- Horizontal play in the front wheel
- With the car jacked up, grip the wheel sides - there will be movement if they are worn.
- Get an assistant to press the brakes while you are shaking the wheel - the movement should disappear.
- It is also common not to experience any play at all and to even pass an MOT with a really bad bearing.
- This is because the Jimny front wheel bearings have dual inner race and only one race may have failed.
Prerequisites
Required parts
The table
| Wheel bearing |
1 piece | 43462-84A00 | Various | Suzuki actually uses Koyo "DAC4168W HR4CS23" bearing under the stated OEM P.N. |
| Bearing oil seal |
1 piece | 09283-54001 | Various | This part is usually available in the aftermarket only in a set together with the bearing. Suzuki originally used the seal with inscriptions "Koyo" and "MHRD 54 69 7.5-9.5SJ" in a Jimny made in 2007. |
| C-clip | 1 piece | 09381-68001 | Various | This part is usually available in the aftermarket only in a set together with the bearing. |
| Bearing grease |
A fistful or so |
| A calendar with pictures of (half)naked women |
12 pictures / months |
- A complete 3-piece kit (wheel bearing + oil seal + C-clip).
Notes about greases
- The longevity of a wheel bearing highly depends on it being properly coated with a grease which has adequate lubrication properties for the application in wheel bearings, as well as the grease having adequate water, oil, grit and temperature resistance.
- The list of recommended aftermarket greases in the above table is by no means complete.
- This heavy duty lithium grease is the grease of choice in BigJimny shop.
- It has proven itself very well in practice with several Jimny owners.
- It claims to be particularly suited for bearings and it has a rather high heat resistance (almost 300 C liquifying point) and still claims good resistance against contaminants.
Required tools
- Assorted screwdrivers
- Hub nut unlock tool
- Circlip pliers (External)
- A ball joint splitter
- 1" Imperial Socket
You will definitely need the special tool to release the locking hub nut.
Notes about special hub nut unlock tool:
- This tool is available both original from Suzuki and various aftermarket models.
- Suzuki has three original tool models:
- 09951-16050;
- 4-pin, interchangeable with 09944-77020;
- Works on any Jimny 3;
- 09944-77020;
- 4-pin, interchangeable with 09951-16050;
- 09944-77010;
- 6-pin;
- This model is stronger and less fragile than the other two, but it works only on newer Jimnys 3 (usually post-2005) which have 6-holed hub locking nuts.
- 09951-16050;
- A notable example of a cleverly designed aftermarket hub nut unlock tool is Zukparts WBTool.
- Also available in their Ebay store.
- Its special value is that it works on multiple vehicle models:
- "Jimnys, Vitaras, Grand Vitaras up to 2004, Suzuki Sidekicks and Geo Trackers from the USA, SJ80 coil sprung Sierras & Samurais".
- Front wheel hub nut unlock tool Suzuki 09951-16050 / 09944-77020
- Suzuki front wheel hub nut unlock tool 09951-16050 and 09944-77020 - A01.jpg
- Suzuki front wheel hub nut unlock tool 09951-16050 and 09944-77020 - A02.jpg
- Front wheel hub nut unlock tool Suzuki 09944-77010
Replacement procedure
Removing the Caliper and pads
- First of all secure the car, release the wheel nuts and jack up the car and remove the road wheel.
- This then reveals the brake caliper, this is the passenger side (nearside) caliper (UK)
- If the pads resist, gently prise out the pads with a small screwdriver - do not remove the spring clips.
Removing the Brake Disc
- The caliper is held on with two bolts at the rear.
- If you are lucky it will simply pull off but if you have problems then there are two M8 holes in the disk hub.
Dismantling the Hub
- With the hub removed the driveshaft is exposed.
- The driveshaft is retained with a circlip so use a pair of circlip pliers to remove it.
- Now for the special tool.
- The hub is held on by a special round nut that requires a special tool to release it.
- The outside of the nut is a smooth polished ring which is part of the vacuum seal so it must not be damaged.
- Otherwise you will need a new nut (which is exceedingly expensive!).
- In the centre of the nut, the edge is bent over into a slot to help secure it.
- The slot can be seen in the photo in the “2 o’clock” position.
- Use a blade to bend the edge back into line.
- It is essential that this is completely free, otherwise it is impossible to undo the nut and you will break the tool.
- This is the tool.
- It is available from the BigJimny Store.
- Make sure that the tool and the nut are completely clean as the tool will not fit.
- Make sure the tool is inserted into the nut correctly with the pins all in the holes in the nut.
- You are really going to have to swing on the nut to release it.
- I had to use a long breaker bar AND a piece of scaffold tube.
- With the nut removed the hub should be removeable, it might need a pull with a slide hammer, mine just pulled off by hand.
- With the hub face down on a surface you can now remove the bearing seal from the rear of the hub.
- I prised mine out with a screwdriver.
- Then you can use a pair of long nose pliers to remove the C-Clips that retain the bearing.
- Note that these may be corroded in and difficult to even see at first.
- Now comes the first bit that is supposed to be difficult.
- Suzuki say that the bearing needs to be removed using a press.
- I decided to have a go myself - using an old piece of bearing and a steel pin I hammered out the bearing and it only took two or three swift blows.
- The picture shows the steel pin resting on the bearing before being hit.
- Note the use of the brake disk to provide a holder for the hub allowing the bearing to be driven out of the bottom.
- The bearings are Koyo brand as standard.
- The BigJimny store has a kit available which includes the seal and the c-clips (not all kits contain the c-clips), the Wheel Bearing Kit is here.
The rebuild
- Suzuki says the new bearing needs to be pressed into place.
- I decided to try a bit of school boy physics.
- I coated the bearing in Copper Grease and then put it in the deep freeze overnight.
- The hub was placed in the oven at 180 degrees for 30 minutes.
- So with an ice cold bearing and a very hot hub I put the bearing in the hub, placed the old bearing ring and the steel pin on top and tapped the bearing straight into place.
- It took two gentle hits!
- Again note the use of the brake disk to hold the hub.
- Once it is cooled put grease into the ends of the bearing.
- Then insert the new circlip and the oil seal.
- I found that the oil seal pressed in ok by hand once coated in Copper Grease.
- The oil seal has a protruding lip, this must be to the outside of the joint.
- Grease the inside of the bearing and slide the hub back onto the driveshaft.
- Grease the hub nut and tighten the nut using the special tool
- Torque it to 220NM or 160ft lbs – ie. really tight!.
- Use a punch to bend the inner lip of the nut to lock it in place.
- Refit the hub thrust washer and circlip to the driveshaft.
- Fit the disk and fit the caliper (Caliper bolts 61ft/lbs), brake pads and bolt the caliper down in position (Caliper pin bolt 16/ft/lbs)
Page last edited on 10/12/2019 by user Bosanek
