Support this project: The information on this page is free, but it took a lot of work to gather, test and write up. If it has been useful to you, you can say thanks with a donation at buymeacoffee.com/bigjimny.
Suzuki Jimny JB74 - CAN bus devices and the commands they answer
Status: work in progress. This page lists every module that answered on the OBD socket (DLC) of one RHD UK-market 2021 Jimny, its request and reply CAN IDs, and the diagnostic commands seen so far. Many sections are short because only identification and fault-code requests have been captured. See OBD2 Diagnostics reading project for how the captures were made and for the TPMS data in detail.
How the CAN bus works
Every module on the car does two separate jobs on the CAN bus: it broadcasts its own messages all the time, and it answers diagnostic requests when a scan tool asks.
One shared bus
CAN is a pair of wires that all the modules are connected to. When one module transmits, every other module on that bus receives the frame. A frame has no "to" or "from" address, only:
- an ID (for example
0x3D0), which names what the message is, not who sent it or who it is for; - up to 8 data bytes.
Each module listens for the IDs it needs and ignores the rest. Each ID is normally sent by only one module, but because the sender is not part of the frame, the sender of each broadcast on this page is inferred.
The ID also sets the priority: if two modules start to transmit at the same moment, the lower ID wins and the other waits. That is why fast, important messages have low IDs (engine speed on 0x124 every 10 ms, wheel speeds on 0x1B8 every 12 ms), body messages are in the 0x3xx range every 100 ms, and diagnostic requests use 0x7xx and similar.
Job one: broadcasting (what the car runs on)
As soon as a module is powered, it sends its own messages at a fixed rate, whether or not anything is listening (see the start-up sequence). Any module that needs a value simply reads it from the bus. Examples from the vehicle bus captures:
| Message | Probably sent by | Used by (examples) |
0x3D0 lamp and flasher states |
Body control module | Instrument cluster: lights-on tell-tale, indicator repeater arrows and ticker |
0x3C1 stalk positions |
Combination switch | Body control module, which switches the bulbs through its own wiring |
0x314 vehicle speed |
ABS or engine ECU | TPMS controller (bytes 82–83 of its data block match it exactly), instrument cluster, power steering |
0x3BA and 0x3E2 Comfort/Loaded setting |
Instrument cluster and TPMS controller | Each other |
One broadcast of vehicle speed therefore serves the speedometer, the power steering, the TPMS and anything else that needs it, without any module asking for it. The meaning of each broadcast byte is Suzuki's own layout and is not published, which is why it has to be worked out from captures.
Job two: diagnostics (only when a tool asks)
Each module also has a diagnostic request ID and reply ID, such as 0x271 and 0x671 for the body control module. These IDs are silent until a scan tool sends a request. For example, SZ Viewer sends 21 08 ("read local data block 08", KWP service 21) on 0x271, and the module answers on 0x671 with 61 08 followed by its data. A reply longer than 7 bytes is split over several frames (first frame 10 …, then 21 …, 22 …), with the tool sending a 30 flow-control frame to say "carry on"; this is ISO-TP.
The diagnostic data blocks mostly repackage values the module already has (voltages, switch states, sensor readings) so that a technician can see them. The car never uses this channel to run itself.
| Broadcast | Diagnostic | |
| Example (body control module) | 0x3D0, 0x3D4 and others (probably) |
0x271 request, 0x671 reply
| When sent | All the time, every 10 ms to 1 s | Only when a tool asks |
| For | Any module that wants it | The tool that asked |
| Meaning of the bytes | Suzuki's internal layout, not published | Standard KWP or UDS services, with Suzuki-specific data blocks |
Bus layout
The central gateway is the hub. Three separate two-wire lines leave it, and nothing passes from one line to another except through the gateway:
OBD socket
diagnostic line
E-call -- e-call line ---------| CENTRAL |
module | GATEWAY |
vehicle bus (red/white pair)
Engine ECU ====+======+======+========+======+======+======+==== Instrument
(bus end) | | | | | | cluster
| | | | | | (bus end)
every other module on the car's CAN (table below)
- Diagnostic line: only the OBD socket. It carries nothing until a scan tool is plugged in.
- E-call line: only the E-call controller, on its own pair (on models with e-call).
- Vehicle bus: every other CAN module, on the red/white pair. Its two ends, each with a 120 Ω terminating resistor, are the engine ECU and the instrument cluster; the other modules connect along its length.
| Group | Module on the vehicle bus | Diagnostic request ID | Notes |
| Engine and drivetrain | Engine ECU | 0x7E0 | One end of the bus |
| 4WD controller | 0x772 | ||
| Automatic gearbox controller | none on the test car | Automatic models only | |
| Chassis and safety | ABS / ESP | 0x261 | |
| Power steering (EPS) | 0x263 | The easiest place to connect to the bus | |
| Dual sensor brake support | 0x778 | Models with brake support only | |
| Airbag (SRS) | 0x793 | ||
| Body and driver | Instrument cluster | 0x274 | The other end of the bus |
| Body control module | 0x271 | ||
| Lighting and turn switch | 0x79A | On the bus on models with automatic headlights, such as the test car | |
| TPMS controller | 0x798 | Models with TPMS only | |
| Headlight levelling controller | none on the test car | Models with automatic headlight levelling only |
Why the e-call controller has a line of its own (the reasons are not published; these are the likely ones):
- It has to work after a crash. eCall is a legal requirement in the UK and EU, and the unit must be able to make the emergency call after a serious impact. By then the vehicle bus may be cut, shorted or flooded with errors from damaged modules. On its own line, with only the gateway at the other end, a fault on the vehicle bus cannot silence it.
- Security. The e-call controller holds a mobile modem and SIM, the one part of the car that talks to the outside world. Keeping it behind the gateway means it cannot put messages straight onto the bus that carries the brakes, steering and engine; the gateway decides what passes.
- Traffic. Its messages stay off the vehicle bus.
Not on CAN at all: the horn, the front wiper switch and the hazard switch. Captures show no message for any of these switches; they are wired to their relay or to the body control module. The hazards' flashing does appear, as the body control module's flasher message (see the vehicle bus captures).
Where the gateway fits
The central gateway sits between the OBD socket and the vehicle bus. It passes diagnostic requests from the socket to the modules and their replies back, but it does not copy the everyday broadcasts out to the socket. So:
- at the OBD socket, only diagnostic requests and replies are seen (most of this page);
- at a module connector behind the gateway (see direct access), all the broadcasts are seen, plus any diagnostic requests the gateway passes in.
Two things worth knowing
- Every module acknowledges every frame. A CAN tool in its normal mode joins in with those acknowledgements, so it becomes part of the bus. In listen-only mode it is a silent observer, which is the safe way to connect to the vehicle bus.
- Not everything is on CAN. A module only broadcasts what another module needs. The instrument cluster needs the indicator state for its arrows, so that is on CAN; the horn and the front wiper switch did not appear on the bus at all and are probably wired directly.
How to read this page
- All IDs are 11-bit CAN IDs on the OBD socket (pins 6 and 14, 500 kbit/s). The "request ID" is the header a tool sends to; the "reply ID" is where the module answers.
- Commands are shown as the payload bytes in hex, without the ISO-TP length byte. Replies longer than 7 bytes are sent as several frames; the tables show them reassembled.
- KWP-style modules use services such as
1A(read ECU identification) and18(read DTCs by status). UDS-style modules use22(read data by identifier) and19(read DTCs). - The reply ID is not always the request ID plus 8: the engine is +0x08, the 0x261 to 0x274 group is +0x400, and all others are +0x10.
- Identification strings are ASCII Suzuki part numbers. The first one in each module (
1A 8Eor22 F1 01) has no trailing character; the second (1A 8Aor22 F1 88) ends in*. They do not always equal the number printed on the module's label. - Commands marked captured were seen in a trace. Nothing here has been sent to a module by us except the TPMS requests.
