Revision as of 10:57, 11 August 2020 by Bosanek (talk | contribs) (Expanded all the tables to include columns both for Jimny 3 and Jimny 4. Now they are ready to accept data.)
Torque
The purpose of this page is to simply list the factory specified tightening torques for various fasteners in the vehicle.
Axle
Tightening torque
Fastener Jimny 3 Jimny 4
[Nm] [lb-ft] [Nm] [lb-ft]
Radius Arm bolts (Axle) 90 65 ? ?
Radius Arm bolts (Chassis) 90 65 ? ?
Differential, front and rear
Tightening torque
Differential Drain Plug 27 19.5 55 40.5
Differential Filler Plug 50 36.5 50 36.2
Prop Shaft Flange Bolts 50 36.5 ? ?
Bevel Gear Bolts 85 61.5 ? ?
Bearing Cap Bolts (front) 50 36.5 ? ?
Bearing Cap Bolts (rear) 85 61.5 ? ?
Lock Plate Bolts 11.5 8.5 ? ?
Front and Rear carrier bolts 23 17 ? ?
Gear Thrust Bolt (front) 1.5 0.1 ? ?
Gear Thrust Bolt (rear) 85 61.5 ? ?
Front Wheel Hub
Tightening torque
Wheel Nuts 95 69 100 72.3
Tie-Rod End Nut 43 31.5 ? ?
Kingpin Bolt 25 18.0 ? ?
Locking Hub Bolts 48 35 ? ?
Swivel Seal Bolts 10 7.5 ? ?
Brake Carrier Bolts 85 61.5 ? ?
Wheel Bearing Lock Nut 220 160 ? ?
Drop-Link/Stabilizer Link ball nut 50 36.5 ? ?
Brake Caliper Slider Bolt 22 16 ? ?
Front Brake Flexi Hose bolt 23 17 ? ?
Wheel Spindle Bolt 50 36.5 ? ?
Engine
Tightening torque
Engine G13B Engine M13A (VVT) Engine K9K Engine K15B
[Nm] [lb-ft] [Nm] [lb-ft] [Nm] [lb-ft] [Nm] [lb-ft]
Oil drain plug ? ? ? ? ? ? 35 25.8
Oil filter (3/4 turn) ? ? ? ? ? ? 14 10.3
Gear box
Tightening torque
Petrol Diesel Petrol
Automatic Manual Automatic Manual
Code ??
1998-2005
Code ??
2005+
Code R7ME
1998-2005
Code R72
2005+
Code YR7D
2003-2005
Code ??
2005-2011
Code ??
2018+
Code ??
2018+
[Nm] [lb-ft] [Nm] [lb-ft] [Nm] [lb-ft] [Nm] [lb-ft] [Nm] [lb-ft] [Nm] [lb-ft] [Nm] [lb-ft] [Nm] [lb-ft]
Fill and drain plugs ? ? ? ? ? ? 23 17 ? ? ? ? ? ? 23 16.6
Reverse Switch ? ? ? ? ? ? 23 17 ? ? ? ? ? ? ? ?
5th gear shift inverse lever bolt ? ? ? ? ? ? 23 17 ? ? ? ? ? ? ? ?
Transmission case bolt ? ? ? ? ? ? 23 17 ? ? ? ? ? ? ? ?
Gear shift rod spring / ball bearing bolts ? ? ? ? ? ? 13 9 ? ? ? ? ? ? ? ?
Gear box case to engine nuts and bolts ? ? ? ? ? ? 90 65 ? ? ? ? ? ? ? ?
Transfer box
Tightening torque
With
mechanical
lever
Without
mechanical
lever
With
mechanical
lever
Fill and drain plugs ? ? ? ? 23 16.6
Other
Tightening torque
Chassis to body mount bolts 60 44 ? ?
All bolts which fasten any of the seat belts to the vehicle 35 26 ? ?
Page last edited on 11/08/2020 by user Bosanek
