Axle
| Item
Torque Nm
Torque lb-ft
| Radius Arm bolts (Axle)
90 Nm
65 lb-ft
| Radius Arm bolts (Chassis)
90 Nm
65 lb-ft
Differential
| Item
Torque Nm
Torque lb-ft
| Diff Drain Plug
27 Nm
19.5 lb-ft
| Diff Filler Plug
50 Nm
36.5 lb-ft
| Prop Shaft Flange Bolts
50 Nm
36.5 lb-ft
| Bevel Gear Bolts
85 Nm
61.5 lb-ft
| Bearing Cap Bolts (front)
50 Nm
36.5 lb-ft
| Bearing Cap Bolts (rear)
85 Nm
61.5 lb-ft
| Lock Plate Bolts
11.5 Nm
8.5 lb-ft
| Front and Rear carrier bolts
23 Nm
17 lb-ft
| Gear Thrust Bolt (front)
1.5 Nm
0.1 lb-ft
| Gear Thrust Bolt (rear)
85 Nm
61.5 lb-ft
Front Hub
| Item
Torque Nm
Torque lb-ft
| Wheel Nuts
95 Nm
69 lb-ft
| Tie-Rod End Nut
43 Nm
31.5 lb-ft
| Kingpin Bolt
25 Nm
18.0 lb-ft
| Locking Hub Bolts
48 Nm
35 lb-ft
| Swivel Seal Bolts
10 Nm
7.5 lb-ft
| Brake Carrier Bolts
85 Nm
61.5 lb-ft
| Wheel Bearing Lock Nut
220 Nm
160 lb-ft
| Drop-Link/Stabilizer Link ball nut
50 Nm
36.5 lb-ft
| Brake Caliper Slider Bolt
22 Nm
16 lb-ft
| Front Brake Flexi Hose bolt
23 Nm
17 lb-ft
| Wheel Spindle Bolt
50 Nm
36.5 lb-ft
Gearbox (R72) Post 2005
| Item
Torque Nm
Torque lb-ft
| Fill and drain plugs
23 Nm
17 lb-ft
| Reverse Switch
23 Nm
17 lb-ft
| 5th gear shift inverse lever bolt
23 Nm
17 lb-ft
| Transmission case bolt
23 Nm
17 lb-ft
| Gear shift rod spring / ball bearing bolts
13 Nm
9 lb-ft
| Gearbox case to engine nuts and bolts
90 Nm
65 lb-ft