Example usage
This example reads the TPMS controller (request ID 0x798) with an ELM327 adapter in a terminal app. Use a terminal that sends a carriage return (CR) at the end of each line, with the ignition on. Send the commands one at a time and wait for OK after each.
| Command | Purpose |
ATZ |
Reset the adapter (prints the adapter version, not OK) |
ATSP6 |
Use protocol 6: ISO 15765-4, 11-bit CAN, 500 kbit/s |
ATSH798 |
Send requests to the TPMS controller (see device table above) |
ATS0 |
No spaces in the reply (stops one clone adapter overflowing its buffer) |
ATL0 |
No line feeds in the reply |
ATFCSH798 |
Send flow-control frames to 0x798 (see device table above) |
ATFCSD300000 |
Flow-control data 30 00 00: continue, send all frames, no delay
ATFCSM1 |
Use the custom flow-control header and data above |
2100 |
Request the sensor data block (service 0x21, identifier 0x00) ( see device specific tables below) |
Example reply (generic ELM327 clone, ignition on, engine off):
2100 066 0:610075010000 1:0000000000004E 2:AA094310397901 3:4900DD91B52520 4:3B880149004EAA 5:0319183C830249 6:004EAA09C9083C 7:83024900000000 8:004EAA09434EAA 9:09434EAA09434E A:AA094373737373 B:7D7D7D7D000000 C:00000000000000 D:00000030222202 E:01801700000000
Reading the reply:
066is the total length in hex: 0x66 = 102 bytes. The lines0:toE:carry those bytes in order.- The data starts
61 00(positive reply to21 00). The next byte,75= 117, is the module supply voltage in tenths of a volt: 11.7 V (confirmed against SZ Viewer, see #Sensor data block (21 00) layout). - Each wheel has a 10-byte record. Byte +6 of the record is the pressure; bar = raw x 0.01372.
| Wheel | Record (hex) | Byte +6 | Raw | Pressure |
| Front left | 4E AA 09 43 10 39 79 01 49 00 |
79 |
121 | 1.66 bar |
| Rear left | DD 91 B5 25 20 3B 88 01 49 00 |
88 |
136 | 1.87 bar |
| Rear right | 4E AA 03 19 18 3C 83 02 49 00 |
83 |
131 | 1.80 bar |
| Front right | 4E AA 09 C9 08 3C 83 02 49 00 |
83 |
131 | 1.80 bar |
Notes:
- The sensor IDs, and the byte values, are from one car. Your IDs will differ, and the values change with pressure and temperature.
ATSHand theATFCsettings last until the adapter is reset (ATZ) or loses power, so send them again after either.- Without the
ATFClines, the clone adapter used here returned only the first line (610075010000). - If the terminal prints
NO DATA, check the ignition is on, that no other app is connected to the adapter, and thatATSH798was sent after the last reset.
Device table
| Request ID | Reply ID | Style | Module | Identification reply (first / second) | How the module was identified |
| 0x7E0 | 0x7E8 | KWP | ECM | 33980-78R0 / 33980-78RC* | Standard engine address |
| 0x261 | 0x661 | KWP | ABS (inferred) | 56100-77RA / 56100-78RF* | Only brake module left by elimination; SZ Viewer reads it under its ABS/ESP tab (inferred) |
| 0x263 | 0x663 | KWP | EPS controller | 38720-77R0 / 38720-77R0* | Parts catalogue (38720-77R01) |
| 0x271 | 0x671 | KWP | Body control module | 36775-77R0 / 36775-77RC* | Parts catalogue (36775-77RC2 to RC4) |
| 0x274 | 0x674 | KWP | Instrument cluster | 34100-78R0 / 34110-78RD* | Rev counter sweep test |
| 0x798 | 0x7A8 | KWP | TPMS controller | 37160-61M0 / 37120-78R0* | Label (Model No. P61M0) and parts catalogue |
| 0x79A | 0x7AA | KWP | Combination switch (lighting and turn) | 37210-74PA / 37210-74PE* | Parts catalogue (37210-74PE2) |
| 0x778 | 0x788 | KWP | Dual sensor brake support (inferred) | 33990-52R0 / 33990-78R8* | By elimination |
| 0x793 | 0x7A3 | UDS | Airbag (SRS) controller | 38910-77R0 / 38910-78RC* | Parts catalogue (38910-78RC0) |
| 0x772 | 0x782 | UDS | 4WD shift controller | 38885-77R0 / 38885-78R0* | Parts catalogue (38885-78R01) |
| 0x799 | 0x7A9 | UDS | E-call controller | 38960-78RA / 38960-78RA* | Parts catalogue (38960-78RA0, RA1) |
| 0x751 | 0x761 | UDS | Central gateway | 33580-79R0 / 33580-78R0* | Label (33580-79R01) and parts catalogue |
The Launch and SZ Viewer scans also probed 27 more addresses that did not answer.
The names marked "inferred" are guesses from elimination and part-number series, not confirmed by a label or test.
0x7E0 ECM
Models: JB74 (2018+, tested on 2021) — untested on: JB64, JC74, JB43
Request 0x7E0, reply 0x7E8. This is the standard OBD engine address. It is the only module that answers standard OBD requests sent to the functional address 0x7DF (see below).
| Request | Reply | Meaning |
3E |
7E |
Tester present (captured) |
3E 01 |
7F 3E 12 |
Refused: sub-function not supported (captured) |
1A 8E |
5A 8E + ASCII 33980-78R0 |
ECU identification (captured) |
1A 8A |
5A 8A + ASCII 33980-78RC* |
1A 90 |
5A 90 + 17 ASCII characters |
The car's VIN (captured; not reproduced here) |
1A 9E |
5A 9E + ASCII 10SW030025 |
Unknown identification string, perhaps a software or calibration number (captured; meaning inferred) |
1A 87, 1A 88, 1A 9C, 1A 9D |
7F 1A 12 |
Refused: identifier not supported (captured) |
18 00 FF 00 |
58 00 |
Read DTCs by status: none stored (captured) |
18 00 00 00, 18 00 40 00, 18 00 80 00, 18 00 C0 00, 18 00 FF FF |
7F 18 12 |
Refused. SZ Viewer tries each of these in turn; only 18 00 FF 00 is accepted (captured)
21 00 |
61 00 + 208 bytes (210 in total) |
Live data block, layout below. SZ Viewer (Engine tab) repeats it about every 0.4 s (captured, partly decoded) |
21 50, 21 51, 21 52, 21 53, 21 55, 21 70, 21 71, 21 90 |
7F 21 12 |
Refused: local ID not supported. SZ Viewer tries each once when the Engine tab opens (captured) |
ECM data block (21 00) layout
Decoded from a PCAN-View capture taken while the SZ Viewer app (Engine tab) was polling the ECM on 14 November 2026, engine idling with a few blips of the throttle, car stationary. Matches SZ Viewer means the formula reproduces the value on the SZ Viewer screen from that capture. Everything else is inferred.
Byte numbers count from the 61 at the start of the reply (byte 0). The letter column is the variable name for Torque Pro and Car Scanner custom PIDs, where A is the first byte after 61 00 (A = byte 2). Bytes not listed were FF (unused) or did not change.
