- Clicking when in 4WD when turning
- Banging and snatching of the steering wheel
- Loss of 4wd
CV joint information
Identifying type
Suzuki uses two different CV joints in the Jimny. One is straight forward to purchase on the parts aftermarket and the other is nearly impossible to source.
- Type 1: 6 balls, 26 external splines and 19 internal splines. - BigJimny Store NTN 75LAC CT9U)
- Type 2: 8 balls, 26 external splines and 29 internal splines. - BigJimny Store (possibly marked NTN EBJ82 although NTN call it an 8-Ball CV)
| Model | Balls | Inner Splines | Outer Splines | Outer Case Dia | Inner Case Dia | Shaft Dia | Type |
| NTN BJ75LAC | 6 | 19 | 26 | 91.6mm | 72.6mm | 19.0mm | Type 1 |
| NTN EBJ82 | 8 | 29 | 26 | 91.6mm | 72.6mm | 21.2mm | Type 2 |
CV Joint compatibility
Note: check the specific joint for your vehicle before ordering.
| Country of Manufacture | Engine | VIN Number | CV Type |
| Japan (JSA) | G13B | ALL | Type 1 |
| Spain (VSE) | G13B | ALL | Type 2 |
| All | M13A | up to 00186627 | Type 1 |
| All | M13A | from 00186627 | Type 2 |
NTN 75LAC CV Joint
NTN 75LAC CV Joint
NTN 75LAC CV Joint - 26 Outer splines
NTN 75LAC CV Joint - 19 inner splines
NTN EBJ82 Style CV Joint
Note these pictures are of a 6-ball copy (the real thing is an 8 ball CV but is not available as a standalone CV, it comes with the full drive shaft)
NTN EBJ82 Style CV Joint - 26 Outer splines
NTN EBJ82 Style CV Joint - 29 inner splines
Prerequisites
Required parts
| Constant velocity joint |
1 piece | Type 1:
Type 2:
Type 1:
Type 2: |
| Halfshaft oil seal |
| Steering knuckle swivel seal |
| Differential oil |
1.1 - 1.65 litre |
Who cares? | See the wiki article "Forecourt" for important details! |
| Heavy duty grease(s) |
A handful or so |
| A calendar with pictures of (half)naked women |
12 pictures / months |
Claudia Schiffer Ana Kournikova Monica Bellucci Salma Hayek Pamela Anderson |
- This heavy duty lithium grease is the grease of choice on BigJimny shop.
- It has proven itself well in practice with several Jimny owners for lubricating and protecting king ping bearings.
- This is just a presumption, because it is very thick and very "gooey" - but it might actually be great in practice.
- Somebody has yet to try this grease in a CV joint and in a wheel bearing and report the long-term effects.
Required tools
- Assorted screwdrivers
- Circlip pliers (external)
- A ball joint splitter
- 1" imperial Socket
The Video
Removing the Caliper and pads
Removing the Brake Disc
Dismantling the Hub
Re-assembly
- You may wish to change the king pin bearings and oil seals at this point if you wish.
- Again the BigJimny shop sells suitable sealant.
Page last edited on 23/03/2018 by user Bosanek
