- 1 Introduction
- 2 Principle of operation
- 3 Required parts
- 4 Complete retrofit sets
- 5 "Fog lamp + bracket" combos
- 6 Parts compatibility
- 7 Notes on lamps
- 8 Notes on lamp mounting brackets (carriers)
- 9 Notes on lamp surrounding bezels
- 10 Pictures of lamps and brackets in bumpers
- 11 Wiring
- 12 Console button / switch
- 13 Installation in the front bumper
- If your vehicle already has working front fog lamps (in the front bumper) installed from the factory, you don't need to read this article.
- Enjoy life instead.
- As far as it is known, all Jimnys 4 have front fog lamps fitted as standard equipment.
- Therefore, this article contains instructions on retrofitting fog lamps only for Jimnys 3.
This article has been written by a single person, based on original research into the vast universe of various Suzuki accessories brochures, parts catalogues, info from various forums etc.
Great effort has been performed to double-check every info, but the topics of required and mutually compatible parts are so complex with so many variations over Jimny 3's 20 year production lifespan, that no guarantees on the accuracy of the written data can be made.
- Factory wiring setup for the front fog lamps is made in such a way that front fog lamps illuminate ONLY when the head lamps are ON as well.
- This means that the front fog lamps will not turn ON even if the in-cabin switch for front fog lamps is pushed IN, until the head lamps are turned ON as well.
- It is not possible to control the operation of each front fog lamp (left and right) independently.
- It's either both OFF or both ON.
- This also means that no fog lamp turns ON automatically when you steer hard on a street corner, like in some fancy modern vehicles.
- If you don't like these restrictions, then you will have to make some custom wiring modifications.
Don't be an idiot and use the fog lamps in non-foggy weather while other participants in traffic are present. Fog lamps are designed to "punch" light through fog. Therefore, they dazzle other drivers and pedestrians (and their precious pets) when there is no fog in between!
Required parts
Main notes:
- A pair of fog lamps;
- Exception is if you have the newest (3rd model) front bumper revision - it has integrated brackets.
- Possibly some more electrics like a relay, a fuse etc.;
In the case of 1st and 2nd model front bumper, you will have to cut out plastic blanks in the fog lamp openings in the front bumper. That operation is irreversible. You could glue the blanks back if you abandon the project, but it will hardly look virgin again. Therefore, it is recommended to obtain all the required parts (especially the electrics), and test-wire everything first before you finally cut the bumper and mount the lamps.
For Jimny 3 types 1-5 (with 1st model front bumper)
Set P.N. 99000-990YZ-011
This is the oldest upgrade set ever offered. It contains the same parts which were originally used for 1st model front bumpers as a factory installation.
- This set is compatible with Jimnys 3 type 1-4, but not with type 5.
- Type 5 is a "transitional" production edition from 2005 with 1st model front bumper but with 2nd edition interior and electric 4WD controls.
- This complete upgrade set might not be available from Suzuki anymore, because they usually offer a "revised" set for 1st model front bumpers (see the next set below).
- If the complete set is not available, perhaps some individual parts might be, or you could scavenge the entire set from a dead Jimny 3.
This set includes:
- A pair of fog lamps model 35500-74F50;
- A pair of mounting brackets model 35526-81A01;
- Fog lamp surrounding bezels model 99000-990YZ-B03 (for left side) and 99000-990YZ-B04 (for right side);
- These are used for the "flush" cosmetic fitting of the fog lamps into the holes in the front bumper;
- However, it makes no sense to include any bezels for fitting the fog lamp model 35500-74F50 to 1st model front bumper, because that fog lamp model is designed to fit flush on its own in that bumper model!
- Proof: See the pictures in the chapter "Pictures of lamps and brackets in bumpers".
- Therefore, the info from Suzuki diagrams about the inclusion of these bezels with these fog lamps might be erroneous!
- Wiring harness for the engine bay (connection to the fog lamps), OEM P.N. 99000-990YZ-A05;
- Includes a fuse;
- Wiring harness for the cabin console (connection to the in-cabin button / switch), OEM P.N. 99000-990YZ-A06;
- Relay P.N. 99000-990YZ-A07;
- In-cabin button / switch P.N. 37270-75F10;
- Various small bits (screws, nuts, bolts, clamps, ties, etc).
