OBD2 Diagnostics reading project
Suzuki Jimny JB74 (2018+) - Reading TPMS data over the diagnostic CAN link
Support this project: The information on this page is free, but it took a lot of work to gather, test and write up. If it has been useful to you, you can say thanks with a donation at buymeacoffee.com/bigjimny.
Overview
Purpose-built diagnostic tools (Autel, Launch and similar) already support Suzuki comprehensively. There is also a trend towards replacing the factory head unit with an Android media unit that can run apps to read and display information from the car's electronics. These units are not Suzuki-specific, so this project aims to learn how to read vehicle data (starting with the factory TPMS) and show it on the head unit.
Equipment
Role Item
Head unit XTRONS PX90
OBD-II Bluetooth dongle 1 Generic ELM-based (Chinese)
OBD-II Bluetooth dongle 2 Veepeak OBDCheck BLE+ (BLE only; unreliable on this head unit)
CAN bus monitor (Windows) PCAN-View (PEAK-System)
Diagnostic tool 1 Launch X431 CRP919
Diagnostic tool 2 SZ Viewer app
Head-unit apps tried Torque Pro (fails past the first line), RealDash (TPMS values seen in its debug view; gauges in progress), Car Scanner Pro (works)
Head-unit Bluetooth xTRONS IP90 - Classic Bluetooth only, no BLE support
Method
  1. The diagnostic tools (Launch X431, SZ Viewer) have comprehensive Suzuki support, so they are used to generate the CAN bus requests.
  2. PCAN-View is connected to the OBD socket to capture the requests and the module's replies, which are then decoded by hand.
  3. The decoded requests are recreated in the head-unit apps so the head unit can ask the car for the same data directly.
Status: work in progress. Based on one RHD UK-market 2021 Jimny with factory TPMS, owner-made PCAN-View captures (including a full Launch scan and an instrument cluster test), the Suzuki wiring diagrams (A-8 CAN communication and A-8 Central Gateway/DLC) and the Suzuki parts catalogue. TPMS readings work in Car Scanner Pro; RealDash works in its debug view with gauges in progress. Items marked unconfirmed are not yet verified.
  • The TPMS control module answers an ordinary diagnostic request on the OBD socket. It does not broadcast tyre data.
  • Request ID 0x798, reply ID 0x7A8 (11-bit CAN, 500 kbit/s, ISO-TP framing) returns the TPMS data, including four sensor IDs and pressure readings. The module's identification reply (37160-61M0) matches the Model No. (P61M0) on the TPMS controller label. Whether the central gateway forwards or remaps the request is unconfirmed.
  • Service 0x21 (read data by local identifier), identifier 0x00, returns 102 bytes containing all four sensor records.
  • Pressure is byte +6 of each sensor record: bar = raw x 0.01372.
  • The OBD socket is fed by a central gateway, so only diagnostic traffic is visible on it.
  • Working: Car Scanner Pro, and RealDash (values seen in its debug view). Not working: Torque Pro.
DLC (OBD socket) wiring
The service-manual diagram numbers the DLC terminals differently from SAE J1962. In all five cases on the diagram, manual terminal n matches standard pin 17 - n.
Manual terminal Standard pin Function Wire / source on diagram
1 16 Battery +12 V GRY, fuse No.49 "DOME2" (10 A)
12 5 Signal ground BLK
13 4 Chassis ground BLK
11 6 CAN-H (from standard assignment) BLU, gateway pin 8
3 14 CAN-L (from standard assignment) WHT, gateway pin 7
Use pins 6 and 14 for a CAN adapter. The diagram does not label CAN-H and CAN-L itself.
Cross-check with other reports
A BigJimny forum thread ("JB74 OBD2 connection", December 2020) describes a 2020 JB74 whose OBD plug had pins 4, 5, 6, 14, 15 and 16 wired, with pin 7 (K-line) not wired. The poster, quoting an older Suzuki pinout, lists pin 6 as a blue wire (CAN-H) and pin 14 as a white wire (CAN-L). This matches the table above: a blue CAN wire on pin 6 and a white one on pin 14.
  • The CAN-H/CAN-L assignment in that thread comes from a pinout reference that the poster says predates the JB74, so it is a report, not a measurement.
  • No wire for standard pin 7 (K-line) appears on the diagram page above, and the forum report also found it unwired. K-line is therefore unlikely to be available on the JB74 socket.
  • On the forum poster's car, pin 15 was also wired; the diagram page above shows no wire for it. This may be a market or model-year difference.
Network layout
The DLC is not on the vehicle bus directly. The central gateway control module joins the vehicle CAN bus (its pins 20 and 21, RED/WHT) and provides a separate CAN pair to the DLC (its pins 8 and 7, BLU/WHT).