| Byte | Letter | Example (hex) | Meaning | Formula | Status |
| 2–5 | A–D | 00 07 E1 80 |
Monitor status, the same four bytes as OBD PID 01 | – | Matches SZ Viewer (OBD-II tab) |
| 17 | P | 02 |
Fuel system status: 02 = closed loop |
– | Matches SZ Viewer ("Closed loop (Sensor)") |
| 19 | R | 81 |
Short-term fuel trim | (R − 128) / 1.28 % (0.781 %) | Matches SZ Viewer |
| 20 | S | 77 |
Long-term fuel trim | (S − 128) / 1.28 % (−7.031 %) | Matches SZ Viewer |
| 23 | V | 79 |
Total fuel trim. Not exactly the sum of the two trims above | (V − 128) / 1.28 % (−5.469 %) | Matches SZ Viewer |
| 25–26 | X–Y | 09 59 |
Injection time | (X × 256 + Y) / 1000 ms (2.393 ms) | Matches SZ Viewer |
| 29 | AB | 87 |
Ignition advance | AB / 2 − 64 degrees (3.5°), the same formula as OBD PID 0E | Matches SZ Viewer |
| 36 | AI | 37 |
Rises from 54 to 70 when the throttle is opened. Perhaps engine load | – | Inferred |
| 37–38 | AJ–AK | 0C A0 |
Engine speed | (AJ × 256 + AK) / 4 rpm | Matches SZ Viewer |
| 42 | AO | 00 |
Vehicle speed | AO km/h | Matches SZ Viewer (0 km/h only) |
| 43 | AP | 1E |
Intake manifold absolute pressure | AP kPa (30 kPa) | Matches SZ Viewer |
| 44 | AQ | 63 |
Coolant temperature | AQ − 40 °C (59 °C) | Matches SZ Viewer |
| 45 | AR | 34 |
Intake air temperature | AR − 40 °C (12 °C) | Matches SZ Viewer |
| 46 | AS | 64 |
Barometric pressure | AS kPa (100 kPa = 750 mmHg). SZ Viewer's "Rel. pressure" (−0.7 bar) is MAP minus this value | Matches SZ Viewer |
| 60 | BI | 2A |
Rises from 41 to 57 when the throttle is opened. Unknown | – | – |
| 66 | BM | 08 |
Throttle position | BM / 2.55 % (3.137 %). Byte 67 carries the same value | Matches SZ Viewer |
| 76 | BW | 1A |
Upstream oxygen sensor (sensor 1) | BW × 0.005 V (0.13 V), the same scaling as OBD PID 14 | Matches SZ Viewer |
| 77 | BX | 98 |
Downstream oxygen sensor (sensor 2) | BX × 0.005 V (0.76 V) | Matches SZ Viewer |
| 99–100 | CT–CU | 38 B0 |
Battery (control module) voltage | (CT × 256 + CU) / 1000 V (14.512 V), the same value as OBD PID 42 | Matches SZ Viewer |
| 101 | CV | D6 |
Fuel tank level | CV / 2.55 % (83.922 %) | Matches SZ Viewer |
| 105 | CZ | 56 |
Rises from 85 to 134 when the throttle is opened. Unknown | – | – |
| 113 | DH | 2D |
Battery temperature | DH − 40 °C (4 °C on the temperature tab) | Matches SZ Viewer |
Notes:
- The fuel tank level (byte 101) is not available as a standard OBD PID on this car (PID 2F is not supported), so this block is the only known source for it.
- SZ Viewer also shows "Injector: 0.97 min/hour". No byte has been matched to it; it may be calculated from the injection time and engine speed.
- SZ Viewer requests this block with flow control
30 00 08(8 ms between frames). The first request of a session used30 00 00and also worked.
Standard OBD (mode 01) PIDs supported
Captured from an SZ Viewer scan on 14 November 2026, engine idling. SZ Viewer sends the standard requests to the functional address 0x7DF and the ECM answers on 0x7E8; no other module answered. A single request (01 00 20 40 60 80 A0) asks for all six "PIDs supported" bitmaps at once.
| Range | Bitmap reply | PIDs supported |
| 01–20 | BE 3E B8 13 |
01 monitor status, 03 fuel system status, 04 calculated load, 05 coolant temperature, 06 short-term fuel trim, 07 long-term fuel trim, 0B intake manifold pressure (MAP), 0C engine speed, 0D vehicle speed, 0E timing advance, 0F intake air temperature, 11 throttle position, 13 oxygen sensors present, 14 and 15 oxygen sensors (bank 1, sensors 1 and 2), 1C OBD standard, 1F run time since engine start |
| 21–40 | 80 05 A0 01 |
21 distance with MIL on, 2E commanded evaporative purge, 30 warm-ups since codes cleared, 31 distance since codes cleared, 33 barometric pressure |
| 41–60 | 6A D0 00 05 |
42 control module voltage, 43 absolute load, 45 relative throttle position, 47 absolute throttle position B, 49 and 4A accelerator pedal positions D and E, 4C commanded throttle actuator, 5E engine fuel rate |
| 61–80 | 00 00 00 01 |
None (only the bit that points to the next range) |
| 81–A0 | 00 00 00 08 |
9D engine fuel rate |
Not supported, so not available to OBD apps through standard PIDs: mass air flow (10; the engine works from MAP), fuel tank level (2F), ambient air temperature (46), engine oil temperature (5C) and odometer (A6). The fuel level and outside temperature can be read from the ECM and BCM data blocks instead.
The ECM accepts up to six PIDs in one request. SZ Viewer's OBD-II tab polls with 01 01 03 04 05 06 07, 01 0B 0C 0D 0E 0F 11, 01 13 14 15 1C 1F 21, 01 2E 30 31 33 42 43, 01 45 47 49 4A 4C 5E and 01 9D, and gets every value back in a single (multi-frame) reply, for example 41 0B 24 0C 0C C6 0D 00 0E 86 0F 34 11 23 (captured).
Other standard requests in the same scan:
| Request (to 0x7DF) | Reply (from 0x7E8) | Meaning |
03 |
43 00 |
Stored emission-related DTCs: none (captured) |
07 |
47 00 |
Pending DTCs: none (captured) |
0A |
No reply | Permanent DTCs. Sent 16 times per scan with no answer, so probably not supported (captured) |
0x261 ABS (inferred)
Request 0x261, reply 0x661. The name is inferred: this is the only brake module left in the scan report after the others were matched, and 56100 looks like a brake part-number series. The SZ Viewer app reads this module under its ABS/ESP tab and shows the same two part numbers, which supports the name (inferred). The driving capture of 15 November 2026 shows wheel speeds, yaw rate, steering angle and brake pressure in its data block, which confirms it is the ABS/ESP module.
3E |
7E |
1A 8E |
5A 8E + ASCII 56100-77RA |
1A 8A |
5A 8A + ASCII 56100-78RF* |
18 00 FF 00 |
58 00 |
DTCs: none stored (captured). SZ Viewer repeats it about every 1.4 s and shows "OK, no DTCs" |
7F 18 12 |
Refused. SZ Viewer tries each once when the ABS/ESP tab opens; only 18 00 FF 00 is accepted (captured)
21 00 |
61 00 + 50 bytes (52 in total) |
Live data block, layout below. SZ Viewer repeats it every 70 to 120 ms (captured, partly decoded) |
ABS data block (21 00) layout
Decoded from PCAN-View captures of the SZ Viewer app (ABS/ESP tab): one on 14 November 2026 with the engine idling and the car stationary, and three on 15 November 2026. The 15 November captures were an 8-minute drive, a parked capture with the steering turned to each lock and the brake pressed lightly and hard, and a 7-minute drive with a roundabout, left and right turns and three sharp stops (the last with the ABS cutting in). The last two were made alongside Android screen recordings of SZ Viewer. Matches SZ Viewer means the formula reproduces the value on the SZ Viewer screen at the same moment. Fits the drive means the byte behaved as expected while driving; the scale is not confirmed. Everything else is inferred.