Set P.N. 99000-990YZ-035
This appears to be a newer "revised" set which replaced the previous set described above.
- Suzuki's OEM accessory catalogues as old as 2006 already offer only this set for Jimnys 3 type 1-4 with 1st. model front bumper, and have no mention of the previous set described above.
According to the pictures from a report from a German forum, this set appears to contain the following:
- A pair of fog lamps produced by Cibie (owned by Valeo), model 026719;
- A pair of brackets (P.N. UNKNOWN for left side and UNKNOWN for right side) to mount it to a 1st model front bumper.
- A pair of surrounding bezels for flush cosmetic fitting in the holes in the front bumper (P.N. UNKNOWN);
- One in-cabin button / switch (P.N. UNKNOWN);
- Wiring harness (P.N. UNKNOWN);
- Fuse;
- The reason for the inclusion of the bezels for the front bumper is that the included fog lamps do not fit "flush" cosmetically in the holes of a 1st model front bumper (they were not originally designed for it), so the bezels correct that.
For diesel type 4 vehicles (with 48 kW engine and mechanically operated 4WD transmission), the following are additionally required:
Set P.N. 990E0-76J10-000
- It is assumed (but not verified!) that this set contains a pair of front fog lamps, a pair of brackets, a pair of bezels, one in-cabin switch, wiring, relay, fuse and some screws.
- It is assumed (but not verified!) that the included fog lamp model is either 35500-63J04 or Cibie 026719.
- It is assumed (but not verified!) that the lamps, brackets and bezels in this set are the same as in the set 99000-990YZ-035, but that the wiring is different.
For Jimny 3 types 6-8 (with 2nd model front bumper)
Set P.N. 990E0-84A02-000
This set includes:
- A pair of fog lamps model 35500-63J0x;
- It has not been verified what character behind "x" in the part number exactly is.
- It is most probably "4" (35500-63J04), but it could also be "0", "2", "3", ...
- A pair of mounting brackets - left model 35566-84A00 and right model 35526-84A00;
- Wiring harness 36813-84A00;
- This harness represents section "Wiring 4" from the DIY diagram below - between the engine bay and the lamps themselves;
- In-cabin button / switch (P.N. UNKNOWN, probably 37270-76J00);
- Various small bits (screws, bolts, etc).
- Complete front fog lamp upgrade set 990E0-84A02-000
For Jimny 3 types 9-12, (with 3rd model front bumper)
Set P.N. 990E0-57M51-000
- Suffix "-000" should be omitted in some searches, and in some other catalogues it is listed with the suffix "-010".
- The difference between suffixes is probably in the languages in which the included paper instruction manual is written.
This set includes:
- No mounting brackets are included;
- This is because 3rd model front bumper has integrated front fog lamp brackets specifically for front fog lamps 35500-63J0x;
- Two pieces of wiring harness 36813-57M00 (one for each fog lamp);
Combo set 99000-990YZ-B01 + 99000-990YZ-B02
- Fog lamp model 35500-74F50 and bracket model 35526-81A01 are available in a combo set P.N. 99000-990YZ-B01 (for the left side) and 99000-990YZ-B02 (for the right side).
- It is not known why there are two differently named sets (specifically for each side), since both the contained fog lamp and bracket models fit any side equally.
- Fog lamp P.N. 35500-74F50 with bracket P.N. 35526-81A01, taken from 1st model front bumper
Lamp Cibie 026719 with its dedicated bracket
- Fog lamp Cibie 026719 with bracket (unknown P.N.), taken from 1st model front bumper
Lamp 35500-63J0x with brackets 35566-84A00 and 35526-84A00
- Fog lamp P.N. 35500-63J04 with brackets 35566-84A00 and 35526-84A00, taken from 2nd model front bumper
Parts compatibility
Separate parts
- However, not each part (lamp, bracket, etc.) is mutually compatible nor compatible with each front bumper model.