Modules on the vehicle bus (diagram): ECM, 4WD control module, TCM (A/T models), BCM, ESP control module, headlight auto levelling module (if equipped), dual sensor brake support control module (if equipped), P/S control module, steering angle sensor, TPMS control module / receiver (if equipped), combination meter, SDM, combination switch.
Gateway power: fuse No.60 "IG1 SIG" (10 A) and fuse No.52 "CONT" (5 A). Treat the ignition as needing to be on.
Observation: two captures from the DLC contained only IDs 0x798 and 0x7A8 (plus two error frames). No broadcast traffic from other modules was seen, so passive listening on the DLC will not show TPMS data.
Diagnostic requests seen
Request Reply Meaning
3E 7E Tester present
1A 8A 5A 8A + ASCII 37120-78R0* ECU identification
1A 8E 5A 8E + ASCII 37160-61M0 ECU identification: matches the "Model No. P61M0" printed on the TPMS controller label
18 00 FF 00 58 00 or 58 01 9A 31 E0 Read DTCs by status (second form = one code reported; not decoded)
21 00 61 00 + 100 bytes Sensor data block (repeated about twice a second by the scan tool)
Part labels on the test car: TPMS controller 37160-78R00, "BASE ASSY-TPMS", Model No. P61M0, Continental A2C13930301, 433.92 MHz; central gateway controller 33580-79R01. The 1A 8E reply (37160-61M0) matches the TPMS controller's base number and model number; the 1A 8A reply (37120-78R0*) shares "78R0" with the full part number, but its meaning is not confirmed.
A Launch full scan reported "Left Front Tire Pressure Low" for the TPMS module, and the module returned one stored code (9A 31) in the same scan. That code is probably the low-pressure warning (inferred; the report does not show the code itself).
Reading it with an ELM327
Terminal commands, one at a time (CR line ending):
ATZ
ATSP6
ATSH798
ATS0
ATL0
ATFCSH798
ATFCSD300000
ATFCSM1
2100
  • ATSH798 sets the request address. The reply address (0x7A8) is worked out automatically.
  • ATFCSH798 / ATFCSD300000 / ATFCSM1 make the adapter send the ISO-TP flow-control frame (30 00 00) itself.
  • ATS0 removes the spaces between bytes. Without it, the generic Chinese ELM327-based dongle (dongle 1) reported BUFFER FULL near byte 81.
  • Expected output: a length line (066 = 102 bytes) and numbered lines 0: to E:.
  • With default settings dongle 1 returned only the first line (61 00 xx 01 00 00).
Reply layout (21 00)
Byte positions count the 61 as byte 0.
Bytes Content
0-1 61 00 (positive reply)
2 Varies 117-142. Looks like system voltage x 10 (unconfirmed)
12-21 Sensor record 1: front left
22-31 Sensor record 2: rear left
32-41 Sensor record 3: rear right
42-51 Sensor record 4: front right
56-71 Four 4-byte sensor-ID entries whose contents change (meaning unknown)
other Not decoded
Sensor record (10 bytes)
Offset Content
+0 to +3 Sensor ID
+4 Position flag
+5 Value 57-74. Behaves like temperature, possibly with an offset of 40 (unconfirmed)
+6 Pressure, gauge: bar = raw x 0.01372 (see Calibration)
+7, +8 Not understood
+9 Always 0
Wheel Sensor ID Position flag
Front left 4E AA 09 43 0x10
Rear left DD 91 B5 25 0x20
Rear right 4E AA 03 19 0x18
Front right 4E AA 09 C9 0x08
Sensor IDs are specific to one car. Yours will differ.
Calibration
Byte +6 against gauge readings (bar). The five deflation-test counts were reconstructed from the app's displayed values.
Raw Gauge (bar) Raw x 0.01372
136 (rear left) 1.868 1.866
131 (rear right) 1.795 1.797
131 (front right) 1.795 1.797
126 1.73 1.729
119 1.63 1.633
112 1.54 1.537
101 1.39 1.386
96 1.29 1.317
The last five rows are from one tyre during a slow deflation (assumed front left).
  • bar = raw x 0.01372
  • psi = raw x 0.199
No offset is needed, which suggests the byte holds gauge pressure. All points are within 0.004 bar except the lowest (0.027 bar off), which may be sensor update lag or slight non-linearity. More readings at low and high pressure are needed.
Torque Pro custom PIDs
Common fields for every wheel:
Field Value
Header 798
Mode and PID 2100
Diagnostic start command ATS0, ATL0, ATFCSH798, ATFCSD300000, ATFCSM1 (comma-separated)
Unit / min / max bar, 0, 4 (or psi, 0, 60)
Equation uses a letter for each data byte. A is the first byte after 61 00 (reply byte 2).