| 0–1 | – | 61 00 |
Positive reply to 21 00 |
| 2–8 | A–G | 00 ×7 |
Unknown. Stayed at zero for the whole drive | – | – |
| 9 | H | 00 |
Wheel speed, front right | H km/h | Matches SZ Viewer |
| 10 | I | 00 |
Wheel speed, front left | I km/h | Matches SZ Viewer |
| 11 | J | 00 |
Wheel speed, rear right | J km/h | Matches SZ Viewer |
| 12 | K | 00 |
Wheel speed, rear left | K km/h | Matches SZ Viewer |
| 13 | L | 80 |
Longitudinal acceleration ("Acceleration"), centred on 128. Negative when braking (−36 = −0.72 G in a sharp stop) | (L − 128) × 0.02 G | Matches SZ Viewer |
| 14 | M | B9 |
Battery voltage | M × 20 / 255 V (185 = 14.51 V). Dipped to A8 (13.2 V) and recovered during the capture |
Matches SZ Viewer |
| 15 | N | 2E |
Pump motor voltage. SZ Viewer shows it twice: the first line is N × 20 / 255 and the second line is the same byte × 20.5 / 255 (46 = 3.608 V and 3.698 V; 175 = 13.725 V and 14.069 V). Alternates between 2E and 2F. Rises to battery voltage for a second or two during the ABS pump self-check just after moving off, and after an ABS stop |
N × 20 / 255 V | Matches SZ Viewer |
| 16 | O | 79 |
Steering angle offset | (O − 128) / 2 degrees (121 = −3.5°) | Matches SZ Viewer |
| 17–18 | P–Q | FF FF |
Unknown. Stayed FF FF for the whole drive, including braking, so this is not the brake pressure |
| 19 | R | 13 |
Master cylinder pressure. 19 or 20 at rest; about 64 for a light press and 109 for a hard press with the car parked | (R − 20) / 10 MPa (64 = 4.4 MPa, 108 = 8.8 MPa) | Matches SZ Viewer |
| 20 | S | 80 |
Lateral acceleration ("G sensor (lateral)"), centred on 128. Positive in a right turn | (S − 128) × 0.02 G | Matches SZ Viewer |
| 21–22 | T–U | 80 00 |
Yaw rate, a 16-bit value centred on 32768. Positive in a right turn | ((T × 256 + U) − 32768) × 0.05 °/s (712 = 35.6 °/s) | Matches SZ Viewer |
| 23 | V | FF |
Unknown | – | – |
| 24–25 | W–X | 0C 74 |
Engine speed | (W × 256 + X) / 4 rpm (3188 = 797 rpm), the same formula as OBD PID 0C. Changes on every reply with the idle (about 775 to 831 rpm) | Matches SZ Viewer |
| 26–27 | Y–Z | 00 A2 |
Steering angle, signed 16-bit. Negative is left, positive is right: −759 at full left lock and +704 at full right lock with the car parked, a span of 1463 counts. The steering wheel turns 4 times lock to lock (1440°), so one count is 1° (0.98° measured). SZ Viewer does not display it | (Y × 256 + Z), minus 65536 if Y ≥ 128, in degrees | Direction confirmed; scale from the lock-to-lock count |
| 28–40 | AA–AM | FF FF FF FF A9 FF FF FF FF FF FF FF 40 |
Unknown; did not change | – | – |
| 41 | AN | 00 |
Status flags. Bit 3 (08) is set while the brake pedal is pressed. Bit 6 (40) was set only while manoeuvring at 0 to 2 km/h at the start of the drive, so it may be reverse gear (inferred) |
– | Confirmed (bit 3) |
| 42 | AO | 0E |
Status flags. Bit 0 is set together with the brake bit in byte 41 (0E becomes 0F) |
– | Confirmed |
| 43 | AP | 00 |
Bit 0 (01) came on when the ABS cut in (one wheel slowing much faster than the others in a hard stop) and stayed on until the car had stopped (inferred) |
– | Fits the drive |
| 44 | AQ | 40 |
Status flag (40 or 00). With the car parked it was clear only while the steering was within about ±10 counts of straight ahead; while driving it also changed during hard stops. Meaning not certain |
| 45 | AR | 00 |
Braking flags. 50 (bits 4 and 6) during every hard stop (about −0.6 G or more). The low bits and bit 7 were added while a wheel was slipping, for example 51 and D5 when the front right wheel dropped to 1 km/h and the ABS cut in. Which bit belongs to which wheel is not certain (inferred) |
| 46–51 | AS–AX | 80 03 00 53 FF FF |
Notes:
- The wheel speeds, acceleration, lateral G, yaw rate and brake pressure were checked against Android screen recordings of SZ Viewer made alongside the 15 November captures. For example, in a tight right turn the screen showed 8 / 11 / 7 / 10 km/h (front right, front left, rear right, rear left), 35.6 °/s and 0.16 G, and bytes 9–12 read 8, 11, 7 and 10 with yaw 712 and lateral 136. In a sharp stop it showed −0.72 G, 7.8 MPa and the rear left wheel at 19 km/h against 22 for the others.
- The steering direction comes from a parked capture that followed a set order (full left lock, then full right lock) and from a drive that started with a left turn at a roundabout. Both gave negative values for left.
- SZ Viewer shows the steering angle offset (−3.5°, byte 16) but not the steering angle itself. The scale of bytes 26–27 comes from counting the turns of the steering wheel from lock to lock (4 turns).
- On the test car, straight ahead reads between about −36° and +9° rather than 0°. A lift kit has been fitted and the steering was only centred by eye afterwards; the steering centre had not been reset since. The centre appears to be held by the EPS controller (bytes 2–3 of its data block), which learns it over time and can be reset with a diagnostic tool; it was reset with a Launch X431 on 15 November 2026. Whether the ABS reading is centred after the reset has not been checked yet.
- Before polling the ABS, SZ Viewer sent one tester-present (
3E) to0x7E1and got no reply. 0x7E1 is the usual address for a separate transmission ECU (the slot after the engine at 0x7E0). The test car has a manual gearbox and no automatic transmission controller; its only transmission-related controller is the 4WD shift controller at 0x772, so nothing is fitted at 0x7E1. SZ Viewer, which also has an AT/CVT tab, appears to check the address and move on.
0x263 EPS controller (Power Steering)
Request 0x263, reply 0x663. Matches parts catalogue entry 38720-77R01 (EPS controller).
3E |
7E |
1A 8E |
5A 8E + ASCII 38720-77R0 |
1A 8A |
5A 8A + ASCII 38720-77R0* |
18 00 FF 00 |
58 00 |
DTCs: none stored (captured) |
21 08 |
61 08 + 40 bytes (42 in total) |
Live data block, partly decoded below. Polled continuously by SZ Viewer's PS tab (captured) |
30 E0 07 80 80, then 30 03 08 80 80, then 30 E0 07 00 80 |
70 E0 07, 70 03 08, 70 E0 07 |
Steering angle (centre) reset, sent by the Launch X431 CRP919. KWP service 30 is input/output control by local identifier; 07 is a short-term adjustment and 08 a long-term (stored) adjustment. Probably: enter centre-learning mode, store the current wheel position as centre, leave the mode (inferred). Afterwards bytes 2–3 of the data block read 80 00. Both of the Launch's "steering angle reset" menu items send the same three requests (captured)
EPS data block (21 08) layout
Decoded from two PCAN-View captures of the SZ Viewer PS tab: one on 14 November 2026 with the engine idling and the wheel not turned, and one on 15 November 2026 during a 2-minute drive (up to 42 km/h) that ended with parking manoeuvres at full assist. Byte numbers count from the 61 (byte 0); letter A = byte 2.
Example reply: 61 08 7F 9D FF FF 00 0F DD 7C CD 80 80 81 00 00 00 C8 26 FF 13 FF 10 04 C1 13 80 33 33 FF FF 00 45 FF FF FF FF 00 00 5E 4D 44
| 2–3 | A–B | 7F 9D |
Stored steering centre offset, centred on 8000. It does not change as the wheel is turned, even at full lock. The Suzuki manual says the module corrects the centre by itself over time from the average steering position; on the test car it was −99 on 14 November and −94 on 15 November without any reset. The Launch steering angle reset (see the request table) sets it to exactly 80 00 |
(A × 256 + B) − 32768 (unit not known) | Captured |
| 9 | H | 7C |
Battery voltage. Dips by 1 to 2 V while the motor is assisting hard | H × 30 / 255 V (122 = 14.353 V, 107 = 12.588 V) | Matches SZ Viewer |
| 10 | I | CD |
Sensor power supply | I × 6.2 / 255 V (205 = 4.984 V, 206 = 5.009 V) | Matches SZ Viewer |
| 11 | J | 80 |
Sensor (main) torque, centred on 128 (range 61 to 193 on the drive). Negative when turning one way, positive the other | (J − 128) × 0.153 Nm (91 = −5.665 Nm, 68 = −9.19 Nm) | Matches SZ Viewer |
| 12 | K | 80 |
Sensor (sub) torque, the mirror image of byte 11 (J + K is always about 256) | (K − 128) × 0.153 Nm (165 = 5.668 Nm) | Matches SZ Viewer |
| 13 | L | 81 |
Control (assist) torque, about twice the sensor torque, clipped at 2 and 255 | (L − 128) × 0.06125 Nm (40 = −5.39 Nm, 2 = −7.717 Nm) | Matches SZ Viewer |
| 14 | M | 00 |
Target motor current. Up to 160 (32 A) at full assist. Always positive, whichever way the wheel is turned | M × 0.2 A | Matches SZ Viewer |
| 15 | N | 00 |
Measured motor current. Follows byte 14 | N × 0.2 A | Matches SZ Viewer |
| 16 | O | 00 |
Vehicle speed | O km/h (up to 42) | Fits the drive |
| 18 | Q | 27 |
Engine speed | Q × 20 rpm (780 rpm) | Matches SZ Viewer |
| 27 | Z | 33 |
Motor drive voltage (+). Rises when assisting one way | Z × 0.117 − 5.0 V (51 = 0.968 V, 43 = 0.032 V, 98 = 6.47 V) | Matches SZ Viewer |
| 28 | AA | 33 |
Motor drive voltage (−). Rises when assisting the other way | AA × 0.117 − 5.0 V (151 = 12.67 V) | Matches SZ Viewer |
| 31–32 | AD–AE | 00 45 |
Changed all the time while driving (byte 31 from 0 to 163). Unknown | – | – |
The scales were checked against an Android screen recording of SZ Viewer made alongside a parked and low-speed capture on 15 November 2026 (wheel turned to each lock, quick left-right turns, then a short drive). Main and sub torque read 0.002 Nm on the screen with bytes 11 and 12 both at 128, so SZ Viewer adds a tiny offset; it makes no practical difference. Before 15 November this table listed byte 10 as battery voltage (× 0.07 V) and bytes 27–28 as × 0.019 V; both were wrong.