Known fog lamp models:
- Suzuki 35500-74F50;
- Cibie 026719;
- Suzuki 35500-63J0x;
- This model has several "sub-models";
- More info is present in the dedicated chapter about lamps.
Known lamp brackets / carriers:
- Suzuki 35526-81A01;
- Suzuki UNKNOWN;
- Used exclusively with fog lamps Cibie 026719;
- Suzuki 35566-81A30 + Suzuki 35526-81A30;
- (Left model + right model);
- Suzuki 35566-84A00 + Suzuki 35526-84A00;
Known lamp surrounding bezels:
- Suzuki 99000-990YZ-B03 + 99000-990YZ-B04
- It is assumed (but not verified!) that these bezels are for use with fog lamps Cibie 026719 in 1st model front bumper and/or with fog lamps Suzuki 35500-63J0x in 1st model front bumper;
- There could possibly exist one more bezel model for use with fog lamps Cibie 026719 in 1st model front bumper and/or with fog lamps Suzuki 35500-63J0x in 1st model front bumper;
- Suzuki 71761-57M10-5PK + 71751-57M10-5PK;
Known wiring harnesses:
- Suzuki 99000-990YZ-A05;
- Used in the engine bay of Jimny 3 types 1-4;
- Includes a fuse;
- Suzuki 99000-990YZ-A06;
- Used behind the dash board of Jimny 3 types 1-4;
- Suzuki 36813-84A00;
- Used between the engine bay and the fog lamps in Jimny 3 types 6-8;
- Suzuki 36813-57M00;
- Used between the engine bay and the fog lamps in Jimny 3 types 9-12;
Known wiring connector adapters:
- Suzuki 36813-54G20;
- Used at the "fog lamp to wiring" ("Cable connector 5") connection point in case of some particular setup combinations;
- It has been determined that this wiring adapter is exactly the same (same connectors on both ends) as the wiring harness 36813-57M00, except that the harness is a bit longer.
- Therefore, they are essentially interchangeable.
- Suzuki 99000-990YZ-C13;
- Used by DDiS Jimnys 3 type 4 only;
Known el. relay models:
- Suzuki 99000-990YZ-A07;
- Suzuki 95572-63C00-000;
Known in-cabin console switches:
- Suzuki 37270-75F10;
- Suzuki 37270-76J00;
Lamp | Bracket left side |
Bracket right side |
Bezel left side |
Bezel right side |
El. connector adapter |
Comment |
35500-74F50 | 35526-81A01 | 35526-81A01 | None required | None required | None required | Standard setup |
Cibie 026719 | Required Seen on pictures P.N. unknown |
99000-990YZ-B03 ? | 99000-990YZ-B04 ? | Probably required Probably 36813-54G20 |
"Improved" (more complicated) setup |
35500-63J00 35500-63J02 35500-63J04 |
35566-81A30 | 35526-81A30 | 99000-990YZ-B03 ? | 99000-990YZ-B04 ? | 36813-54G20 | "Universal retrofit" setup |
Bezel left side |
Bezel right side |
Comment |
35500-74F50 | Not produced | Not produced | Not produced | Not produced | Not produced | Infeasible setup unless custom brackets are made and el. connections are soldered |
Cibie 026719 | Not produced | Not produced | Probably not needed | Probably not needed | None required | Infeasible setup unless custom brackets are made |
Bezel left side |
Bezel right side |
Comment |
Notes on lamps
Common notes
- As evident from the tables above, both the 2nd model and the 3rd model front bumper use the same fog lamps.
Notes on fog lamp model Suzuki 35500-74F50
- Fog lamp model Suzuki 35500-74F50 is actually produced by Stanley, model 010-2587.
- This fog lamp is used on several other vehicle models, so you can find it from other cars as well.
- Fog lamp model Suzuki 35500-74F50 / Stanley 010-2587
Notes on fog lamp model Cibie 026719
- Another fog lamp model which is often found on Jimnys with 1st model front bumper is produced by Cibie (division of Valeo), model 026719.
- It is not known under which official "OEM" / virtual Suzuki P.N. this fog lamp is catalogued.