Wheel Byte +5 (temperature?) Byte +6 (pressure candidate)” to “Byte +6 (pressure)”
Front left P Q
Front right AT AU
Rear left Z AA
Rear right AJ AK
Example: Q*0.01372. Letters must be upper case. Whether Torque accepts two-letter variables is unconfirmed.
Known problem
Using dongle 1 (generic Chinese ELM327-based) with Torque Pro on the XTRONS PX90, Torque read bytes A to D (first line of the reply) correctly, but every byte from E onward returned -1, even though a terminal received the full 102 bytes with the same commands. The start-command field is applied (adding ATH1 changed the output). Tried without success: turning off "Faster communication", removing ATS0. Not yet tried: ATAT0, ATSTFF timeout settings, other apps, and the Veepeak OBDCheck BLE+ (dongle 2).. Unresolved. The same result occurred with the Veepeak OBDCheck BLE+ (dongle 2). Car Scanner Pro does not have this problem (see below).
Car Scanner Pro (working)
Car Scanner Pro reads all the bytes where Torque Pro fails. Custom PID settings used:
  • Header: 798
  • Request: 2100
  • Start command (backslash-separated): ATAT0\ATSTFF\ATS0\ATL0\ATFCSH798\ATFCSD300000\ATFCSM1
  • Equations use the same letters as the table above, for example Q*0.01372 for front left (bar)
The start command has not yet been shortened. Adapter: Both dongle 1 (generic ELM327-based) and dongle 2 (Veepeak OBDCheck BLE+) work with Car Scanner Pro.
Other modules found by a full scan
A full health-check scan with a Launch X431 CRP919, captured with PCAN-View on the OBD socket, shows 12 modules answering on the DLC. Every module that replied is listed here. The reply ID is not always the request ID plus 8.
Request Reply Protocol Identification replies Module How identified
0x7E0 0x7E8 KWP 33980-78R0, 33980-78RC* ECM Standard engine address
0x261 0x661 KWP 56100-77RA, 56100-78RF* ABS (inferred) Only brake module left by elimination
0x263 0x663 KWP 38720-77R0, 38720-77R0* EPS controller Parts catalogue
0x271 0x671 KWP 36775-77R0, 36775-77RC* Body control module Parts catalogue
0x274 0x674 KWP 34100-78R0, 34110-78RD* Instrument cluster Rev counter sweep test
0x798 0x7A8 KWP 37160-61M0, 37120-78R0* TPMS controller Label and parts catalogue
0x79A 0x7AA KWP 37210-74PA, 37210-74PE* Lighting and turn switch Parts catalogue
0x778 0x788 KWP 33990-52R0, 33990-78R8* Dual sensor brake support Parts catalogue
0x793 0x7A3 UDS 38910-77R0, 38910-78RC* Airbag (SRS) controller Parts catalogue
0x772 0x782 UDS 38885-77R0, 38885-78R0* 4WD shift controller Parts catalogue
0x799 0x7A9 UDS 38960-78RA, 38960-78RA* E-call controller Parts catalogue
0x751 0x761 UDS 33580-79R0, 33580-78R0* Central gateway Label and parts catalogue
Reply ID offsets: engine +0x08; 0x261 to 0x274 +0x400; all others +0x10.
  • KWP-style modules answer 1A 8E and 1A 8A (identification) and 18 00 FF 00 (DTCs). UDS-style modules answer 22 F1 01 and 22 F1 88 (identification) and 19 02 FF (DTCs).
  • Requests to 0x273 and 0x262 (tester present) got no reply, so those modules are probably not fitted.
  • The "probable" and "possible" names are guesses from the part-number series and are not confirmed.
Instrument cluster output test (0x274 / 0x674)
A rev counter sweep commanded by the Launch X431 appears as a single KWP output-control request, after which the cluster sweeps the needle up and down by itself:
Request Reply Notes
3E 00 7E Tester present, about every 2.15 s
30 01 07 80 40 00 00 70 01 07 Starts the sweep (service 0x30, local ID 01, "short-term adjustment")
30 01 07 80 00 00 00 7F 30 22 Refused ("conditions not correct"); possibly a stop request sent after the sweep had finished
The meaning of the four control bytes (80 40 00 00) is not known.
Open questions
  • Meaning of reply bytes +5, +7, +8 and the unexplained regions.
  • A reliable pressure scale and offset (more gauge readings needed).
  • Whether other Suzuki modules use addresses near 0x798 (not checked).
  • Why Torque stops after the first line.
Sources
  • Owner PCAN-View captures, October 2026.
  • Suzuki wiring diagrams: A-8 CAN communication system; A-8 Central Gateway Control and DLC System (RHD).
  • Forum thread "Jimny JB74 (2019+) - Torque Pro PID for TPMS".
  • BigJimny forum thread "JB74 OBD2 connection" (December 2020).
