This article is in the early process in the making! It should receive significant expansion in the near future.
Suzuki used to produce a factory diesel edition of Jimny, primarily for the market of Western Europe (excluding United Kingdom).
The model name for diesel Jimny edition is JB53. Its technical model name is SN415.
The marketing name for diesel Jimnys is "DDiS".
DDiS Jimnys were most popular in Portugal, Spain, Italy and France. A rough estimation is that almost every second Jimny in those countries, which was sold in the period 2003-2011, was DDiS.
DDiS Jimnys also had minor to moderate presence in other European countries. Notable examples are Belgium, Germany and Austria. A rough estimation is that two in every ten sold Jimnys in those countries, in the period 2003-2011, were DDiS.
Note: DDiS Jimnys have never been available in United Kingdom.
Since DDiS Jimnys were produced "only" between 2003 and 2011, while petrol Jimnys are in production since 1998 and still ongoing in 2017, DDiS Jimnys are relatively rare even in Europe.
Therefore, a potential Jimny buyer would normally be concerned what parts for the relatively rare DDiS Jimnys are specific to them, and how difficult is it to obtain those parts. Also, their concern is about servicing the diesel engine and other DDiS specifics.
Existing DDiS Jimny owners are struggling to find technical or service information about DDiS Jimnys, because there is hardly anything written about DDiS Jimnys in English language on the Internet.
Advantages and disadvantages of DDiS versus petrol
Advantages
- Overall fuel consumption is probably the lowest among any proper all-terine vehicle model ever produced.
- Engine's RPM-torque curve is much more biased towards 1500-2000 RPM range, which is excellent for offroad driving;
- Has a mean looking power bulge on the bonnet, which is different and larger than the power bulge on post-2012 petrol Jimnys;
- Engine sounds mean and utilitarian, making the vehicle appear like a larger serious 4WD truck both from inside and from outside.
Disadvantages
- Availability limited to certain European countries, and in most of them it is rather rare;
- The engine weights cca 100 kg more, so vehicle's already unbalanced front-to-rear weight distribution is further worsened - further increasing vehicle's tendency to oversteer in bends, lose traction on uphill bends, or especially when going uphill in reverse (all in 2WD mode);
- The engine is noisier and certainly vibrates more than the petrol, decreasing interior comfort;
- The overall reliability of Renault's 1.5 DCI diesel engines is not even close to the excellent reliability of Suzuki's M13 petrol engines.
- Vehicle is a half-breed of two completely different vehicle manufacturers. It has Renault's engine and some engine peripherals, with Suzuki's vehicle computer and some engine peripherals. So, if it develops a complicated engine issue, you will be stuck (or stretched) between two sides. Only Suzuki workshops can read and change all genuine failure/diagnostic codes, descriptions and settings, but most of those workshops have no experience and knowledge about Renault's engines. On the other hand, Renault workshops have the best knowledge and experience about servicing Renault engines, but no proper access to vehicle's ECU. You will most probably have to move the vehicle back and forth between those two to completely resolve the issue (if the two sides are that cooperative)!
DDiS revisions
- The "1.5th" generation corresponds to "Type 5" Jimny revision in Suzuki's official technical classification;
- The 2nd generation corresponds to "Type 6" Jimny revision in Suzuki's official technical classification;
Note: For more information about Jimny "types", see wiki chapter Manuals and owner guides;
- The 1st DDiS model was produced from 2003 to the first part of 2005.
- The 2nd DDiS model was produced from the end of 2005 to approx 2011. The second model had several minor revisions.
The change from 1st to 2nd DDiS model occurred at the same time period when all Jimnys (both petrol and diesel) changed from manually operated 4WD transfer box to electrically operated (push-button) transfer box and from 1st generation interior trim to 2nd generation interior trim and from 1st generation front bumper to 2nd generation front bumper. This transition occurred during the second half of 2005.
- Change of engine from 48 kW (65 HP) to 63 kW (86 HP) by the addition of an intercooler.
- Different fuel filter;
- Different electrical generator and alternator;
- Different air conditioning system and piping;
- Different turbo charger;
- Different engine sensors (crankshaft, camshaft, lambda, etc.);
- Change from 1st generation to 2nd generation front bumper (see wiki article Front bumper issues#"Front bumper issues");
The summary of the changes in the engine bay is that, while the basic engine block might have remained the same, most of the peripheral engine components have changed, and an intercooler was added. This resulted in significant power and torque increase (from 160 Nm to 200 Nm). Fuel consumption remained the same, which is officially 5,6 l/100km extra-urban, 7,0 l/100km urban and 6,1 l/100km combined.
Apart from the changes in the engine bay, the other changes were:
- Different front bumper; (see note above)
- Different interior trim; (see note above)
- Different transfer box; (see note above)
The new intercooled 65 kW dCi engine requires the use of 2nd generation front bumper (to accommodate the intercooler and to feed it with air). That is why the 2nd generation front bumper was invented in the first place, but Suzuki sadly decided to bolt it onto every petrol Jimny as well from 2006 until 2012.
To be continued soon ! ...
Page last edited on 17/01/2017 by user Bosanek