0x271 Body control module
Request 0x271, reply 0x671. Matches parts catalogue entries 36775-77RC2 to RC4 (body control module, RHD).
3E |
7E |
1A 8E |
5A 8E + ASCII 36775-77R0 |
1A 8A |
5A 8A + ASCII 36775-77RC* |
18 00 FF 00 |
58 00 |
21 08 |
61 08 + 100 bytes (102 in total) |
Live data block, partly decoded below. SZ Viewer's BCM tab repeats it about every 0.13 s (captured) |
BCM data block (21 08) layout
Decoded from a PCAN-View capture of the SZ Viewer BCM tab on 14 November 2026, engine idling, car stationary. Byte numbers count from the 61 (byte 0); letter A = byte 2.
| 2 | A | 32 |
Outside air temperature | A − 40 °C (10 °C). Also shown on SZ Viewer's temperature tab (9 °C, 31, a few minutes earlier) |
Matches SZ Viewer |
| 3 | B | B9 |
Battery voltage | B × 0.078 V (14.43 V) | Matches SZ Viewer |
| 6 | E | D2 |
Auto light sensor voltage | E × 5 / 255 V (4.118 V) | Matches SZ Viewer |
| 7 | F | 28 |
Varied between 40 and 43. Unknown | – | – |
| 22 | U | 00 |
Vehicle speed | U km/h | Fits the drive of 15 November 2026 (0 to 52 km/h) |
| 23–24 | V–W | 0C 94 |
Engine speed | (V × 256 + W) / 4 rpm (805 rpm) | Matches SZ Viewer |
| 12, 26–60 | – | 80, 33 00 FF 45 C0, 08, 02 00 E1 FF FF 02 80 00 02 32 87 00 00 10 FF 01 FF 04 A5 20 00 |
Probably the switch states shown on the BCM tab (doors, lights, key, seat belt, parking brake, A/C, wipers and so on). They did not change during the capture, so the bits are not yet mapped | – | – |
The outside temperature is not available as a standard OBD PID on this car (PID 46 is not supported), so this block is the only known source for it. To map the switch bits, capture the BCM tab while operating one switch at a time.
0x274 Instrument cluster
Request 0x274, reply 0x674. Confirmed by the rev counter sweep test.
3E or 3E 00 |
7E |
Tester present, about every 2.15 s during the sweep test (captured) |
1A 8E |
5A 8E + ASCII 34100-78R0 |
1A 8A |
5A 8A + ASCII 34110-78RD* (last byte of the reply is 06) |
18 00 FF 00 |
58 00 |
30 01 07 80 40 00 00 |
70 01 07 |
Starts the rev counter sweep (service 0x30, local ID 01, "short-term adjustment"). The cluster then sweeps up and down by itself (captured) |
30 01 07 80 00 00 00 |
7F 30 22 |
Refused ("conditions not correct"). Possibly a stop request sent after the sweep had finished (captured) |
The meaning of the four control bytes (80 40 00 00) is not known. Other output tests (gauges, warning lights) have not been captured.
0x798 TPMS controller
Request 0x798, reply 0x7A8. The label on the module reads 37160-78R00, "BASE ASSY-TPMS", Model No. P61M0 (Continental A2C13930301, 433.92 MHz). The full data layout, calibration and app setups are on OBD2 Diagnostics reading project.
3E |
7E |
1A 8E |
5A 8E + ASCII 37160-61M0 |
ECU identification; matches Model No. P61M0 on the label (captured) |
1A 8A |
5A 8A + ASCII 37120-78R0* |
18 00 FF 00 |
58 00 (no codes) or 58 01 9A 31 20 (one code) |
DTCs by status. 9A 31 is B1A31, "Left front tire pressure low" (confirmed by SZ Viewer). SZ Viewer shows status 20 as History (stored, not current); E0 was seen in earlier captures (captured)
21 00 |
61 00 + 100 bytes |
Sensor data block: module supply voltage and four sensor records (ID, wheel position, temperature, pressure, acceleration, battery status). Layout below. The Launch tool repeats it about twice a second, SZ Viewer every 0.12 to 0.15 s (captured, decoded) |
ELM327 setup that works for 21 00: ATSH798, ATS0, ATL0, ATFCSH798, ATFCSD300000, ATFCSM1, then 2100.
Decoded from a PCAN-View capture taken while the SZ Viewer app (TPMS tab) was polling the module on 14 November 2026, engine running, car stationary. Each decoded value below was checked against the SZ Viewer screen at the same moment.
| 0–1 | – | 61 00 |
| 2 | A | 8E |
Module supply voltage | A / 10 V (14.2 V). It dipped to 82 (13.0 V) and recovered during the capture; SZ Viewer showed 13.3 V (85) at that moment
| 3 | B | 01 |
Unknown | – |
| 4–11 | C–J | 00 ×8 |
Unknown, all zero so far | – |
| 12–21 | K–T | – | Sensor record 1 | see record table below |
| 22–31 | U–AD | – | Sensor record 2 | see record table below |
| 32–41 | AE–AN | – | Sensor record 3 | see record table below |
| 42–51 | AO–AX | – | Sensor record 4 | see record table below |
| 52–71 | AY–BR | 00000000 4EAA09C9 4EAA0319 4EAA09C9 DD91B525 |
Log of received sensor IDs. The first slot (52–55) has always been zero; 56–59 holds the most recently received sensor, then the older ones. While driving, the newest ID changed every time one of the four records was updated. In the deflation capture (example above) every filled slot held the left front ID | 4 bytes per slot, hex |
| 72–75 | BS–BV | 73 73 73 73 |
Low-pressure warning threshold for each wheel, in wheel-position order (right front, left front, right rear, left rear). Temperature-compensated: each value changes when that wheel's record brings a new temperature (inferred) | value × 0.0137 bar (73 = 1.58 bar, 22.9 psi)
| 76–79 | BW–BZ | 7D 7D 7D 7D |
A second threshold per wheel, in the same order and also temperature-compensated. Possibly the pressure at which the warning clears (inferred) | value × 0.0137 bar (7D = 1.71 bar, 24.8 psi)
| 80–81 | CA–CB | 00 00 |
Unknown | – |
| 82–83 | CC–CD | 00 00 |
Vehicle speed. Byte 83 is 00 or 80 (a half step). Matched the SZ Viewer "Speed" line on 48 readings in a row during a drive |
(CC × 256 + CD) / 128 km/h, or simply CC × 2 to the nearest 2 km/h |
| 84–91 | CE–CL | 00 90 00 96 00 62 00 69 |
Four 16-bit counters. While driving they rose by about 290 per second at 25 to 30 mph and wrapped round at 32768, in two closely matched pairs (84–87 and 88–91). Probably ABS wheel-rotation pulse counts, which the module needs for auto-location (inferred) | – |
| 92 | CM | 00 |
Low tyre pressure warning lamp. Bit 7 (80) is set while the lamp is on. It came on in the same reply in which the left front pressure fell from 1.603 to 1.507 bar, below that wheel's threshold in byte 73 (1.603 bar), and SZ Viewer changed from "Off" to "On / Blinking" at the same moment |
bit 7: 1 = lamp on |
| 93–101 | CN–CV | 30 33 33 02 01 80 17 00 00 |
Unknown. Bytes 94–95 were 22 22 in the engine-off example and 44 43 at the start of the drive, settling to 33 33 as the tyres cooled. Byte 96 changed from 02 to 12 once the car was moving. Byte 94 also changed from 34 to 24 when the first pressure drop was reported in the deflation capture |
Each sensor record is 10 bytes. Offsets are from the start of the record, as in the example at the top of the page.