- It appears that this Cibie fog lamp is sometimes also referred by another Cibie P.N. 67721231;
- This fog lamp appears to be compatible only with 1st model front bumper, and it requires its own specific bracket to mount it to that bumper.
Notes on fog lamp model Suzuki 35500-63J0x
- The following fog lamp models appear to have exactly the same dimensions, shape, bulb, el. connector and mounting points to the brackets:
- The actual fog lamp product under this Suzuki catalogue number is made by Valeo, P.N. 89210094.
- Renault uses the same lamp under its OEM P.N. 8200074008.
- 35500-63J03 - found on many European Jimnys from mid-2000s;
- This is probably the older "main" edition which was superseded by the current "main" edition;
- The actual fog lamp product under this Suzuki catalogue number is made by Valeo, P.N. 89210094 and/or 89206633.
- Two Valeo P.N.s are mentioned because both were factory stamped as well as this Suzuki P.N. on the actual fog lamp which was owned by a forum user.
- The actual differences between all these fog lamp models are unknown - possibly beam pattern or clear / ribbed glass?
- All these fog lamps can also be used in the 1st model front bumper with certain OEM brackets (mentioned elsewhere in the article), since that front bumper model has its own different "default" fog lamp model.
- Fog lamp model Suzuki 35500-63J04 / Valeo 89210094
- Brackets / carriers are required for mounting any fog lamp model to 1st and 2nd model front bumper.
- The 3rd model front bumper already has fog lamp brackets as its integral part.
- Bracket model 35526-81A30
- Bracket model 35566-81A30
- Bracket model 35566-84A00
- 3rd model front bumper - view from inside - enlarge the pictures and note the screw holes in the integrated front fog lamp brackets, to which the compatible fog lamps directly attach
- In some combinations (as indicated in the tables above), surrounding bezels are required to achieve nice "flush" cosmetic fitting of lamps inside the bumper holes.
- 3rd model front bumper already comes with a pair of "blank" bezels attached in the place of fog lamps.
- Left blank bezel P.N. is 71761-57M00-5PK and right blank bezel P.N. is 71751-57M00-5PK.
- The "proper" fog lamp surrounding bezels look exactly like the "blank" bezels, but only with a pre-cut hole for the fog lamps.
- Left "proper" fog lamp surrounding bezel P.N. is 71761-57M10-5PK and right bezel P.N. is 71751-57M10-5PK.
- Therefore, in theory, there is no need to buy "proper" bezels for retrofitting fog lamps to a 3rd model front bumper, as it should be (in theory) possible to carefully cut suitable holes for the fog lamps in the default "blank" bezels which are already present in the bumper, and achieve exactly the same look and finish.
- The P.N. of bezels, which are required for flush cosmetic fitting of fog lamp model Cibie 026719 in the holes in the 1st. model front bumper, is currently unknown.
- The P.N. of bezels, which are required for flush cosmetic fitting of fog lamp model 35500-63J0X in the holes in the 1st. model front bumper, is currently unknown.
- Appearance of fog lamp 35500-74F50 when mounted in 1st model front bumper - notice that it fits flush without any additional bezels
Wiring
The wiring setup for the fog lamps in Jimnys 3 is made up of several sections, separated by connectors.
More info on electrical connector types used in Jimnys is written in the article Electrical connector types.
- Some Jimnys 3, which were produced without front fog lamps, still have most of the required wiring elements (cables, connectors, relays, fuses, etc.) for them already installed.
- The best case scenario which you could expect is to already have everything from the above crude diagram already installed from the factory, except Fog lamps + Cable connector 5, Wiring 4 and Switch.
- Therefore, you should first check for the presence of wires with unused el. connectors in the vehicle.
- First search for the unused Cable connector 4 in the engine bay, just behind the head lamps.
- In Jimnys 3 type 1-5, there should be ??????? behind ???????.
- In Jimnys 3 type 6-8, there should be one unused connector behind one of the head lamps (usually left).
- In Jimnys 3 type 9-12, there should be one unused connector behind each head lamp (so two connectors in total).
- If not found there, then search for it/them somewhere behind the front bumper (after removing the front inner wheel arch liners).
- Then check if the unused Cable connector 3 for the console button / switch is present inside the console in the cabin (see the chapter about the installation of the console button / switch).
