- Clicking when in 4WD when turning
- Banging and snatching of the steering wheel
- Loss of 4wd
CV joint information
Suzuki uses two different CV joints in the Jimny. One is straight forward to purchase on the parts market and the other is nearly impossible to source.
- Type 1: 6 balls, 26 external splines and 19 internal splines. - BigJimny Store NTN 75LAC CT9U)
- Type 2: 8 balls, 26 external splines and 29 internal splines. - BigJimny Store (possibly marked NTN EBJ82 although NTN call it an 8-Ball CV)
| Model | Balls | Inner Splines | Outer Splines | Outer Case Dia | Inner Case Dia | Shaft Dia |
| NTN BJ75LAC | 6 | 19 | 26 | 91.6mm | 72.6mm | 19.0mm |
| NTN EBJ82 | 8 | 29 | 26 | 91.6mm | 72.6mm | 21.2mm |
NTN 75LAC CV Joint
NTN 75LAC CV Joint
NTN 75LAC CV Joint - 26 Outer splines
NTN 75LAC CV Joint - 19 inner splines
NTN 75LAC CV Joint
NTN 75LAC CV Joint
Changing the CV joint
- Assorted screwdrivers
- Circlip pliers (External)
- A ball joint splitter
- 1" Imperial Socket
The Video
Removing the Caliper and pads
Removing the Brake Disc
Dismantling the Hub
Re-assembly
- You may wish to change the kingpin bearings and oil seals at this point if you wish.
- Again the BigJimny shop sells suitable sealant.
Page last edited on 31/01/2017 by user Mlines