| Offset | Letters (records 1 / 2 / 3 / 4) | Meaning | Formula | Check against SZ Viewer (records 1 / 2 / 3 / 4) |
| +0 to +3 | K–N / U–X / AE–AH / AO–AR | Sensor ID | 4 bytes, hex | 4EAA0943 / DD91B525 / 4EAA0319 / 4EAA09C9 |
| +4 | O / Y / AI / AS | Wheel position in the top five bits, as learned by the module's auto-location (see notes). The bottom three bits are status flags: bit 2 was set on each sensor's first transmission after moving off and bit 0 a little later (10 → 14 → 15) |
INT(value / 8): 1 = right front, 2 = left front, 3 = right rear, 4 = left rear. Plain value / 8 is wrong once the car has moved | 10 left front / 20 left rear / 18 right rear / 08 right front
| +5 | P / Z / AJ / AT | Air temperature | value − 50 °C | 3C 10 °C / 3B 9 °C / 3B 9 °C / 3C 10 °C
| +6 | Q / AA / AK / AU | Air pressure | value × 0.0137 bar (× 1.37 kPa, × 0.1987 psi) | 89 1.877 / 89 1.877 / 85 1.822 / 87 1.850 bar
| +7 | R / AB / AL / AV | Rotational (centripetal) acceleration measured by the sensor (SZ Viewer label "TPS acceleration"). Used with the ABS wheel speeds to locate each sensor on its wheel. Held from the sensor's last transmission, so not zero when parked | value / 2 g | 38 28 g / 35 26.5 g / 15 10.5 g / 0D 6.5 g
| +8 | S / AC / AM / AW | Sensor status, shown by SZ Viewer as battery status | 42 is shown as Normal. 49 in the engine-off example and 4C in data held from parking; each sensor changed to 42 on its first transmission while moving, and one sent 82 once. While the left front tyre was being deflated it sent 4A (bit 3 set), which looks like the sensor's pressure-drop alert mode. Probably a sensor mode or frame type as well as the battery state (inferred) |
all 42, Normal
| +9 | T / AD / AN / AX | Unknown | – | all 00
Notes:
- The records are stored in sensor-ID order, not wheel order. Use byte +4 to find the wheel, especially after the tyres have been rotated.
- SZ Viewer scales pressure by exactly 0.0137 bar per count (all four values match to three decimals). The 0.01372 used in the example above gives the same result to two decimals.
- The acceleration at +7 is the centripetal acceleration of the rotating wheel, so it rises with wheel speed. The module compares each sensor's rotation signal with the ABS wheel-speed signals to work out which sensor is on which wheel, and stores the result as the position code at +4. That is why the records are kept in sensor-ID order with the position as a separate field.
- The car was stationary during the capture, so the +7 values are held from each sensor's last transmission while moving. Each sensor transmits on its own schedule, so the four values were taken at different speeds as the car slowed: with the valve at about 0.19 m radius and a tyre rolling radius of about 0.37 m, 28 g / 26.5 g / 10.5 g / 6.5 g correspond to roughly 50 / 48 / 30 / 24 km/h, which supports the ÷ 2 scaling (estimate).
- Driving capture (15 November 2026, about 3 minutes, up to about 40 mph): the highest +7 value was
51(40.5 g). At 40 mph a valve at about 0.19 m radius sees roughly 45 g, so this supports the ÷ 2 scaling. Each sensor sent a new record roughly every 10 to 30 seconds while driving. - Temperatures fell from 16–19 °C (held from an earlier drive) to 7–8 °C during the drive, and the pressures fell with them (for example
90to80, 1.97 to 1.75 bar). The thresholds in bytes 72–79 dropped at the same moments:77to73(1.63 to 1.58 bar) for a fall from 18 °C to 7 °C, which is what the gas law predicts for a cold-pressure threshold. - SZ Viewer's temperature (°C) tab lists the TPMS temperatures as "Air temperature #1" to "#4" in record order, not wheel order (10 / 9 / 9 / 10 °C in the capture, matching records 1 to 4).
- SZ Viewer also shows speed and the low-pressure lamp. Both were found with a capture on 15 November 2026 alongside an Android screen recording: the left front tyre was let down while parked (1.877 to 1.48 bar) until the lamp came on, and the car was then driven for about 7 minutes with the lamp on. The speed is bytes 82–83 and the lamp is byte 92 bit 7 (see the table). The lamp came on below the threshold in byte 73 (the left front wheel's threshold), which supports the reading of bytes 72–75 as the low-pressure thresholds.
- SZ Viewer sends
21 00every 0.12 to 0.15 s and18 00 FF 00about every 2 s, with flow control30 00 00.
0x79A Combination switch (lighting and turn)
Request 0x79A, reply 0x7AA. Matches parts catalogue entry 37210-74PE2 (switch assembly, lighting and turn, RHD).
3E |
7E |
1A 8E |
5A 8E + ASCII 37210-74PA |
1A 8A |
5A 8A + ASCII 37210-74PE* |
1A 90, 1A 8D, 1A 99, 1A 98 |
7F 1A 12 |
Refused: identifier not supported. Tried by SZ Viewer (captured) |
18 00 FF 00 |
58 00 |
0x778 Dual sensor brake support (inferred)
Request 0x778, reply 0x788. The name is inferred by elimination (the scan report's last unassigned module). Not confirmed.
3E |
7E |
1A 8E |
5A 8E + ASCII 33990-52R0 |
1A 8A |
5A 8A + ASCII 33990-78R8* |
18 00 FF 00 |
58 00 |
0x793 Airbag (SRS) controller
Request 0x793, reply 0x7A3. Matches parts catalogue entry 38910-78RC0 (airbag controller, VAN).
3E 00 |
7E 00 |
22 F1 01 |
62 F1 01 + ASCII 38910-77R0 |
Identification (captured) |
22 F1 88 |
62 F1 88 + ASCII 38910-78RC* |
19 02 FF |
59 02 4B |
DTCs by status mask: none stored (captured) |
22 10 00 |
62 10 00 + 60 bytes (63 in total) |
Live data, partly decoded below. Polled continuously by SZ Viewer's SRS tab (captured) |
SRS data (22 10 00) layout
Decoded from a PCAN-View capture of the SZ Viewer SRS tab on 14 November 2026, engine idling. Byte numbers count from the 62 (byte 0). For a UDS reply the app letter A is the first byte after 62 10 00, so A = byte 3.
Example reply: 62 10 00 FF 04 AF BE FF FF FF FF FF FF 1A FF FF FF FF FF FF FF FF FF 02 60 FF FF 4F 80 07 E0 CC 00 19 17 FF FF 17 16 FF…
| 4 | B | 04 |
Number of squib channels | B (4) | Matches SZ Viewer |
| 5 | C | AF |
Battery voltage | C × 21 / 255 V (14.412 V) | Matches SZ Viewer |
| 6 | D | BE |
Back-up (energy reserve) voltage | About D × 0.167 V (31.8 V). The exact scale is not known | Close to SZ Viewer (31.816 V) |
| 33 | AE | 19 |
Driver airbag squib resistance | AE / 10 Ω (2.5 Ω) | Matches SZ Viewer |
| 34 | AF | 17 |
Passenger airbag squib resistance | AF / 10 Ω (2.3 Ω) | Matches SZ Viewer |
| 37 | AI | 17 |
Driver pretensioner squib resistance | AI / 10 Ω (2.3 Ω) | Matches SZ Viewer |
| 38 | AJ | 16 |
Passenger pretensioner squib resistance | AJ / 10 Ω (2.2 Ω) | Matches SZ Viewer |
0x772 4WD shift controller
Request 0x772, reply 0x782. Matches parts catalogue entry 38885-78R01 (4WD shift controller).
3E |
7F 3E 13 |
Refused: incorrect message length. Sent four times by the scan tool (captured) |
3E 01 |
7F 3E 12 |
Refused: sub-function not supported. Sent four times (captured) |
3E 00 |
7E 00 |
22 F1 01 |
62 F1 01 + ASCII 38885-77R0 |
22 F1 88 |
62 F1 88 + ASCII 38885-78R0* |
19 02 FF |
59 02 4B |
22 10 00 |
62 10 00 + 30 bytes (33 in total) |
Live data, partly decoded below. SZ Viewer's 4WD tab repeats it about every 0.08 s (captured) |
4WD data (22 10 00) layout
Decoded from a PCAN-View capture of the SZ Viewer 4WD tab on 14 November 2026, engine idling, 2H selected. Byte numbers count from the 62 (byte 0); app letter A = byte 3.