- If you find both unused Cable connector 4 and Cable connector 3 (for the fog lamps and for the in-cabin switch) in your Jimny 3, consider yourself lucky!
- In that case, you then only need to obtain the following:
- A pair of fog lamps (with suitable brackets if needed) + Cable connector 5 (usually comes integrated or attached with the lamps);
- Wiring 4;
- Switch;
- Then just connect the following:
- Switch to Cable connector 3;
- Wiring 4 to Cable connector 4;
- Fog lamps to Wiring 4 via Cable connectors 5;
- Mount the fog lamps to the bumper and go on joyful rides on foggy mornings ever since.
- If you find no unused Cable connector 3 and/or Cable connector 4 in the vehicle, you will also need to obtain wiring harness kit(s) Wiring 2 (includes Cable connector 2 and Cable connector 3) and and/or Wiring 3 (includes Cable connector 1 and Cable connector 4) as well.
- You can also buy one of complete fog lamp retrofit kits mentioned earlier in the article.
- That way you will eliminate any risk of missing any of needed components.
- The OEM wiring harness kit in the engine bay, represented by Wiring 3 + Cable connector 1 + Cable connector 4 in the crude diagram above, is P.N. 99000-990YZ-A05.
- This kit also includes In-line fuse (15A rated current) and a plug to the Relay, but not the Relay itself.
- It is currently not known if this kit is compatible with every Jimny 3 revision and every fog lamp model used!
- However, it is known to be compatible with Jimnys 3 type 1-4 and fog lamps model 35500-74F50.
- The OEM wiring harness kit behind the dash board in the cabin, represented by Wiring 2 + Cable connector 2 + Cable connector 3 in the crude diagram above, is P.N. 99000-990YZ-A06.
- It is currently not known if this kit is compatible with every Jimny 3 revision!
- However, it is known to be compatible with Jimnys 3 type 1-4 (with old style interior console).
- The relay is P.N. 99000-990YZ-A07.
- There is another relay P.N. 95572-63C00 which is instead mentioned in some other catalogues.
- Wiring harnesses 99000-990YZ-A05 & 99000-990YZ-A06 tangled together
- According to a forum report, it appears that the Cable connector 1 (if present) is located in the engine bay, near the bulkhead, almost behind the battery / below the brake master cylinder (in RHD Jimnys).
- It is a "single bullet" connector.
- According to the same reports, the Cable connector 2 (if present) is located near the wiring loom by the front right speaker (in RHD Jimnys).
- There are 2 main wiring bundles there - it should be in one of those.
Notes on Cable connector 4:
- It appears that this connector is some specific type in Jimnys 3 type 1-5 (with 1st model front bumper) (needs more investigation).
- This connector on Jimnys 3 type 6-12 (with 2nd and 3rd model front bumper) is actually the same male type connector as Cable connector 5 in Jimnys 3 type 1-5!
- See notes about Cable connector 5 below for more details.
Notes on Wiring 4:
- This element represents the wiring harnesses:
- P.N. ?????-????? for Jimnys 3 type 1-5,
- P.N. 36813-84A00 for Jimnys 3 type 6-8,
- It is a split dual wire harness which connects both fog lamps in parallel to a single Cable connector 4;
- P.N. 36813-57M00 for Jimnys 3 type 9-12.
- It connects only one fog lamp to the el. circuit (to Cable connector 4), so two of these harnesses are needed for one car.
- Wiring 4 should easily be removable from a donor vehicle while the fog lamps are being removed.
- Additional notes on harnesses 36813-84A00 and 36813-57M00:
- The connectors on these two harnesses are the same.
- These two harnesses are compatible with fog lamp model 35500-63J0x, which all Jimnys 3 type 6-12 use.
- Harness 36813-84A00 can be used in Jimnys 3 type 9-12, but it will not be as Suzuki intended.
- The thing is that there is only one Wiring 3 and thus only one Cable connector 4 in Jimnys 3 type 6-8 (usually on the left side), while there are two Wiring 3 and thus two Cable connector 4 in Jimnys 3 type 9-12 (one on each side).
