Revision as of 19:28, 25 January 2017 by Bosanek (talk | contribs) (Some small wiki code adjustments)
CV joint replacement
  • Clicking when in 4WD when turning
  • Banging and snatching of the steering wheel
  • Loss of 4wd
CV joint information
Suzuki uses two different CV joints in the Jimny. One is straight forward to purchase on the parts market and the other is nearly impossible to source.
  • Type 1: 6 balls, 26 external splines and 19 internal splines. - Easy to source (one I have is marked NTN 75LAC CT9U)
  • Type 2: 8 balls, 26 external splines and 29 internal splines. - Difficult to source, 6 Ball Jakoparts J2828040 is supposed to fit. (possibly marked NTN EBJ82 although NTN call it an 8-Ball CV)
I can get Type 1 for you, I just do not stock it as too many people bought the wrong one and wanted to return it.
Model Balls Inner Splines Outer Splines Outer Case Dia Inner Case Dia Shaft Dia
NTN BJ75LAC 6 19 26 91.6mm 72.6mm 19.0mm
NTN EBJ82 8 29 26 91.6mm 72.6mm 21.2mm
NTN 75LAC CV Joint
Changing the CV joint
  • Assorted screwdrivers
  • Circlip pliers (External)
  • A ball joint splitter
  • 1" Imperial Socket
The Video
Removing the Caliper and pads
Jimny Front Caliper
  • First of all secure the car.
  • Release the wheel nuts and jack up the car and remove the road wheel.
  • This then reveals the brake caliper.
  • The picture shows the passenger side (nearside) caliper (UK).
Unbolting the caliper
Open brake caliper
Removing the brake pads
  • If the pads resist, gently prise out the pads with a small screwdriver - do not remove the spring clips).
Removing the Brake Disc
Carrier bolt
  • The caliper is held on with two bolts at the rear (see below).
Caliper tied to Spring
Disc removal using bolt
  • If you are lucky it will simply pull off, but if you have problems then there are two M8 holes in the disk hub.
  • My disk appeared to be ok on the visible side but the rear showed some bad wear so I will change them as part of this job.
  • New disks are available in the BigJimny Store.
Dismantling the Hub
Torx bolt on hub
Removing the circlip
  • With the hub removed, the driveshaft is exposed.
  • The driveshaft is retained with a circlip, so use a pair of circlip pliers to remove it.
removing a vacuum pipe
  • Gently pull the two vacuum hoses for the hub from the knuckle, making sure you note which one connects to each pipe.
  • It is essential that you get this correct else the hub will not work again.
  • Also note that if you have an ABS equipped vehicle then you will have to remove the sensor.
  • I do not have photos of this but the video shows it.
Removing the swivel seal bolts
  • At the rear of the hub, release the small bolts holding the seal and retainer.
  • You can see that the swivel hub is covered in oil, a bad sign for KingPin problems.
Splitting the ball joint
  • Undo the nuts on the steering joints.
  • If the joint rotates, then put a jack under the joint and lift the car slightly to lock the joint.
  • Using a splitter, split the steering joints (two to do on the passenger side and one on the drivers side – UK).
undoing the Kingpin bolts
  • Finally, release the KingPin bolts themselves.
  • There are two sets, top and bottom and they must not be mixed.
  • You can see in the picture that I have marked them up with a letter T.
  • If you are doing both sides at once then do not mix them across either!.
  • The KingPins are also held in with sticky sealant so you will need to prise them out.
  • The hub will now pull off and the driveshaft can be removed.
  • Depending on how broken the CV is, the shaft may come out in two pieces.
  • The next stage is to CLEAN, CLEAN and then CLEAN again.
  • Clean the swivels inside and out, clean the knuckles and make sure all broken CV parts are removed.
Removing the C-Clip
  • The CV Joint is held on the driveshaft by a hidden C-Clip.
  • The only way to dismantle a whole CV Joint (yours may already be in bits if you have really broken it!) is to drive the joint off with a hammer.
  • Clamp the driveshaft into a vice and, holding the joint VERY straight, hit the cup with a hammer and drive it off.
New CV Joint
  • Now put the new C-clip onto the shaft and tap the new joint into place.
Re-assembly
  • This is basically the reverse process.
  • You may wish to change the kingpin bearings and oil seals at this point if you wish.
  • If you are changing the large seal then now is the time to put the new one on.
  • The confusing part is the order of the seals and rings on the swivel, the picture below is of the correct orientation, note also that the slits in the retainers go to the top.
The greased CV joint
  • Pack the CV with grease (but do not overpack) and re-fit the driveshaft.
  • A suitable waterproof grease is available in the BigJimny Shop.
Applying sealant
  • Grease the new KingPin bearings and insert the top one in the carrier.
  • I find the easiest way to grease the bearings is to put them in a polythene bag with some grease and use the bag to squeeze the grease into the bearing, this can be seen in the video. (picture needed here).
  • Carefully insert the new bottom bearing and, holding it in place, slide the whole knuckle onto the hub.
  • Fill the Knuckle with 100ml of grease, Suzuki recommend only 100ml and not to overfill.
  • Now the KingPins need to be inserted, but first they need a bead of sealant around the KingPin.
  • Again the BigJimny shop sells suitable sealant.
  • Make sure that you have put the correct Kingpin in place.
  • Remember you should have marked them when you dismantled them!
  • Bolt the Kingpins in and tighten them to the correct torque (18ft/lbs).
  • Refit the steering arm (or arms if it is the side with two connections), tightening the nuts to 31ft/lbs.
  • Fit the disk and fit the caliper (Caliper bolts 61ft/lbs), brake pads and bolt the caliper down in position (Caliper pin bolt 16/ft/lbs).