Example reply: 62 10 00 90 FF 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 01 80 10 01 FF 04 FF FF FF 11
| 3 | A | 90 |
Battery voltage | A / 10 V (14.4 V) | Matches SZ Viewer |
| 5 | C | 00 |
Vehicle speed | C km/h | Inferred (0 km/h only) |
| 6, 23–26, 28, 32 | – | 00, 01 80 10 01, 04, 11 |
Probably the switch states shown on the 4WD tab (4WD, 4WD-L, vacuum, VSV1, VSV2, ignition, transmission type). They did not change during the capture | – | – |
A capture while shifting between 2H, 4H and 4L should show which bits carry the 4WD and 4WD-L switches.
The scan tool tried the KWP-style 3E first and fell back to the UDS form 3E 00.
0x799 E-call controller
Request 0x799, reply 0x7A9. Matches parts catalogue entries 38960-78RA0 and RA1 (E-call controller).
3E |
7F 3E 13 |
Refused: incorrect message length. Sent four times (captured) |
3E 01 |
7F 3E 12 |
3E 00 |
7E 00 |
22 F1 01 |
62 F1 01 + ASCII 38960-78RA |
22 F1 88 |
62 F1 88 + ASCII 38960-78RA* |
19 02 FF |
59 02 4B 92 4E 00 02 |
One stored code record: 92 4E 00, status 02. The Launch report does not list it and its meaning is not known (captured)
1A 8A, 1A 8E, 1A 8D, 1A 90, 1A 91, 1A 98, 1A 99, 1A 9A |
7F 1A 11 |
Refused: service not supported. Sent by SZ Viewer (captured) |
18 00 00 00, 18 00 40 00, 18 00 80 00, 18 00 C0 00, 18 00 FF 00, 18 00 FF FF |
7F 18 11 |
SZ Viewer talks to this module with KWP-style requests (3E, 1A, 18), which it refuses, so SZ Viewer cannot read its identification or fault codes and does not show the 92 4E 00 record. Only the UDS requests above work. SZ Viewer did not send 19 02 FF, so its scan does not show whether that record is still stored.
0x751 Central gateway
Request 0x751, reply 0x761. The label on the module reads 33580-79R01.
3E 00 |
7E 00 |
22 F1 01 |
62 F1 01 + ASCII 33580-79R0 |
22 F1 88 |
62 F1 88 + ASCII 33580-78R0* |
19 02 FF |
59 02 4B |
The gateway sits between the OBD socket and the vehicle CAN bus. Whether it forwards requests to the other modules unchanged is not confirmed. To listen to the vehicle bus itself, see direct access below.
Direct access to the vehicle CAN bus (behind the gateway)
The OBD socket only carries diagnostic traffic, because the central gateway keeps the vehicle CAN bus away from it. To see the messages the modules send to each other (for example the instrument cluster's Comfort/Loaded tyre pressure setting, or the TPMS warning lamp command), connect a CAN tool to the vehicle bus directly.
The easiest place is the power steering (EPS) controller, which sits directly under the steering column.
- Remove the lower steering column cover. It is held by a hidden screw inside the round hole in the lower cover.
- Release the steering column adjuster lever and gently pull the cover off.
- Find the CAN wires in the EPS controller connector. Suzuki uses red for CAN-H and white for CAN-L.
- Push the tool's leads into the back of the connector alongside those two wires. On the test car the PCAN tool's leads are red and black, so red goes to red (CAN-H) and black goes to white (CAN-L).
Notes:
- Set PCAN-View to listen-only mode before connecting, so the tool cannot acknowledge or send frames on the live vehicle bus.
- The vehicle bus is already terminated. If your tool has a switchable 120 Ω terminator, leave it switched off.
- Only the messages in the table below have been identified so far.
Messages identified on the vehicle bus
From two captures at the EPS connector on 22 November 2026, both with SZ Viewer polling its TPMS tab through the OBD socket at the same time:
- 32 seconds parked with the ignition on. The brake pedal was pressed three times as sync points, and the dashboard tyre pressure setting was switched from Comfort to Loaded and back.
- About 68 seconds of a town drive at up to 54 km/h, including a junction turn. Speeds were scaled against the TPMS controller's vehicle speed (bytes 82–83 of its data block).
- 31 seconds parked: left indicator, right indicator and hazards in turn, each separated by a brake press as a cue.
- 30 seconds parked: light switch through Off, Auto, Side and Dip, with two headlamp flashes while on Dip, cued by brake presses (taken in the late afternoon, so Auto had the headlamps on).
- 31 seconds parked: front wiper switch through Off, Intermittent, Slow, Fast and Off, cued by brake presses.
- 10 seconds parked: horn sounded between two brake presses.
Byte 0 is the first data byte.
| ID | Rate | Byte | Meaning | Values |
0x124 |
10 ms | 1–2 | Engine speed (inferred) | (byte 1 × 256 + byte 2) / 4 rpm. About 700–790 rpm at idle and about 2,700 rpm at 50 km/h. 0x13F (20 ms) carries the same value in its bytes 1–2
0x1B8 |
12 ms | 0–7 | Four wheel speeds (inferred) | Four 16-bit words (bytes 0–1, 2–3, 4–5, 6–7), each word / 32 = km/h, about 3% below the vehicle speed on 0x314. Probably in the same order as the ABS data block: right front, left front, right rear, left rear. In a junction turn signalled with the right indicator (0x3D0), words 1 and 3 (the right-hand wheels, on the inside of the turn) ran slower than words 2 and 4 |
0x314 |
100 ms | 1–2 | Vehicle speed | (byte 1 × 256 + byte 2) / 128 km/h. Matches bytes 82–83 of the TPMS data block exactly, so the TPMS controller probably takes its speed from this message |
0x318 |
100 ms | 0 | Pedals (inferred) | Bit 2 (04) set while the brake pedal is pressed. Parked it reads 01, or 05 with the brake on. While driving it reads 02 in gear and 01 during gear changes, so bits 0 and 1 are probably the clutch switch or a neutral switch. Bytes 1 and 2 also change around each brake press; not decoded
0x3B8 |
100 ms | 0, 7 | Instrument cluster lamps (inferred) | Byte 0 bit 2 (04) set while the main beam tell-tale is lit (seen during headlamp flashes). Byte 7 reads FF with the lights off and E5 with them on; probably the dashboard dimming level
0x3BA |
100 ms | 1 | Tyre pressure setting change request, probably from the instrument cluster (inferred) | 00 normally. On a change it carries the chosen setting for 1 second (10 frames), then returns to 00: 03 = change to Loaded, 01 = change to Comfort
0x3C1 |
100 ms | 0–1 | Combination switch (stalk) positions, probably sent by the combination switch | Byte 0 bit 0 (01) = side lamps (set in both Side and Dip). Byte 1: bit 7 (80) = headlamps (Dip), bit 6 (40) = Auto, bit 3 (08) = headlamp flash, bit 2 (04) = left indicator, bit 1 (02) = right indicator. The indicator bits are set for as long as the stalk is held and do not change for the hazards. Off reads 00 00
0x3C3 |
100 ms | 6 | Electrical load level (inferred) | 00 with nothing running. With the front wipers: a brief 01 at the start of each intermittent wipe, mostly 01 on Slow, mostly 02 (briefly 03) on Fast, and short 01 blips for about 4 seconds after switching off, probably while the wipers park. It also varied up to 0F while driving without the wipers on, so it is probably a general electrical load figure (for example for the engine ECU's idle control) rather than a wiper signal
0x3D0 |
100 ms | 0, 2 | Exterior lamp states, probably from the body control module (inferred) | Byte 2: bit 3 (08) = side lamps on, bit 5 (20) = dipped headlamps on, bit 4 (10) = main beam on, bit 0 always set. Off 01, Side 09, Dip 29, Dip with flash 39; Auto read 29 because it had switched the headlamps on. Byte 0: bit 5 (20) set whenever any lights are on (matches the green lights-on tell-tale); bit 7 (80) set in Off and Side, when the headlamps are off, possibly the daytime running lamps (not checked)
0x3D0 |
100 ms | 4 | Turn signal flash state | Bit 6 (40) = left, bit 7 (80) = right, both (C0) = hazards. The bits switch on and off every 0.35 s (about 85 flashes a minute) in step with the bulbs. Probably sent by the body control module to the instrument cluster for its repeater lamps and ticker (inferred); the bulbs themselves are wired to the body control module and are not on CAN. The hazards appear only here, not on 0x3C1, which fits the hazard switch being wired to the body control module
0x3D4 |
100 ms | 4 | Light switch position as one code (inferred) | 80 = Off, 84 = Side, 88 = Dip, 8C = Auto. Probably the body control module's reading of the switch
0x3E2 |
100 ms | 6 | Current tyre pressure setting (inferred) | 01 = Comfort, 03 = Loaded. Follows the request on 0x3BA about 150 ms later and stays
0x3E8 |
100 ms | 1 | Probably battery or system voltage (inferred, scale not known) | Dropped by one count (AE to AD) with each wiper stroke, and rose slowly from B9 to BF during a drive
The front wiper switch position does not appear on the bus: in the wiper capture nothing changed on 0x3C1, 0x3D0, 0x3D4 or 0x3B8, only the load and voltage values above. The combination switch at 0x79A is the lighting and turn switch, so the wiper stalk is a separate part, probably wired directly to the body control module, which drives the wiper motor itself (inferred). The washer and rear wiper have not been tested.