- Harness 36813-84A00 is a split dual wire harness (connects both fog lamps to a single power source), so it will work in Jimnys 3 type 9-12, but one Wiring 3 + Cable connector 4 will be left unused, potentially creating a hanging electrical impendance.
- The probable reason why Suzuki chose to use dual wire harness in later Jimnys 3 (one for each fog lamp) instead of a common wire harness for both fog lamps is to reduce the current through the wires and increase robustness of the circuit (if one wiring fails, the other one is unaffected).
Notes on Cable connector 5:
- There are two types Cable connector 5 for front fog lamps in Jimnys 3.
- The first connector type was used in all Jimnys 3 type 1-5 (which originally came with 1st model front bumper, from 1998 to approx 2005).
- All other / newer fog lamp models which use H11 bulbs (including OEM fog lamps 35500-63J0X) can be connected to the first / old type of Cable connector 5 through a suitable connector adapter 36813-54G20.
- This adapter is exactly the same as the wire harness 36813-57M00 (same connector on both ends), only the harness is slightly longer. They can be interchanged!
- The second / newer Cable connector 5 type was used in all Jimnys 3 type 6-12 (which originally came with 2nd and 3rd model front bumper, from approx 2005 to 2018).
- This newer Cable connector 5 is actually a direct male connector for bulbs made according to H11 bulb standard.
- It is directly compatible with all fog lamp models 35500-63J0X, as these fog lamps use H11 bulbs.
- It is incompatible with front fog lamp model 35500-74F50 (which was not meant for 2nd and 3rd model bumpers anyway, since no brackets for that combination are available).
- However, a required el. connection could probably be made by cutting the Cable connector 5 off and soldering the Wiring 4 to the fog lamps directly.
![](/mediawiki/images/thumb/7/7c/Suzuki_Jimny_3_-_OEM_accessory_35500-74F50_-_fog_lamp%2C_front%2C_detail_of_el._connector_to_vehicle_-_A01.jpg/400px-Suzuki_Jimny_3_-_OEM_accessory_35500-74F50_-_fog_lamp%2C_front%2C_detail_of_el._connector_to_vehicle_-_A01.jpg)
- Wiring connector adapter 36813-54G20, for certain equipment combinations in point 'Cable connection 5'
- Regarding all the specific details of wiring, refer to a corresponding wiring diagram manual for your vehicle revision (and for donor's vehicle revision if needed).
Main info
- The switch appears to exist in two editions:
- Older model P.N. 37270-75F10;
- This model presumably fits Jimnys 3 with older (1998-2005) style interior and in-cabin console.
- Newer model P.N. 37270-76J00;
- This model presumably fits Jimnys 3 with newer (2005-2018) style interior and in-cabin console.
- Both switch editions appear the same - add info about the differences and compatibility if you know them!
- In-cabin front fog lamp switch (P.N. 37270-76J00)
This should be the pinout of the switch P.N. 37270-76J00:
- Pins 1 and 2 are earth.
- Pin 3 is unused.
- Pin 4 is the output to the fog lamp relay.
- Pins 5 and 6 are the "+ve" feed - these are wired to the lighting circuit in the vehicle, as it is not allowed to have the fog lamps on without having the main head lamps on.
- Pin 5 is the power that goes through to the fog lamps.
- Pin 6 is just the feed to illuminate the switch itself.
If you are using some 3rd party 3-wire wiring to connect to the switch P.N. 37270-76J00, then wire it like this:
- Earth - Pins 1 and 2 (connect to BOTH)
- From relay - Pin 4
- From main head lamp circuit - Pins 5 and 6 (connect to BOTH)
- In-cabin front fog lamp switch, unknown source. Probably aftermarket product. Note the presence of only 3 pins instead of 5.
- Test if the switch works.
In the case of 1st and 2nd model front bumper, you first have to cut out the plastic blanks in order to open the holes through which the fog lamps will illuminate the space in front of the vehicle. As this is an irreversible operation, it is advised to do this only after obtaining all the parts and test-connecting all the wiring to prove that it all works as planned.
Page last edited on 6/12/2019 by user Bosanek
