Rebuild
 - Range of impact sockets used to press in bearings
 - 2 large flat head screw drivers
 - a 2 leg gear puller and/or hydraulic press
 - bearing seperator
 - torque wrench(s) to cover 23-90Nm
 - copper or plastic mallet
 - sturdy metal tube of approx 25mm internal diameter, at least 130mm long; but see text for alternatives
Gearbox Removal
Dismantling
Remove gear shift locating bolts (red arrows in above picture), springs and ball bearings (not shown). The bearings can stick in the shafts. If you can't them out at this stage losely refit a bolt in the corresponding hole so you don't lose the bearing when you start to remove the gear shafts.
Full details of the torque settings can be found in the  reference data
Page last edited on 18/01/2017 by user Sheepish
