Start of Type 6 | JS3JB43V#64300999 |
| Start of Type 6 | JS3JB43V#74302038 |
| Start of Type 6 | JS3JB43V#84300001 |
| Start of Type 6 | JSAFJB53V00313302 |
| FROM VIN | TO VIN |
| JSAFJB43V00326734 | JSAFJB43V00329354 |
| JSAFJB43V80300001 | JSAFJB43V80300061 |
| JS3JB43V#64300999 | JS3JB43V#64301148 |
| JS3JB43V#74302038 | JS3JB43V#74302335 |
| JS3JB43V#84300001 | JS3JB43V#84300085 |
| JSAFJB53V00313302 | JSAFJB53V00315309 |
| FROM VIN | TO VIN |
| JSAFJB43V00329354 | JSAFJB43V00340001 |
| JSAFJB43V80300061 | JSAFJB43V80340001 |
| JS3JB43V#64301148 | JS3JB43V#64301512 |
| JS3JB43V#74302335 | any higher JS3JB43V#7####### |
| JS3JB43V#84300085 | JS3JB43V#84300944 |
| JSAFJB53V00315309 | JSAFJB53V00340001 |
| FROM VIN | TO VIN |
| JSAFJB43V00340001 | JSAFJB43V00344139 |
| JSAFJB43V80340001 | JSAFJB43V80340131 |
| JS3JB43V#64301512 | JS3JB43V#64301799 |
| JS3JB43V#84300944 | JS3JB43V#84301682 |
| JSAFJB53V00340001 | JSAFJB53V00343059 |
| FROM VIN | TO VIN |
| JSAFJB43V00344139 | End of type 6 |
| JSAFJB43V80340131 | End of type 6 |
| JS3JB43V#64301799 | End of type 6 |
| JS3JB43V#84301682 | End of type 6 |
| JSAFJB53V00343059 | End of type 6 |
| FROM VIN | TO VIN |
| Start of type 8 | JSAFJB43V00524710 |
| Start of type 8 | JSAFJB43VC4100001 |
| Start of type 8 | JS3JB43V#B4203125 |
| FROM VIN | TO VIN |
| JSAFJB43V00524710 | End of type 8 |
| JSAFJB43VC4100001 | End of type 8 |
| JS3JB43V#B4203125 | End of type 8 |
This is the end of the article (for now ...).
Page last edited on 9/02/2017 by user Bosanek