The horn does not appear on the bus either: while it sounded, nothing changed apart from the usual counters, and 0x3E8 showed no dip. The horn button is probably wired through the clock spring straight to the horn relay, with no module involved (inferred).
Which modules send 0x3BA and 0x3E2 is not known, because the bus does not show the sender. Unplugging the TPMS controller and seeing which ID disappears would tell.
The setting is sent as a mode (Comfort or Loaded), not as a pressure, so the placard pressures (26/26 and 26/29 psi) must be stored in a module. During the capture the warning thresholds read through SZ Viewer did not change: bytes 72–75 stayed at 73 (22.9 psi) and bytes 76–79 at 7D (24.8 psi) on all four wheels in both settings (see the TPMS data block). The controller may only recalculate them when the sensors transmit, which they rarely do while parked. A drive in Loaded would show whether the rear thresholds (bytes 74–75) rise to about 25.5 psi (81).
Start-up sequence
From a capture at the EPS connector on 22 November 2026: key inserted, ignition on, engine started (cold). Times are from the start of the recording. Payloads of the security-related messages are deliberately not shown.
| Time | What appears on the bus | Probably |
| 0 s | Only 0x470 (100 ms). Byte 3 counts up |
A module already awake, for example from the door being opened |
| 2.8 s | 0x3D0, 0x3D1, 0x3D4, 0x3D5, 0x3D9 and 0x3E8 start, mostly all zeros |
Key inserted (inferred) |
| 5.4 s | Almost every other ID starts within about 0.3 s, and 0x470 byte 4 changes from 00 to 80 |
Ignition on (inferred) |
| 5.5–5.8 s | 0x4E0, 0x4E1, 0x4E4, 0x4E5, 0x4E9 and 0x4ED each send two all-zero frames and then stop |
Each module announcing itself once at wake-up (inferred) |
| 6.0–6.4 s | 0x0D0, 0x0D1 and 0x0D2 appear with changing, random-looking data, only in this window |
Probably the immobiliser exchange between the key unit and the engine ECU (inferred) |
| 5.9–6.5 s | 0x310 byte 3 reads 40 and 0x318 byte 1 reads 41, only in this window |
Starter cranking (inferred) |
| 6.3–6.8 s | Engine speed on 0x124 rises from 0 through 210 rpm to a peak of 1,600 rpm, then settles at about 1,380 rpm |
Engine running; cold fast idle (warm idle is about 700–790 rpm) |
| 7.3–7.7 s | 0x32F byte 0, 0x310 byte 6, 0x318 byte 6, 0x3E2 byte 0 and 0x3BA bytes 0–1 each change once |
Warning lamps clearing after the start, for example oil pressure and charge (inferred) |
| 7.8 s | 0x400 and 0x40B appear once or twice |
Not known |
0x500 (200 ms) carries ASCII text that starts with Suzuki's manufacturer code, so it almost certainly sends the vehicle identification number (VIN) in parts. Its contents are not shown here, and captures of it should not be published unedited.
Addresses probed with no reply
The Launch scan tool sent tester-present (3E) about eight times each to 0x273 and 0x262 and received nothing from the expected reply IDs (0x673 and 0x662).
The SZ Viewer scan of 14 November 2026 probed 0x262 and 0x273 too, and also sent tester-present (3E, 3E 00 or 3E 01) to the addresses below. None of them answered, in either of two full passes:
| Range | Addresses with no reply |
| 0x2xx | 0x241, 0x242, 0x243, 0x262, 0x264, 0x265, 0x272, 0x273, 0x275, 0x276, 0x277 |
| 0x7xx | 0x715, 0x716, 0x750, 0x776, 0x777, 0x779, 0x77A, 0x784, 0x79B, 0x79C |
| 0x7Ex | 0x7E1, 0x7E3, 0x7E4, 0x7E5, 0x7E6, 0x7EA |
These are probably modules that SZ Viewer knows from other Suzuki models and this car does not have, such as an automatic transmission (0x7E1, see the ABS notes) or an auto-levelling controller. Which module each address belongs to is a guess.
ELM327 notes
- Only
0x798has been tested with an ELM327. For other modules, setATSHto the request ID andATFCSHto the same ID, and you may needATCRAwith the reply ID, because the reply is not always the request ID plus 8. This is untested. - Replies from the 0x7xx modules are multi-frame for the identification strings, so the flow-control settings from the TPMS section probably apply there too. Untested.
- Do not send output-control commands (service
30and similar) from a head-unit app while driving.
Sources
- Owner PCAN-View captures of a Launch X431 CRP919 full health-check scan and rev counter sweep test, October 2026.
- Suzuki Jimny parts catalogue 9900B-40312-004 (type 1, October 2021), figures 350A, 351A and 351B.
- Labels on the TPMS controller and central gateway of the test car.
- Owner PCAN-View captures of the SZ Viewer app (TPMS and ABS/ESP tabs, ELM327 v1.5 Bluetooth adapter) with matching screenshots, 14 November 2026.
- Owner PCAN-View capture of an SZ Viewer full DTC scan (two passes), 14 November 2026.
- Owner PCAN-View captures of the SZ Viewer temperature, OBD-II, Engine, 4WD, BCM, PS and SRS tabs with matching screenshots, 14 November 2026.
- Owner PCAN-View captures of the SZ Viewer ABS/ESP, PS and TPMS tabs while driving, 15 November 2026.
- Owner PCAN-View captures of the SZ Viewer ABS/ESP, PS and TPMS tabs with matching Android screen recordings (parked steering and braking, a drive with ABS stops, power steering at full assist, and a TPMS deflation and drive with the lamp on), 15 November 2026.
- Owner PCAN-View captures of the Launch X431 CRP919 steering angle reset (EPS), 15 November 2026.
- Owner photo of a PCAN tool connected at the EPS controller connector, November 2026.
- Owner PCAN-View capture of the vehicle CAN bus at the EPS controller connector (Comfort/Loaded switching, with SZ Viewer polling the TPMS tab), 22 November 2026.
- Owner PCAN-View capture of the vehicle CAN bus at the EPS controller connector during a town drive, with SZ Viewer polling the TPMS tab, 22 November 2026.
- Owner PCAN-View capture of the vehicle CAN bus at the EPS controller connector during key-in, ignition on and engine start, 22 November 2026.
- Owner PCAN-View capture of the vehicle CAN bus at the EPS controller connector with the left indicator, right indicator and hazards in turn, 22 November 2026.
- Owner PCAN-View capture of the vehicle CAN bus at the EPS controller connector with the light switch in each position and headlamp flashes, 22 November 2026.
- Owner PCAN-View capture of the vehicle CAN bus at the EPS controller connector with the front wiper switch in each position, 22 November 2026.
- Owner PCAN-View capture of the vehicle CAN bus at the EPS controller connector while the horn sounded, 22 November 2026.
