Types of vehicle lifts
- Body lift
- Suspension lift (UK: called a spacer lift)
- Longer suspension (UK: called a suspension lift)
Note: The vehicle can also be lifted by installing larger (taller) tyres, which is the only way to lift the axles as well as the entire vehicle. See wiki article "Tyre selection and usage - best practices" for full details.
Body lift
Therefore, body lift does not raise any component of the chassis or the underbody away from the ground. A key benefit is that the steering is unaffected by a body lift.
- To look cool or mean on a budget (if that turns you on)
- To increase clearance between the wheels and body panels around the wheels. This then enables fitment of larger tyres, which in turn lift the entire vehicle.
Suspension lift
Installing longer suspension
Benefits, issues and risks
Benefits
- Vehicle lifts make your vehicle look cooler or nastier (if that turns you on).
- Vehicle lifts increase the ride height, increasing your self esteem.
- Vehicle lifts improve vehicle's off roading potency, as well as your own.
- Vehicle lifts make you feel you've finally done something significant to your vehicle.
Issues
- Suspension lift or longer suspension can significantly distort or even disrupt some vehicle's systems (steering, brake, transmission).
- Suspension lift or longer suspension can financially quickly spiral out of control, as they might require extensive modifications of suspension, steering and driveline components in order to compensate for technical issues.
Risks
- Vehicle lifts will make a car more unstable on the road. This is especially pronounced with suspension lift and longer suspensions.
- In some countries, in order to make the vehicle road legal, it is compulsory to perform some vehicle recertification after applying any modification the vehicle. A vehicle lift is certainly a BIG modification.
- Larger lifts may not be made road legal in some countries.
UK readers: Most modifications are permitted if your insurance company will insure the vehicle and it will pass the annual MOT test. A rule of thumb is that once you start cutting parts like the chassis then an SVA is required.
Modifying a vehicle can have legal consequences in some countries! The reader is responsible for checking on the local rules in their country
Additional considerations
For frequent road use, it is recommended to stick with a 2" suspension lift.
Lift kit comparisons
| Spring comparison | ||||||||||||
| Manufacturer | Model Number | Location | Free Height (mm) | Spring rate (lbf/in) | Notes | |||||||
| A | B | |||||||||||
| Stock | 41111-81A20 | Front | 335 | 335 | 120 | Wire 10.3mm 7.25 turns | ||||||
| Rear | 288 | 288 | 120 | Wire 10.3mm 7.25 turns | ||||||||
| King | KSFR-36EH | Front | 365 | 365 | 140 | |||||||
| KSRR-37H | Rear | 325 | 325 | 165 | ||||||||
| OME 40mm | 2965 (petrol) | Front | 365 | 365 | 146 | Wire 11.5mm 10 turns | ||||||
| 2969 (diesel) | Front | 360 | 360 | 170 | Wire 12mm 9.5 turns | |||||||
| 2966 (RHD) | Rear | 335 | 315 | 176 | Wire 12mm 10 turns | |||||||
| 2967 (LHD) | Rear | 325 | 325 | 176 | Wire 12mm 9.5 turns | |||||||
| Dobinson | C57-046 | Front | 355 | 355 | 170 | |||||||
| C57-053 | Rear | 340 | 340 | 165 | ||||||||
| Trailmaster 2" | 76043 (petrol) | Front | 368 | 368 | 148 | Wire 12mm | ||||||
| 75053 (diesel) | Front | 353 | 353 | 205 | Wire 13mm | |||||||
| 76143 | Rear | 326 | 326 | 188 | ||||||||
| Trailmaster 3" | 76086 | Front | 368 | 368 | 228 | |||||||
| 76186 | Rear | 355 | 355 | 240 | ||||||||
Source:
- Stock - 2015 OME International Application Catalogue
- King - King Springs Sales and Technical Services
- OME - 2015 OME International Application Catalogue
- Dobinsons - Dobinsons Spring and Suspension International Sales
- Trailmaster - Maas Group GMBH and co.
Kits
Standard Jimny
An unmodified 2005 VVT Jimny (UK) for comparison.
Trailmaster 2" Lift kit
The Trailmaster 2" Lift
(see BigJimny Store )
Trailmaster 3" lift
Jimny fitted with Trailmaster 3" lift components
Jimnybits 2" Body lift
Jimny fitted with Jimnybits 2" Body lift
Jimnybits 2" Body lift & 2" Spring Lift
Jimny fitted with combined Jimnybits 2" Body lift and 2" Spring lift (AVO shock version)
JimnyBits 2" lift
Jimny fitted with JimnyBits 2" lift kit
KAP Suzuki 3" lift
Jimny fitted with KAP Suzuki 3" lift kit
Tough Dog 120mm lift
Jimny fitted with Tough Dog 120mm Lift (Australia)
Note: I think the 120mm lift is an 80mm lift with extra spacers?
Conclusion
Page last edited on 30/12/2016 by user Mlines
